Go to Post I learned about how FIRST really is about so much more than a robot competition, it is about team building and the individual. - Adel Hodiwala [more]
Unread 04-08-2014, 12:01
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
pic: 4WD Concept
Unread 04-08-2014, 12:02
AdamHeard's Avatar
Lead Mentor
Re: pic: 4WD Concept
It would make sense to direct drive the traction wheels with the gearbox.
Unread 04-08-2014, 12:06
Professional Stat Padder
Personally, I would run a 6WD here. The 4WD worked for Winnovation because of the game and the fact that their driver is magic. For most drivers, this kind of drive can be harder to maneuver and score with, and if the game were something more precise (like 2010-2012), it might not have worked as effectively.
Regardless, running a WCD, you should probably direct drive one of the wheels (probably the traction one), then chain/belt in the omnis.
(2015-Present)
Unread 04-08-2014, 12:09
Chris is me's Avatar
AKA: Pinecone
First thing I would be tempted to suggest is direct driving the back wheel. You do have to make an asymmetrical gearbox to get everything to package nicely but it saves you a few hex bearings and a shaft in weight. The other benefit of this is that your traction wheel will always be powered even in the event of chain failure, and more of your robot's weight is over the traction wheels.
The solid bearing blocks inside the tube like that really shorten the distance between your two bearings, resulting in a less well supported shaft. I would consider a tensioner free belt drive (no bearing blocks) or some other kind of bearing block like the VersaBlock for adequate shaft support.
If you're willing to step up to 3" tube and shim your bearings out a little you could pop a 24T 15mm wide pulley in the tube to power your omni. This is how we ran a 4WD in 2013. A 27T 9mm wide belt might also work.
Looks good, these are fairly nitpicky suggestions and it largely comes down to preference.
4WDs like this are indeed an option, just know what the trade off is. You're sacrificing a good deal of traction and a centered turning point for better performance against T-bones and a turning point about one end of the robot. T-Bones were a big concern this year with all the defense but they are not always a big problem. It's not inherently harder to drive than a 6WD, just different.
Unread 04-08-2014, 12:16
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
This drivetrain was brilliant pretty much for the sole reason that Winnovation's driver is magical. I don't know if any other team could pull it off.
Unread 04-08-2014, 12:19
I've driven a 4WD myself (just like this) and it just takes a bit of practice. It is different, but it doesn't give a disadvantage in my mind. I've programmed plenty a successful autonomous program for this style drive. Magic drivers help, but this drive doesn't require magic.
I'll look into the possibility of remaking the gearbox to direct drive the traction wheel, that makes a good bit of sense.
My current mentor for the summer is interested in making a tensioner-free drive as a prototype to see how well it performs and how easy the maintenance would be on it. I've also never run chain-in-tube before either and I'd be interested to explore that option as well.
If the open field disappears and I need something more accurate I would obviously consider the potential of another style of drive. I just want to experiment with the simplest possible drives for a given problem/scenario. Say another 2013 or 2014 style game returns in the near future.
John Fogarty
Unread 04-08-2014, 12:54
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Additionally, if the game requires you to sit a few seconds to score with defense (such as 06* and 07), you can pretty easily be spun around. We tried to take advantage of that against 1625 at Midwest but it takes them just a split second to get the truss pass off.
*I believe 1625 ran a similar drive in 2006 but added a drop down breaks for the championship to prevent this.
Unread 04-08-2014, 13:04
Olin class of 2019
We ran a tensioner free belt drive this year - indeed , we didn't even have bearing blocks - just sat flanged bearings in the tube wall. It worked fine, but we did have to add idlers to the back belts to compensate for a belt-sizing issue.
In the future we'll probably run ansi-25 chain and sliding idlers (sprockets with shafts that sit in a milled slot).
Unread 04-08-2014, 13:29
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
As the main mentor who helped with the design of last years drive train, here's what I have to say.
I really like how easy this thing is to build and it isn't super hard to drive in my opinion (although I have driven some difficult robots in my day). I would recommend trying to keep your center of gravity shifted a little bit back, this is another good reason to direct drive the rear axle.
As far as pushing goes, I was really surprised at how much grip the omnis actually have. Also, because most 6wd only have 4 wheels on the ground at a time, the 4wd can go toe-to-toe with many 6wd's in a pushing match.
I really like 6 CIMs on the drive. I have looked a lot at the numbers, which seem to say it doesn't make a huge difference. But I think it's worth it.
These are just my opinions, feel free to prove me wrong.
"More power 'till it breaks or you win."
- Keith Carey
Unread 04-08-2014, 13:45
AdamHeard's Avatar
Lead Mentor
The bearings are spaced plenty far apart. Most teams that run 2 piece blocks (like 254) are counter boring the bearings anyway, yielding the same bearing spacing (or only .125" more).
The rigidity and concentrically advantage over most 2 piece blocks (as most 2 piece blocks don't adequately align to each other) is nice as well.
Unread 04-08-2014, 13:52
magnets's Avatar
magnets magnets is offline
You don't even need bearing blocks-- The robonauts didn't use any this year, they just pressed their bearings straight into the frame rail.
As time goes on, our drives get more and more interesting. We started with cantilevered wheels, then aluminum sprockets and shafts, and now, we're starting to ditch the bearing blocks.
Unread 04-08-2014, 14:04
In my research of the 118 press-bearing system they still had some method of tensioning the chain if needed. I'm not a huge mechanical guy. My background is mainly in electrical and programming, but I've started learning this stuff to help my team design better. How would one make sure the chain is tensioned properly without the use of tensioner blocks...I would assume some pretty accurate calculations have to be made.
John Fogarty
Unread 04-08-2014, 14:52
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This past year we used this calculator produced by 1640 to space our wheels apart using 35 chain. We CNCed our drive plates, assembled, and haven't touched the chain since. It has stretched a little over the course of a long season with 6 events but it still runs great. We had a plan for tensioning if needed using a round piece of delrin with an off center drilled hole for mounting so we could rotate the piece around until proper tension was re-achieved and tighten the mounting bolt.
However I would assume since your single chain run is nearly the entire length of the robot (assuming you direct drive the traction wheel) the chain slack would be more noticeable compared to teams running an 8wd with C-C around 8in as you have more links to stretch out. A bearing block system might be more appropriate but you can use the chain calculator to help in design so your bearing block starts where you need it and tension from there.
1058 PVC Pirates 2016 - xxxx
Unread 04-08-2014, 15:10
AdamHeard's Avatar
Lead Mentor
For 1:1 ratios, the math becomes dead simple. For Chain, the c-c must be a multiple of the chain pitch (.25 for #25, .375 for #35). It can be a multiple of the half pitch if you're willing to use a half link.
For belt, it must be a multiple of the half pitch (BUT don't assume all belts are sold!). Required toothcount on the belt (B) is;
B = T + 2*C-C/P
T = Pulley toothcount
C-C = Center to center (in same units as P!!!)
P = Pitch (in same units as C-C).
For both chain and belt there are arguments for adding a fudge factor to the c-c. I generally don't for shorter distances, but will more commonly do so for longer distances (or for small pitch belts).
Unread 04-08-2014, 17:55
Kingland093 Kingland093 is offline
FRC #4215 (Trinity Tritons)
Kingland093 will become famous soon enough
My team used 4WD set up like yours last year, and to quote our driver, "it turned like an old lady". It was poor in situations with heavy defense (glad we didn't do it this year). If you're going to go 4WD, I'd suggest to go 4 omnis or even mecanum. Other than that, I'd recommend sticking with 6WD
McGill University Mechanical Engineering Class of 2020
FRC 4215: Trinity Tritons 2013-2016 (Programmer, Strategy, Driver)
2015 MRI Winner (with 3130, 2052, and 2531)
2015 MN State Championship Winner (with 2512 & 3130)
2015 Double DECC'er Winner (with 3130 & 525)
2015 Northern Lights Winner (with 3130 & 525)
