Re: 1" Bore Timing Pulleys
It's not likely that you'll find a 1" bore on a metric sized pulley. That being said, you may be able to find a 25mm bore pulley, which can be opened up (25.4 mm = 1") for your needs.
If you don't have machining resources, you could likely sand down the steering tube by hand. It's only .014" difference, assuming you can get the 25mm bore pulleys |
