Go to Post You can be extra safe or you can be competative - its your choice. - Raul [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 23-07-2014, 10:25
Neutrinos6433 Neutrinos6433 is offline
FTC #6433
Neutrinos6433 is an unknown quantity at this point
Re: [FTC]: 2014-2015 Game Manual Part 1 Now Online
Originally Posted by atucker4072 View Post
Say the game calls for speed like Block Party did. That's great you realize it and you build a fast robot that can zip around the field. Okay someone plays defense on you. Would you rather have to try and make a move around them and possibly have to around to the other side of the field or would you rather shift and be able to just push them out of your way?
Are we sure a shifting gear box is legal? I would think it is a COTS with more than one degree of freedom. Only COTS with one degree of freedom are allowed. In a shifting gearbox, one degree of freedom is rotational and the other degree of freedom is translation (for shifting).
In fact a non shifting gearbox could be considered having more than one degree of freedom as each gear has its own axis and different rotational direction. All this will have to be clarified in the official forums, but your comments at this time will be appreciated.
  #32   Spotlight this post!
Unread 23-07-2014, 11:55
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Andy Mark is updating the information on the link to the motor to say that all the gears are metal! No more plastic gears!
  #33   Spotlight this post!
Unread 23-07-2014, 12:01
Andrew Tucker
AKA: Andrew Tucker
When I talked with the person that had been working with it, it was specifically designed for FTC. The goal of it was to make smaller of the shifter that 4251 had built this year. That's all I know.
  #34   Spotlight this post!
Unread 24-07-2014, 00:22
jcarr jcarr is offline
Coach
FTC #3539
jcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud of
I think that the shifter has two degrees of freedom and don't think that it would be legal under the rules as written unless the forum specifically allows it. However, the ability to use COTS gear housings may make it easier to build your own.
  #35   Spotlight this post!
Unread 24-07-2014, 00:35
Andrew Tucker
AKA: Andrew Tucker
They did have a single speed gear box actually. It was about as half as thick as the shifter. Other than that it was the same size. Basically a smaller FRC single speed gear box.
  #36   Spotlight this post!
Unread 24-07-2014, 15:05
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
This is an outstanding development. Does anybody from the FRC world know if AM usually supplies repair parts for their motors?
let tau = 2pi
  #37   Spotlight this post!
Unread 24-07-2014, 18:01
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Generally in FRC the motors don't have replacement parts but the gearboxes do, I asked andymark and they said there are currently no plans on the motor having replacement parts.
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
  #38   Spotlight this post!
Unread 31-07-2014, 10:57
JohnFogarty's Avatar
AKA: @doctorfogarty
I've never in my days ever thought I would want to replace parts of a motor. Now a motor-gearbox combo like the Tetrix motors are, that's a different story.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #39   Spotlight this post!
Unread 15-08-2014, 23:30
ftcTeam6389 ftcTeam6389 is offline
FTC #6389
ftcTeam6389 is on a distinguished road
Details about the new Andy Mark motor are here:
http://www.andymark.com/product-p/AM-2964.htm
I'm excited about the built-in encoder but a bit apprehensive about the plastic gear.
what plastic gear? the specs say "Gear Material: Steel"
confused.
  #40   Spotlight this post!
Unread 16-08-2014, 00:29
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
confused.
When the product was first released it had a single plastic gear and then they changed them all to steel.
Smart Move Andymark!
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #41   Spotlight this post!
Unread 30-08-2014, 12:15
Snakebyte 4546 Snakebyte 4546 is offline
FTC #4546
Snakebyte 4546 is an unknown quantity at this point
So I was wondering what ya'll thought about the rules regarding the SuperPro board and accessories. The rules aren't incredibly specific regarding this but it seems like it IS legal to have two 9V batteries, one for the SuperPro and one for visible LEDs (if they aren't robot controlled). But, if they are being controlled by an Arduino Micro (Which seems to also be legal, <R11>.D.ii) Can they technically be considered "Non ROBOT controlled, thus allowing for an independent 9V battery? This is what we interpreted. Any thoughts?
-Snakebyte 4546
  #42   Spotlight this post!
Unread 31-08-2014, 22:37
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
I think it would be legal per R04c
COTS parts and assemblies may only have a maximum of a single degree of freedom. It is the intent of FIRST that teams design and build their devices to achieve the game challenge. Assemblies of COTS components, such as linear slides, and gearboxes are allowed while a pre-fabricated gripper assembly designed to grab the game elements is not. Holonomic wheels (omni or mechanum) are exempt from the one degree of freedom limitation.
Examples of single degree of freedom COTS components are:
  • Hinges
  • Sprockets
  • Gears of any type, including Rack and Pinion gears
  • Simple and compound gear trains
  • Planetary gear trains
  • Lazy Susan
Just my thought, but as always it should be asked in the FTC Q&A.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
  #43   Spotlight this post!
Unread 01-09-2014, 15:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Compound in the context of gearboxes could also mean a single speed, multi-reduction gearbox, such as an am toughbox. It is with Q&A before a purchase is made, IMO.
  #44   Spotlight this post!
Unread 01-09-2014, 20:40
Very true. Definitely a Q&A issue.
FRC 4466
FTC 7042
  #45   Spotlight this post!
Unread 02-09-2014, 14:14
skatefriday skatefriday is offline
skatefriday is an unknown quantity at this point
-Snakebyte 4546
We powered an led light strip via the main robot battery pack, running
it through a 7805 voltage regulator (with a huge heat sink) last year.
We had a schematic of the voltage regulation circuit and a fully educated
team member for judging should a judge question the setup.
Note that all microcontrollers, which includes an arduino, must be
powered from the superpro protoboard, and it can only supply
something along the lines of 8mA. A stock arduino will draw 20mA,
so we ran a barebones ATmega328 to drive the led strip.
Writeup here:
http://degreesplato.wordpress.com/20...s-need-lights/
