Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 01-08-2014, 21:59
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
FRC #2169 (KING TeC)
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
Andymark Churros
Hi, our team is prototyping a wcd this summer, and we have an excess of andymark Churro extrusion (http://www.andymark.com/product-p/am-2595.htm) and plan to use it as a live axle. Does anyone have experience using this material? If so, is it strong enough?
Unread 01-08-2014, 22:05
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Andymark Churros
If you are just building a drivebase they might work.
But I have never heard it being used as an axle before and I am skeptical that it would be strong enough for the job. Most hex axles don't have a hole going all the way through it, as well as a dimple on every side of the outside edge.
If you could I would suggest you use something else.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 01-08-2014, 22:11
Michael Hill's Avatar
The churros are 6063 aluminum. Hex shaft from Vex is 7075-T6 (black anodized for superior performance, of course). I'd say there's not a chance they hold up, but that's just my speculation.
Unread 01-08-2014, 22:13
I wouldn't even use regular 6061 hex shaft for this application, let alone the 6063 churros. Bad experiences with bending and snapped axles. (Just ask 2791, among others).
Unread 01-08-2014, 22:56
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Excess material you say? Build it and see what it takes to break it! You will learn more by testing the churro extrusions to the limit than you will by using the "right" material from the start. If they fail, you can replace them with stronger shafts later.
I'm a big fan of destructive testing. It's fun and educational. Every now and then you find something that you were sure wouldn't survive, but ends up working and saving you time/money/weight.
Unread 01-08-2014, 23:00
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
I agree if you have it test it. Also since it already has the hole through it you can use that to put a bolt and washer on each end to hold the shaft in place, either by putting a bolt all the way through, or by tapping each end.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 02-08-2014, 00:02
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Sure, it's a 'learning experience" and you can use it, but I doubt it will last long. simple directional changes(with 120lb worth of robot) would probably be enough to twist them. The profile is probably the WORST for handling torsion loads, it's missing material from where it's needed the most for this application.
If you do use it make sure you have some solid hex(as high a grade as you can find) to have ready to go.
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
Unread 02-08-2014, 01:07
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Spacer, yes. Live axle, no.
We tried this on this year's robot and it twisted it into a twizzler shape. I recommend using solid hex aluminum for your application. 6061 might suffice if the load isn't too high. We ended up using 2024 solid aluminum hex. That worked well for us.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 02-08-2014, 04:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
6061 1/2" hex will not bend in drivetrain applications, as we had to substitute a few 7075 axles for 6061 during build and they held up through 2 competitions. This might have been due to to other drivetriain problems that stopped us from moving too much though.
6063 is considerably weaker than 6061, so I would be wary of using it. For prototyping, it might be fine, but it would be much safer to just purchase some 1/2" 7075 hex stock from Online Metals instead.
EDIT: This would be in our team's experience only.
Unread 02-08-2014, 04:52
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by asid61 View Post
6061 1/2" hex will not bend in drivetrain applications, as we had to substitute a few 7075 axles for 6061 during build and they held up through 2 competitions. This might have been due to toher drivetriain problems that stopped us from moving too much though.
I'm not totally following. Just to clarify, your saying that 6061 1/2" hex would be more than fine in a drivetrain application such as a WCD (or other drivetrain using live axle)?
R.C.
MadTown Robotics Team 1323
Unread 02-08-2014, 04:56
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I'm sorry, it did not bend for us. Our drivetrain didn't see very heavy use this year, and that might be why it worked fine. Teams like 254 probably would need the extra durability afforded by 7075, but for a prototype low-load drivetrain 6061 should be fine.
Unread 02-08-2014, 05:17
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
Thumbs down Re: Andymark Churros
http://www.chiefdelphi.com/forums/sh...0&postcount=16
You stated they would bend here. Please give us accurate information. Our students use chief delphi to help them make decisions where others have more experience. If they see contradictory posts like yours then they and many others will be confused. Please edit your post.
Chow Out
Unread 02-08-2014, 10:24
Generator of Entropy
FRC #2973 (The Mad Rockers)
Originally Posted by MechEng83 View Post
...twisted it into a twizzler shape.
Churros and twizzlers, this thread is making me hungry.
Unread 02-08-2014, 13:48
DampRobot's Avatar
Physics Major
AKA: Roger Romani
We've used 1/2" 6061 axles in a drive before, however, they were supported by bearings on both sides, and we were running 6" wheels instead of 4" wheels. We didn't see it twist up at all. YMMV.
Of course, with the 7075 VP stuff so cheap, easy, machinable, and strong, I would never order 6061 hex for drive shafts. They almost never come with the right dimensional tolerance on the OD anyway, whereas the VP stuff is good to go out of the box. So really, why use 6061?
OP, if you're fine with wrecking some material, go for the Churro tube. Otherwise, buy the real stuff from Vex and profit. I've seen Churro tube twisted up ("into a twizzler shape") multiple times at regionals, and I wouldn't bet much on it holding up.
-Plutarch
Unread 02-08-2014, 22:43
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We used some Churro for our collector on this years bot with no issues...
You can't really see it in that picture because the PVC spacers cover it, but it extends across the entire length of the collector, drives the wheels, and is only supported on the ends. Overall we've been very happy with it, especially because it's light and rigid (and because we already had some around when VEXPro ran out of their long hex stock during build season).
Now granted this application probably undergoes far less force than something like a drive system would, so keep that in mind when planning its use.
