Go to Post I think that FIRST should just give up and officially recognize Chiefdelphi as the place to go for community and team resources. - Greg Needel [more]
Unread 29-07-2014, 17:24
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Replacement for Pneumatics and Linear Actuators
I'm a bit confused about it's advantages then. If a lead screw mechanism were designed to be pull only, then it could be very compact and likely substantially cheaper than the $191 seen here. This takes up a relatively wide cross section, and to cover the vulnerable innards would increase that.
You'd have a tough time selling me on the reliability of the cabling (not unspooling ever, etc...) as well.
What type of printing is done on it? I'd have concerns about the strength of the eyelets too depending on motor ratio.
If these could move faster than a lead screw, I'd certainly consider using them. Really clever design, with some more improvements they could become a valid replacement for pistons in some applications. (though they really should increase the preload on that shooter )
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
