Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 31-07-2014, 14:11
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: 1" Bore Timing Pulleys
Originally Posted by Gdeaver View Post
We use HTD5 all AL pulleys and then bore them out on the lathe. Plastic pulleys we have found do not have the clearance to drill out with a key way. We found it better to drill in several steps from 1/2" to 1". Our HTD pulley supplier got out of the business and we are looking for a new supplier. Lead time can be a problem.
Gdeaver - I noticed in the 1640 CAD models that you guys chose a 32T, 5mm HTD x 15mm wide setup. Are you able to offer any details about how you arrived at this selection? I'm curious if it was a function of product availability, or if it was more based on torque requirements?
