Go to Post Oh, the magic smoke will just make make it seem a bit more like Christmas. - CJO [more]
Unread 31-07-2014, 12:50
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
pic: Ultralight Spoked Wheel
Unread 31-07-2014, 12:56
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: pic: Ultralight Spoked Wheel
It would be doable if the the spokes were solid, but I don't see how you could machine the pockets of the X's into the spokes, no matter what kind of machining resources you had.
Nice render though...
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 31-07-2014, 13:04
RKazmer RKazmer is offline
FIRST Volunteer
AKA: Richard Kazmer
FRC #2363
RKazmer is on a distinguished road
3D printing the part might work for the 8-spoke. Not sure about the 12.
Unread 31-07-2014, 13:09
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They could be cast, potentially. Making the mold would still be a challenge.
Unread 31-07-2014, 13:13
magnets's Avatar
magnets magnets is offline
Originally Posted by evanperryg View Post
Under what conditions did you perform FEA? Wheel "strength" can be measured in different ways.
You can measure how much weight it can hold. For an aluminum wheel like this, that's not going to be a problem for just carrying around a robot.
You will have to worry about shock loading, as a rocking/tipping robot can come crashing down quickly. If the wheel is used for a long time fatigue can come into play too.
You could also measure how much torque it can withstand before either the hex strips out or the spokes snap off.
You also have to worry about what happens if you suddenly run the wheel into a wall at high speeds getting pushed by a robot. If there's a step in the field (like in 04), you can really destroy a wheel this way.
There also the issue of side loads. Imagine holding the wheel's axle still, the pushing on the rim on the wheel, parallel to the shaft, to try to rotate the wheel on an axis that isn't its axis of rotation.
As for machining, you could either 3d print aluminum with laser sintering (extremely expensive) or you could manufacture each of the spoke plates and weld it into place.
I agree, it's not practical (a VersaWheel weighs less), but it is a cool looking part.
On the topic of cool wheels, 118's 2012 wheel was very cool looking too.
Unread 31-07-2014, 13:24
AdamHeard's Avatar
Lead Mentor
Andymark designs their wheels to be heavier because they need to be robust. They need to account for teams doing odd and out of spec things with them.
Assuming this is nominally a 4x1" wheel, this isn't an un-achievable weight with traditional machining methods.
Our 4x1" wheels we ran on "Black Knight" (Downloadable in sig) were about .25 lbs and could've been pocketed more. I know 254 runs wheels in this ballpark or lighter.
Unread 31-07-2014, 15:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Pics of FEA tests or ban!
Unread 31-07-2014, 18:25
evanperryg's Avatar
AKA: Evan Grove
The goal really wasn't for this thing to be "logical" or "practical," It was an idea that popped into my mind, largely inspired by spoked car wheels. They might never see competition, but they certainly would be a cool demonstration of what a multi-axis mill (or whatever else you could use to make these) is capable of.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 31-07-2014, 18:38
kevincrispie's Avatar
kevincrispie kevincrispie is offline
FRC #0971 (Spartan Robotics)
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
As far as I know, these wheels aren't make from a multi-axis mill. From the Truespoke website, where the picture you linked is from, it seems as if these particular wheels are put together by hand. The spokes, rim, and hub would all be separate parts. Regardless, these wheels are excellent craftsmanship and it can certainly be a good CAD project to create a design inspired off of these.
I am curious about the cost evaluation on the part. When you say that the 8 spoke design is significantly cheaper, did you get somebody to do an evaluation, or is this your own estimate?
"If you want to build robots, you're going to have to break a few small appliances"
Unread 19-08-2014, 14:21
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Hmmm. Looks a lot like this one. Impractical for conventional machining techniques. Great for 3D printing. Mine has the spokes arranged more in the classic spoked wheel pattern, which relies on spokes in tension for torsional rigidity. The design in the OP relies strictly on the bending stiffness of the spokes for torsional strength.
Note that this one has the same internal structure, but adds fairings that protect the spokes.
So, all you folks with 3D printers, print some up, test them out, and let us know the results.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
