| Thread Tools |
Rating:
Display Modes |
Frank Answers Fridays: Expanded Championship Qualification
http://www3.usfirst.org/roboticsprog...idays-07252014
Re: Frank Answers Fridays: Expanded Championship Qualification
inb4 Gregor comments on "nationals"
How can Michigan solve this problem? Increase the size of MSC by moving to a new venue? Adding divisions like World's? Jim Zondag addressed this issue a few years ago in his whitepaper. Quote:
Yes, having so many teams make it from a district that the championship is worthless is a problem... but perhaps more of a problem is for the areas that aren't districts.
Minnesota, for example, is probably going to have about 200 teams next year. As a state, we have 4 regionals... which means 24 slots at champs. Sure, a few teams travel to out of state regionals, but even more teams from out of state come to our regionals and win slots. What it ends up meaning is that, as a state, the number of teams we send to champs is essentially a constant, and not comparable to the number districts send, as a proportion to FIRST population. We don't grow as champs grows - if we want more MN teams to make it to champs, we have to hold more events. The same isn't true for the districts, which creates, in my opinion, a severe imbalance across FIRST. FIRST needs to come up with a system whereby they can support both the district and regional model while allowing proportional representation from every distinct area. Picture something like drawing up district lines across all of FIRST for Champs participation, but the method of entry for each individual region could be different - The district model could use the point system with a district championship, while the regional model could pull X teams from each regional, based on the number of teams needed for that area (with each area designed to have a minimum of 6 teams attending). For the regional, you could use a point system for the event, or base it on awards, or whatever. |
Why does FIRST have to ensure proportional representation from all areas?
Of course it doesn't. But it's a way of saying that, to a first-order approximation, all teams have a roughly equal opportunity to advance to CMP. This is part of what makes a compelling competition.
#7
Almost no where in FIRST is an equal distribution of CMP slots to number of teams. Florida for instance, there are 12 total possible slots for CMP and yet Florida hold roughly 4% of FIRST; this would be 17-18 slots of CMP. Florida actually sent something like 10-12 teams to CMP this year too.
#8
But personally I would rather there be some new determining factor that is fair to all teams other than who can click a mouse the fastest. Quote:
#9
I'm not sure why a FIRST-wide points system based on the standard district model points system wouldn't work....
Top 600 teams in the world go to champs. |
#10
EDIT: Though if that idea would have been applied last year Florida would have been represented by 180, 179, 744*, 1592, 1251*, 108, 79, and 233*, meaning 1902, 3932, 4013, 5145 and 5196 wouldn't have made it (All who won the awards above except 3932 who was the last pick of the South Florida Winning Alliance) *-did not qualify Last edited by MARS_James : 25-07-2014 at 19:02. |
#11
Hm. Something is vaguely unsatisfying with the comment about 'a district with 10% of the teams gets 10% of the slots'. That's the case now (more or less), but I'm just not following the logic to expand that to 600 slots, guaranteeing a near-overbooking situation every year. And the absurdity of sending 60 teams from MI.*
I think it's me. I do understand the logic of equal representation though. Either you run districts, which get a proportional representation (and rewards you for growing FRC), or you run regionals, which gets you (about) 6 slots per regional (and rewards you for being able to fund more regionals). I don't envy the task force. *Not that they're not welcome, but as AGPapa pointed out, the MSC becomes pointless for everyone but 4-5 teams. |
#12
FIRST doesn't have to have proportional representation at champs... The problem comes in when some areas are proportional while others aren't. Teams from Michigan don't have to compete for spots with teams from Hawaii, Wisconsin, Iowa, Ohio, etc... But Minnesota teams do. I'm completely willing to back a non-proportional system, so long as it provides equal opportunity for everyone, not two radically different sets of rules that potentially benefit one group but not another. Giving proportional representation to one group but not another simply doesn't present a level playing field.
#13
I'm all for having the most competitive Championship experience, but the impact of a Championship on a less-than exemplary team also needs to be noted -- I've had the distinct pleasure of seeing faces light up with inspiration at the level of play at the Championship. However, some of those teams wouldn't have gotten there if they hadn't been that third robot to the #1 alliance. So I guess what I'm saying is that the top teams should go, but that also needs to be weighed against the merits of letting weaker teams experience Champs. |
#14
There's also a paper on representation of regions at CMP (link) that goes back quite a bit. (It probably doesn't have much to do with the topic at hand but I think its a good read as well). Although I do find it interesting, I really have no idea what can be done about it, if anything (especially the under-representation some regions face). |
#15
MN Teams in 2014: 186 FRC Teams in 2014: 2707 Percentage of FRC teams from MN: 6.87% Number of slots if represented at champs by percentage: 27.5 Current in state slots available: 24 Percentage of MN teams at champs if all slots won by MN teams: 6% 2014: 24 slots available, 6 slots won by non-MN teams 2 MN teams double qualified (one of them providing a wildcard slot to another MN team) Slots won by MN teams: 18 Slots used by MN teams: 17 Percentage of champs teams who are from MN: 4.25% The percentages currently aren't that far off, but as MN grows it will become farther and farther away from equal representation if more slots aren't available to MN teams. Of course there are two other regionals frequented by MN teams that are available but for the most part MN brings in more out of state teams then we send to other states. I may go through at some point and run the numbers for 2013 as well if I get the chance. |
