Thread Tools |
Rating:
Display Modes |
Re: Team 1511 Prototype Drivebase CAD
Do I understand this correctly? You're going to drop your electronics into the floor to resist being pushed?
I am just wondering why are you using flat metal plates rather than putting flanges to make it rigid? You use flanges in other parts but still use flat metal plates along the length of your frame.
Also, make sure you don't damage the field when you drop your "super brake". |
Drive bases with omniwheels at each corner like that can be very hard to control at times. They tend to be difficult to drive straight.
What is the final speed of the drivetrain? That's a pretty large gear on the transmission output shaft. We've had very little luck tensioning chains using the manner you've shown. The friction from the single fastener in the end of the cam shafts simply isn't enough to keep the cam stationary and they will end up spinning. Drivetrains generate a surprising amount of force on the chains. It appears that the only thing holding the chassis 'square' are the 2 bolts at each junction between the side modules and the front crossbar. This will not be strong enough, and you will want gusseting. You will probably also want support across the middle of your chassis - that's why so many teams use a solid belly pan. It stiffens up the platform significantly. |
In regards to omni wheels we have used them three times out of the four past years and our driver is more comfortable with them.
I like the concept, but I do have a few suggestions. You might be able to save some footprint on the battery mount by changing from the folded sheet metal to a few pieces of aluminum 1x2 angle (or something similar cut out of some 1x2 rectangular tube) or something similar. Also, I'd be very wary of having the battery on the drop down bellypan, that seems a bit sketchy. As previously mentioned you're probably better off designing a few drop down brake pads and making sure that they comply with the rules (though the 2015 rules haven't actually been announced yet). Not only would you not have to drop the battery, the bellypan would go a long way towards stiffening your frame. Best of luck with the beta testing, and nice job on the design head start, you'll definitely have something you really like by build season.
![]() I like the description "a bit sketchy," in referring to the battery dropping, and it may even be an understatement. That is why we are trying it now, not during build season. The idea came from a mentor who recently left for California, and we decided to go with it at least for this project. Hopefully it will make lifting the wheels off the ground a possibility. |
#7
We are also planning on having bumpers that are entirely connected (one piece), and that are reinforced with aluminum. I don't know if anyone else has had good results with bumpers that also serve to reinforce their structure, or if that is just not a good idea. |
#8
I love the design and the ideas in it. Why not go with somewhat of a WCD style drive if you are not using sprockets for a final gear ratio? You could just gear directly to the center wheel and save yourself some weight. Also on the gear boxes I would definitely have multiple replacements. This last season we had one of our vex gearboxes crack and the motor almost fall all the way out of the transmission in finals of a competition. We also had the output shafts fall out several times during matches. (This could be fixed by glueing the shaft back in, but it was a huge pain)
Dropping the belly pan is an interesting idea, but I would be very cautious in doing that. First if you lost air pressure and put it down, you would be unable to lift it again leaving you useless for the rest of the match. Second if you get in a pushing match and drop it, you will be putting your robots weight and all the force of the other robot on 4 pistons. If you were rammed at a high speed while you had it dropped, I think its possible you could break the pistons or the supports. Third I do like the idea of dropping a separate piece down to act as a brake though. |
#9
I would highly recommend you give this chain spacing calculator a try to properly space your wheels. We used it this past year on 35 chain and after a full season the chains have stretched slightly but they are still in great shape to run. Its been really nice not having to worry about chain stretching out over a season and eliminate some components from the robot. http://www.chiefdelphi.com/forums/sh...8&postcount=10 Also am I looking at the model right that you are using two shaft collars to keep your axles in place? I would recommend using slip rings or tap each end of the axle with a 1/4-20 thread. Shaft collars will come loose very easily and if you don't check them after every match it will come off eventually. Your drivebase is the most important part of the robot that will see the most run time. If you make it as reliable as possible and eliminate as many failure points as you can your pit crew will spend little to no time touching it in a season. If you keep the gearboxes mounted as they are now you might want to consider running dead axles instead of live axles as you are now. Round bearings are cheaper to buy in comparison to 1/2in hex. Since you aren't directly driving your center wheel there isn't much of a need to go with live axles. Another thought to consider is how to make each wheel/axle assembly as similar as possible to reduce the number of unique parts and make repairs a lot easier. This past year we made every wheel/axle assembly the same on both of or robots including color coded spacers so all parts were interchangeable between wheels and robots. Of the few times we did have to adjust our drivebase it was an pretty pain free. You can see a picture of one of our drive modules assembled for reference. |
#10
It's an interesting concept, but like Madison I would recommend not dropping your really expensive electronics on the ground that hard. Also be aware that you will need to prove that your robot's belly pan is fully in compliance with current rule r6, wherever it get put in next year's rules, meaning that you will need to add some type of rubber tread to the bottom of it. My suggestion would be to instead of dropping your entire belly pan that instead, design four posts that do the same function, or look at 118's and 1114's drive train's drop down omni-wheels as inspiration instead. I also know that 1730 did something similar as the two previously mentioned, but instead they used a ball caster like these http://www.mcmaster.com/#standard-ca...nsfers/=t2it6g.
#12
I'm not sure if this was mentioned yet. But you are going to need to redesign the electronics board if you want to use this in the future. We would be using the RoboRio and not the Crio
#13
Yup we are aware of this. Our idea behind this project is to get the experience we need going into next build season to build a similar drive train for next year. Additionally since we are a beta team we will be gaining experience with the RobotRio during the summer so it shouldn't be too difficult to change the electrical board next year.
#14
That being said, we plan on putting some blue nitrile tread on the bottom of the belly pan. This will help make the base more difficult to move while preventing carpet damage. Last edited by Vespasian : 02-08-2014 at 21:01. |
