Go to Post A robot that does 60% of the tasks 100% of the time is better than a robot that does 100% of the tasks 60% of the time. - artdutra04 [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 24-07-2014, 18:32
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Pneumatic Restrictions & Improvments
In 2014 we saw a large upswing of people using pneumatic for their launching mechanism. This created quite a discussion on rules and legal restrictions for pneumatics.
If you are the GDC , How would you improve the pneumatics rules next year ?
For example.
Why are we limiting CV , tubing and port size ? (CD thread )
Why do we limit low-pressure to 60 psi compared to 70 or 80 psi ?
Are there any devices that could improve the pneumatic experience for most teams ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 24-07-2014, 18:53
magnets's Avatar
magnets magnets is offline
Re: Pneumatic Restrictions & Improvments
For example.
First of all, pneumatics restrictions were lessened by a lot this year. The CV of the valve restriction was removed.
The reason the GDC limits CV is for safety. If we had unlimited CV, and someone were to put their head against a medium to large size pneumatic cylinder, and it is accidentally actuated, the person would die.
Unread 24-07-2014, 19:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Quick exhaust valves. PLEASE
Unread 24-07-2014, 19:40
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Even with our current systems that could happen, 2in bore cylinder with 60PSI behind it is a lot of force. Also some spring punchers were just insane in amount of stored energy.
Basically the hose (1/4) and the 1/8 NPT rule limits the "power available".
Personally I want to be able to use a 3000PSI CF paintball tank/regulator so I never have to charge air at a competition but I don't think that's happening anytime soon.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-07-2014, 19:54
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Very true.
This year, we were playing around with a pneumatic launcher, and we wanted to try it with shop air. Strangely, no air was coming from the valve, and after closing all the other valves in the room (it shuts off the compressor if it detects a leak) so I went to go to the maintenance room to check on the big compressor. It turns out the room's dump valve had a faulty contact, and when I opened up the electrical panel, the valve opened, pressurizing the cylinder very, very quickly. The cylinder and its bracket went flying across the table, both fittings were torn/snapped off. It left a sizeable dent in the sheet steel counter, and chipped off part of our CNC's safety shield!
Unread 24-07-2014, 20:05
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Let us charge with offboard air compressors, even if we have one onboard.
If it's made legal for everyone, it's no longer a competitive advantage, and there are ways to let it happen safely. I'd argue it's much safer to go into the match with a cool compressor than a hot one which can melt tubing or drag on battery voltage.
-Plutarch
Unread 24-07-2014, 20:37
Mk.32's Avatar
AKA: Mark
As a robot 2014 inspector, this can be legal. You just have to power it from the robot. With either an 2nd spike or just unplugging the off board temporary. I know 987 actually had two off board compressors they switch between to make sure they never over heated.
Now I understand you probably mean just plugged in a off board into a battery, or using a shop air compressor. But safety concerns I would guess, have first to ban them and we have no power over that. Again rules many change in 2015, but doubt they would change this one.
Unread 24-07-2014, 20:50
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
R79 is pretty clear stating that you cannot. "One and only one compressor."
Originally Posted by 2014 Manual
R79
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 24-07-2014, 21:22
Mk.32's Avatar
AKA: Mark
We had this debate .... and I think it was on QA too, one and one compressor = one running at a time. So you can have two in the pits/around, but you can't use them both at the same time (aka to charge air faster).
Unread 24-07-2014, 21:36
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
We had a pneumatic catapult. I found a way to actuate a 2in bore, 10in stroke at the speed of a 3/4 in bore, 4in stroke. So, staying within the regulations, we had the strength of a 2in bore with the speed of a small, 3/4in bore.
Unread 24-07-2014, 22:02
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I just checked, it wasn't specifically asked on the Q&A this past year. Regardless, R79 is very clear - your robot can only have one source of compressed air. Filling it with an off board compressor then using a different on board compressor during the match is two sources. If you dump pressure before the match, your fine... And as an LRI, that's what I'll do if I see a team charging with an off board compressor while having one on board.
2016: Lake Superior WFFA
Unread 24-07-2014, 22:23
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
We didn't have an on board compressor on our robot. As stated in previous post, we had two off board compressors and only used ONE at any given time.
"A genius is just a talented person who does his homework" T. Edison
Unread 25-07-2014, 01:44
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I've seen people on these forums and elsewhere explicitly say that you can only have one compressor charging the robot's tanks, which means no off board compressors if you have an onboard one. Not that you're incorrect, but there's definitely a lot of misinformation out there about this.
Yes, that's what I mean. Having to enable your robot with the DS just to charge the tanks is a huge PITA. As long as you can demonstrate that your off board control system will shut off automatically at 120 PSI, and had an emergency pressure relief valve, I don't see how it's a safety concern. In any case, it's exactly how the inspectors determine that the regular onboard pneumatic compressor is safe.
-Plutarch
Unread 25-07-2014, 09:45
headlight headlight is offline
headlight is an unknown quantity at this point
Quick exhaust valves can be approximated by using a 2 port solenoid valve at the cylinder and controlling it through software to provide an additional dump path. It would be way easier if we could just use quick exhaust fittings.
I would like to be able to use mufflers. Please. It is a small purely aesthetic change but high flow vent caps on the solenoid manifolds ensure that nothing gets inside. And a high flow muffler on the manual pressure release vent plug just helps keep sound down and makes sure there isn't a blast of air blowing stuff around whenever you dump pressure.
If would be nice if the pneumatic rules were just slightly more clarified and consistent. Things like ball valves, can they be used or not? or can they only be used as the main pressure dump?
There is also an entire world of pneumatic logic that hasn't been particularly capitalized on.
Unread 25-07-2014, 09:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I would eliminate plastic storage tanks completely. I would consider requiring that storage tanks be mounted to avoid damage by contact with the field or other robots, but that would be a hard rule to word.
One issue with shop compressors is that almost all the venues are power limited. You don't have enough power in the pits to run 30-60 compressors at the same time. A side effect of limited the compressor capacity is the it limits the practical amount of stored air on the robot. Maybe limit the stored air volume & open up off robot compressor sizes?
