Go to Post It's one thing to post thoughts, guesses, opinions - that's all good ... However, it's [different] to make statements claiming first hand knowledge & facts without actually having first hand knowledge, facts, or accurate information. - Jason Morrella [more]
Unread 28-07-2014, 18:08
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Team 3489 Category 5 Presents Storm Drive
You should be careful with worm gears in your drivetrain. If you slam into a wall (or other robot) at full speed, there could be a tremendous axial force applied directly to your worms.
Also you may be unable to push the robot around in your shop/etc
Unread 28-07-2014, 18:16
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Actually, it turns out that, once broken in, these gearboxes can be back-driven with some effort. We don't want to make a habit of it, but it's possible. The spider couplings also help with some of the shock load. We disassembled 1 gearbox after 2 (often rigorous) regionals and a few demo events, and the gears showed no visible damage.
FRC Team 3489 "Category 5"
Unread 28-07-2014, 22:39
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Originally Posted by Andrew Schreiber View Post
Not really. Having the traction wheels on the outside makes you more stable when they are down. You are less likely to be spun (longer moment) and, have a bigger contact patch to keep your CG inside and prevent tipping. You don't need to worry about either of these with omni wheels due to them being slippy by design. (It's real hard to tip an omni bot due to them just sliding away and their habit of preserving their inertia, and spinning them is almost always easier no matter their contact patch)
Basically, there's design benefits to having your traction wheels on the outside. I can't come up with any obvious ones to having your omnis on the outside.
Come by our pits sometime. My kids would like to show you the advantages of a small traction wheelbase octocanum.
Unread 28-07-2014, 22:57
Joining the 900 Meme Team
FRC #0079
Or you could tell me and save me a trip... I'll ignore that I said nothing about mecanum wheels.
Unread 28-07-2014, 23:15
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Both have their advantages and disadvantages. It really depends on your end goal. Putting the traction wheels in the center gives you more turning ability with more control over where the robot ends up (no drift due to omni wheels). You would probably be using the omni's to escape a t-bone or something like that.
On the flip side, putting the traction wheels on the outside means you are primarily using the omni's most of the time. I believe this is what most teams who use butterfly do, because of the reasons Andrew Schreiber said - you have a longer wheelbase for stability when you're pushing or being pushed, and are less likely to be spun around.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 29-07-2014, 09:24
HumblePie's Avatar
AKA: Mista Doug
Originally Posted by Abhishek R View Post
Wow. This is really cool. Do you have any video of it in action?
Hope this works.........
http://youtu.be/arKL5XCXGfU?list=UUZ...8THLwUgtdjtgdg
You may notice a lot of "power slide" maneuvering with the 4 omnis. What you probably won't notice is much audio, and yes it was on. The team decided to go with 4 omnis rather than 2+2 omni/traction, which would have made the driving dynamics very different. The 4 omnis did make it much easier to place the robot on the field (by pushing it sideways) since the gearboxes were hard to backdrive, at least early on. The chassis has since been converted to 2+2 for demo events, and the chassis can be maneuvered in any direction now that the gearboxes are broken in.
Unread 29-07-2014, 13:56
wilsonmw04's Avatar
Coach
Originally Posted by HumblePie View Post
Looks nice. Have you tested it on carpet? One thing I noticed is that it is so quiet!
Unread 29-07-2014, 14:26
FRC #0624
This is great. Omni wheels are a lot of fun once you get the hang of them.
Team Website
Unread 29-07-2014, 14:30
HumblePie's Avatar
AKA: Mista Doug
We've used it in 2 regionals this year, so absolutely. The carpet provides better traction and stability than on the polished concrete.
Unread 30-07-2014, 09:29
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
I am just going to put it out there. When your traction wheel and omni wheel are this close together, wouldn't it make more sense to put packaging of the system over the traction wheel base? Especially for the drive this thread is about, moving the traction wheels to the outside could net you about an extra inch at most of traction wheel base. While moving the traction wheel out would appear to make it more difficult to package.
Also, do you have any video of the drive at competition weight. It would give us a much better idea of this drives capabilities.
Unread 30-07-2014, 10:19
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
From my experience, many drive train modifications/features provide only marginal gains, but when you look at the sum of all the little details, you will see a noticeable improvement.
Successful sports teams
often use this principle of "aggregation of marginal gains", it works just as well in the FRC world.
Unread 04-08-2014, 01:55
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Looks sweet. I would like to see the worm drive gearbox in action, it looks interesting.
Unread 06-08-2014, 18:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Very cool looking! Do you have and specs in CAD for the individual module weight?
The use of a worm gearbox plus the cim mounting... such a beatiful combination.
