Go to Post No, Dave says "that's PUMP" - dlavery [more]
Unread 31-07-2014, 22:40
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
pic: 3216 Swerve
Unread 31-07-2014, 22:42
ekapalka's Avatar
FRC #3216
Re: pic: 3216 Swerve
Another angle
Unread 01-08-2014, 09:42
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
I'd double check some of the VP kits, I distinctly remember there being an extended output shaft add on/kit.
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 01-08-2014, 10:43
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Have you thought about utilizing the tapped hole in the end of the VP output shafts? you could either use a 1/4-20 screw and somehow clamp on the sensor shaft that way, or you could drill it out, and put a tapped setscrew hole in the side of the shaft to lock onto the sensor shaft.
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 01-08-2014, 16:00
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Using the tapped hole on the end of the shaft is a good idea, it's worked for us in the past but not exactly as you describe it. In 2013 our shooter wheels were on two vp gearboxes and we needed to attach encoders to each for control. Our solution was to thread in a bolt with the head removed and couple this to the encoder via a short piece of surgical tubing held on by zip ties.
-Adrian
Unread 01-08-2014, 17:01
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
A tension system for the belts. It could be very difficult to assemble without something. Also you might want to look into sliverthin bearings http://www.silverthin.com/ They are a few X more expensive then the ones you used but can be worth it with the weight and size.
Unread 01-08-2014, 19:50
ekapalka's Avatar
FRC #3216
The problem I'm facing is that the absolute encoder/potentiometer needs to rotate with the module 1:1. The only solution I have been able to come up with is to have a separate series of gears originating from the VersaPlanetary at the same ratio as the belts, but I've run into found a few issues with that (stemming from the short VersaPlanetary output and/or vex and andymark gear thickness). I'm trying to keep as much as possible contained within the plates that make up the body of the module (and I'm trying to go no higher than 1.25" from one to the other). I'm sure there are a lot of ways around this I haven't thought of... [EDIT] I could use a motor other than the BAG motor with a lower RPM and have 1:1 pulleys turning the module. Then mount the sensor right on top of the VersaPlanetary
Hmm... I was told that properly spaced pulleys wouldn't require a tension system :/ I guess I'll get looking into how that's done. As for the bearings, do you have a ballpark estimate for the prices they offer? I like the weight and look of them, but the bearings I've found are only $19.
Even if my team actually decides to go through with this and build it (which I'm almost certain they won't), we're probably not going to use it in competition because of the technical problems that undoubtedly go along with swerve.
I was wondering if anyone had any thoughts about holding the pivot yoke to the rotating module using screws (8xM5). Its not something I've seen done, so there's probably a reason...
Unread 01-08-2014, 20:15
Andrew Lawrence
Posts: n/a
[edited]
Last edited by Andrew Lawrence : 01-08-2014 at 20:55. Reason: Misleading information
Unread 01-08-2014, 20:22
Jared's Avatar
Jared Jared is offline
If you can get the center to center distance correctly, like if you're doing it on a mill/CNC, you won't need tensioning.
Silverthin bearings are nice, but really pricey. If you've got the room for thicker ones, you could save some money. I know 1640 uses a large ball bearing, a large thrust bearing, and a bushing on top.
Unread 01-08-2014, 21:37
ekapalka's Avatar
FRC #3216
Originally Posted by Andrew Lawrence View Post
If you know the ratio between the output shaft of the VersaPlanetary and the rotation of the module you can compensate for a non 1:1 ratio in the code.
Yeah but that means that the modules have to be perfectly aligned every time its turned on or the wheels have to be in the same orientation when the robot is turned on as when it was turned off (and the last angle value would have to be persistently saved so it remains between reboots). I'm also the programmer, so I'm trying to avoid having to do that
Unread 02-08-2014, 04:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Okay, so I have a few questions and suggestions for you:
1. Why do you need the encoder to have a 1:1 ratio? You can still tell if the wheels are out of alignment, and realistically it would be better to just have some way of keeping them in line for calibration mechanically, with something such as surgical tubing between the axis of the wheels. I think 1640 had something on keeping modules in line on their Swerve Central site.
2. Is this a shifting design? If not, you are almost certainly using way too many gears and pulleys. You can probably cull almost every gear by using a sprocket reduction to the wheel. For example, using a 10t #25 sprocket on the shaft with the bevel gear and a 42t #25 sprocket on the 4" wheel (I assume it's 4 inches) will net you around 18fps adjusted, and you can lower that via a single pulley reduction going from CIM to turning module. Less gears means cheaper and less complex.
3. Mount the encoder to the end of the versaplanetary and save yourself some time. I think Western Digital sells 10mm shaft absolute encoders, so you can drill out the 1/4"-20 tap on the end of the shaft and add a set screw.
4. Is the center of the turning module, looking down from the top, equidistant from both of the sides that mount the swerve module? That way you don't need to worry about module orientation when putting it on a chassis, and programming becomes a bit easier.
5. How thick are the top and bottom plates, and why? Just curious.
6. You don't need to use roller bearings for turning the module. Bushings can support tons of weight at low rpms, which you are running at anyway. Even a thick plastic bushing on the top plate can provide a strong interface. Ball bearings will work fine, but I think a flanged bushing would work better so you don't need to depend on a press fit or put a lot of axial load on ball bearings.
7. What bevel// miter gears are you running? I've never found a good place to get them cheaply at other then Vex, and the Vex bevel gears are pretty large.
8. How much does this weigh? If it weighs more than 8-9lbs, you need to rethink weight distribution. It's definitely possible to get it lower than that.
Overall, it looks very slick. I like the bearing mount on the top of the module. I hope your team can build a swerve!
Unread 02-08-2014, 23:25
ekapalka's Avatar
FRC #3216
The encoder I'm intending to use is a USDigital MA3 absolute magnetic shaft encoder (not the incremental encoder used to measure speed). Preferably, the robot should be ready to go as soon as its turned on with little or no calibration (which I guess might be unrealistic, but I'd still like to make the code relatively straightforward). I'm not sure what you mean by a mechanical solution... something to align the wheels with human assistance, or something else?
Its not a shifting design. The max free speed is supposedly around 16.5fps. Aside from the weight difference, I'm not sure why I chose to go with belts. I chose the particular gears I'm using to take up the least space. I tried with various other ratios, but the one I chose allowed me to make the plates that hold the module together significantly smaller by having the gears be positioned close around the bearing. Like this.
I'm currently re-designing the body, but the version shown in the pictures is equidistant. Unintentionally, though - I'll make sure to do it this way in the final design as well.
0.25in, because its the thickness of the WCP SS and DS gearboxes. Additionally, its the thickness of most Vex/AndyMark bearings (minus the flange), to there's a lot of nice flush edges.
Vex 15t Bevel gear. I haven't found a problem with them other than the fact that they're 3/8in hex and most everything else is .5in hex, so the shaft going to it has to be milled from one to the other and it needs to have a set screw put in it...
With quite a bit of hardware missing, it weighs 10.25lbs, but once I add the missing hardware, cut out relief pockets, and (maybe) trade out one of the heavy bearings for a bushing, it should be around 9-10lbs. Its not for competition, so I'll be satisfied with anything under 11lbs.
Thank you for your input!
Unread 03-08-2014, 22:18
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
What is the use of all the extra material below the wheels axial?
The module looks supper tall. This will give you a higher center of gravity decreasing performance.
The co-axil looks complex.
I don't see the need for the gears. Most teams that i have seen that don't use shifting go directly from the cim to the co-axie with a timing belt and the majority of reduction in the yoke. Removing the gears will give you a higher mechanical efficiency and less moving parts in the high speed parts of the transmission.
The top of the modules bearing can definitely be using a bushing saving weight and cost. I personal like the thrust bearings riding on the bearing like 1640.
The plates look complex with a lot of milling operations on places that are not holding weight. Mainly where the bearings are why is this? It would be lighter and cheaper not to have to get plates that thick and mill them down even if the beaing plate are not smooth.
Over all a great start
Unread 05-08-2014, 14:07
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
FRC #2517 (the green wrenches)
Team Role: CAD
kk052 can only hope to improve
screws can be inacuate, also how are you planning on putting a pully on if you cant change the center distance in any way?
FRC TEAM 2517 The Green Wrenches
2012 Autodesk Oregon regional
Chairman's award, Entrepreneurship award, Pit safety award
2013 central Washington regional
Imagery award, Pit safety award
2014 we won something but i forgot
-"the CAD is only accurate if you machine it accurate!!!"
--"its not working because your doing it wrong!!!"
---"is it really ok to put an acronym in an acronym?" (FIRST)RC?
Unread 05-08-2014, 14:15
Joining the 900 Meme Team
FRC #0079
You could always use an incremental encoder and an index (limit switch of some sort) as a zero.
