Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 24-02-2003, 21:37
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
its faster to cut off the curve into 90 degree sections than to make a wide arc around to the ramp. If you use dead reckoning to make the same curve that you would if you followed the tape, what's the point?
I agree that your code is simpler, but not faster, at least not for our bot.
We also were planning on putting the gyro in so it accelerates when it hits the ramp, but never got around to it. Yet another thing to be done at regionals.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 24-02-2003, 21:45
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Originally posted by Stephen Kowski
dead reckoning - too inconsistent put a few bins in the way and while your robot thinks it is going straight up the ramp it is now going off at an angle. You get a battery that has a higher or lower charge the motors will act differently. just too inconsistent
Yep. This is why we opted for a robot that follows the line. We're using 5 sensors this year ... they're all lined up on the front of TOBOR VI. It's pretty nifty! I believe we have a dead reckoning program written just in case we need to use it, but I'm not sure.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Alex you are tired or really not with it. Where did you get 393? Actually I am not doing it like that at all. This is how I am doing it.
POT = (POT*127)/254 'Gives me a perportional number between 0 and 127
if POT<63 then
Left_drive = 127 + POT
Right_drive = 125 'Locks wheel
else
Left_drive = 125 'Locks wheel
Right_drive = 127 + (254 + POT)
endif
I think this is right but it is late and I can't find the source I wrote earilier.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
f22flyboy's Avatar
      _______________
     A              B
              ____
           _|       |_
       _|               |_
      A                    B
maybe this will help explain what I'm trying to say. The distance from point A to point B is shorter in 1 than in 2
Edit- trying to get the lines right
Edit-close enough
Team 540 Forums
Unread 24-02-2003, 22:24
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
First of all, we are not travelling in a straight line, we must travel forward, turn 90 degrees right, go forward, then travel 90 degrees right again.
Second, the distance may or may not be greater, that's not the point. When you don't do an arc, you have to stop, turn, then move, and then you have to accelerate back up to your top speed. When you do an arc, you apply power to the motors continously, and thus you aren't jerky and you save some speed.
Now, it may be different depending on drive train issues, and robots, but it's not as simple as "the shortest distance between two points is a straight line" (unless you are 179 and you can just climb over the rail, thus going in a straight line! )
Stephen
Unread 24-02-2003, 22:31
f22flyboy's Avatar
I'm not advocating an 0 radius turn. There is some arc to the turns, but they would still be considered a sharp 90. Hitting the front lip of the ramp at top speed in our current configuration would be catistrophic, so I say once again: It is a decision that needs to be made in each team, and is dependant on your individual robot and strategy.
I still maintain that cutting of the curve in dead reckoning is faster for most bots that I have seen, but only time will tell.
Team 540 Forums
Unread 24-02-2003, 22:38
Willum's Avatar
Willum Willum is offline
#0871 (Robotechs)
Willum is an unknown quantity at this point
Send a message via AIM to Willum
We have both a curve and a 90-90 dead reck going. I believe the 90-90 program is faster, but sometimes there's a good reason behind using an arc. but i've said too much.
Unread 24-02-2003, 22:39
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
code:--------------------------------------------------------------------------------
if POT<63 then
else
endif
Remember ours didn't work earlier, this fixes it, and 127+256=393 (i forgot that 254 thing) this inverses it correctly, the one we had was backwards (close to 127 was sharper turn than 254).
---Lightning Robotics!---
Unread 24-02-2003, 22:40
Duke 13370's Avatar
C is for cookie...
the big advantage to an arc is that is would be variable, and not limited by the line. (you could make it variable with the 90-90 thing, but this uses less variables)
Unread 24-02-2003, 22:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
the fastest way isnt a 90/90 turn. The fastest is to back up at an angle and then go straight up the ramp with a very minor correction. We have multiple modes of autonomy, using Gyros, Line followers, and dead reckoning. We are using 5 sensors in a line to detect the line.
This is our config:
this works rather nicely
[edit] ummm it didnt like the way i spaced my little lines, lemme figure out a way to fix em.
Basically, there are two sensors on the far ends and then a group of 3 in the middle.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 24-02-2003, 23:40
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
We are. I wish we had five sensors to play with, though. We're only using three. We also have some d. r. programs.
Sensors are cool!
Look for our bot doing some cool antics at the Seattle regional!
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 24-02-2003, 23:49
Cory's Avatar
AKA: Cory McBride
Oh yeah, we have a pretty cool odometer too. Ill post some pictures in a few days when i upload a whole bunch of our bot.
Cory
2001-2004: Team 100
Unread 25-02-2003, 00:18
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
We were going to do line-following until our programmer found a better way to use the sensors to count wheel revolutions. Look for some very cool autonomous action from 360 at the Seattle Regional.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 25-02-2003, 08:51
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
we aren't line following...
but then again we aren't exactly dead reckoning either....
sensors galore on our robot... 16 digital inputs and 3 analog! (gee that was fun to wire )
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 25-02-2003, 10:29
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Is anyone else out there using encoders? I heard one person talk about odometry.
We got some gray scale mechanical encoders (Grayhill) and are using them on our back wheels.
We do the back up then forward at an angle strategy.
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
