Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Unread 04-08-2014, 18:04
Chris is me's Avatar
AKA: Pinecone
Re: pic: 4WD Concept
The bearings are spaced plenty far apart. Most teams that run 2 piece blocks (like 254) are counter boring the bearings anyway, yielding the same bearing spacing (or only .125" more).
The rigidity and concentrically advantage over most 2 piece blocks (as most 2 piece blocks don't adequately align to each other) is nice as well.
I didn't realize these were COTS bearing blocks when I made the post, which increases my confidence in them a lot.
That said, since the bearings are hex, I think there's at least an argument to be made to be paranoid about how heavily the bearings are loaded. This year, our bearings were spaced 1.75" apart (just happened to be, we didn't design around this problem) and we had no hex bearing failures. Other teams with bearings 1" apart or less had problems with some hex bearings exploding under regular drivetrain loads. Hopefully the manufacturing problems with hex bearings are cleared up for 2015 and we don't have to think about out of spec COTS parts when designing, but if you want to be paranoid it's something to consider.
An easier solution than going with a different bearing block would be to just turn that part of the shaft round and use round bearings (less prone to failure), or better yet use a dead axle bearing block (also available from 221) since your chain is on the same side as the wheels. But this might not even be a problem next year, so...
Unread 04-08-2014, 18:13
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Originally Posted by Kingland093 View Post
My team used 4WD set up like yours last year, and to quote our driver, "it turned like an old lady". It was poor in situations with heavy defense (glad we didn't do it this year). If you're going to go 4WD, I'd suggest to go 4 omnis or even mecanum. Other than that, I'd recommend sticking with 6WD
What Wheels were you using and where was you CG located?
We had no problems whatsoever with turning.
"More power 'till it breaks or you win."
- Keith Carey
Unread 04-08-2014, 23:25
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Our team ran something similar to this in 2010 (by accident....) but it actually turned out working very well. It allowed us to pivot more around the ball that we had possession of in the front of our robot. We had one of the best acquisition units that year at FLR and we could keep control of the ball in almost any situation.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 05-08-2014, 07:10
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
I honestly don't know why this would occur. The turning scrub of this drive-train would be noticeably less than that of a 6WD.
These bearing blocks though designed to work similarly to 221 systems blocks are in fact somewhat custom. 4451 and I CAD up these versions ourselves and then CNC milled them ourselves. They used this version on their 2014 6WD drive-train without issue. When you say the bearings were spaced (distance) apart, are you referring to the distance between the two bearings inside the block?
John Fogarty
Unread 05-08-2014, 12:49
AKA: Pinecone
I was referring to the distance between the bearings, as that determines how well the shaft is supported and how loaded the outer bearing is, but it seems like that's not a very big issue, especially if you've successfully done it before.
Unread 06-08-2014, 12:42
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
...snip...
It would depend on the CG location. Let't take a couple of extremes and then this might make sense.
1. If the CG is really close to being over the top of the omin-end, then turning can be difficult as the traction wheels act a bit like a rudder.
2. If the CG is nearly directly over the top of the traction wheels, then there will be very little lateral from the omnis which can make it difficult to drive straight.
1 can be a very bothersome configuration as you would get pushed around easy without the benefits of being really maneuverable.
2 can be difficult to drive in a straight line, but should be very very maneuverable.
There is a white paper by Chris Hibner that you can use to set up a calculator and play around with values.
Unread 06-08-2014, 20:33
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
In my research of the 118 press-bearing system they still had some method of tensioning the chain if needed. I'm not a huge mechanical guy. My background is mainly in electrical and programming, but I've started learning this stuff to help my team design better. How would one make sure the chain is tensioned properly without the use of tensioner blocks...I would assume some pretty accurate calculations have to be made.
Talking to 118 at IRI about their 2013 drive, they had no chain tensioners, they relied on the walls of the tube to keep from throwing chain once it stretched out. IIRC they used custom 17T sprockets like the 221 robotics systems ones, they are essentially two sprockets on one hub.
Because you are only running one chain, you could use regular 17T sprockets inside the tube and they should fit fine (This would also make it so your wheels arent cantilevered so far, which is important because with only 4 wheels, each wheel is taking a lot of weight). A chain run that long though may not be as forgiving in terms of stretching, but unless you are in a district model I don't think you will play enough matches for it to matter.
As for bearing blocks, you are probably fine without them, but if you can get something COTS like the VexPro ones I definitely would. Even if the spacing between bearings isnt an issue, what you also have to look at is the support on the outside race of the bearing. Sheet metal teams (like 971) often times beef up areas around bearings with something as simple as an extra bit of sheet riveted on just so there is a thicker face for the bearing to sit on. This may not be critical, but with only 4 wheels taking the whole weight, I would play it safe.
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
Unread 06-08-2014, 21:18
Kingland093 Kingland093 is offline
FRC #4215 (Trinity Tritons)
Kingland093 will become famous soon enough
2 KOP traction wheels and 2 omnis
As for CG, I'm not really sure as I'm not on the Build team, but I think it was in the middle of the robot, and not very low down, but it wasn't tipsy unless you actually tried to flip it over
McGill University Mechanical Engineering Class of 2020
FRC 4215: Trinity Tritons 2013-2016 (Programmer, Strategy, Driver)
2015 MRI Winner (with 3130, 2052, and 2531)
2015 MN State Championship Winner (with 2512 & 3130)
2015 Double DECC'er Winner (with 3130 & 525)
2015 Northern Lights Winner (with 3130 & 525)
Unread 07-08-2014, 00:57
Bryan1625's Avatar
Bryan1625 Bryan1625 is offline
Team Role: Driver
Bryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really nice
As much as id like to admit im magic i hate to say its actually just practice. We had the gearbox direct driven to the traction wheels which seemed to be pretty effective.
Unread 07-08-2014, 09:00
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Nope. Magic. CD is agreed .
Unread 07-08-2014, 09:48
Bryan1625's Avatar
Team Role: Driver
Well much appreciated but we really had no problems with turning or tbones which helped a lot in matches against heavy defense.
Unread 07-08-2014, 11:58
Sam_Mills's Avatar
FRC #4965 (FIRE)
This times x1000. Between 2010 and 2013 a certain unnamed MAR team built some of the worst drivetrains one could conceive, but their drive team was so good (so well practiced) that it didn't matter, and they had multiple event wins as well as IRI appearances.
ewcp 2013-current
Unread 07-08-2014, 23:19
Bryan1625's Avatar
Team Role: Driver
Well I wouldn't consider this one of the worst drive trains. Done right it can be a very competitive drive train. With practice you can out manuver a swerve and have more pushing power then a low gear on an 8 wheel or 6 wheel tank. It just takes trial and error on which wheels you want to use and the driver and the set up of the gear box
Unread 08-08-2014, 01:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
For 1:1 ratios, the math becomes dead simple. For Chain, the c-c must be a multiple of the chain pitch (.25 for #25, .375 for #35). It can be a multiple of the half pitch if you're willing to use a half link.
For belt, it must be a multiple of the half pitch (BUT don't assume all belts are sold!). Required toothcount on the belt (B) is;
B = T + 2*C-C/P
T = Pulley toothcount
C-C = Center to center (in same units as P!!!)
P = Pitch (in same units as C-C).
For both chain and belt there are arguments for adding a fudge factor to the c-c. I generally don't for shorter distances, but will more commonly do so for longer distances (or for small pitch belts).
If you have multiple sizes or want to save time, you can just use a chain length calculator: https://www.rbracing-rsr.com/chainlength.html
Unread 09-08-2014, 19:19
Sam_Mills's Avatar
FRC #4965 (FIRE)
By no means do I think this is a bad drivetrain setup, I was only trying to assert that even if it was, any negative aspects can be mitigated with practice to the point where practice is arguably the most important thing. I really like how hard it is to lock this setup in a friction pin, as well as how light weight it is.
I don't really understand how it is supposed to be able to push better than a 6 or 8 wheel tank though, considering that both robots are allowed the same motors, but one has more torque and a higher CoF with the floor.
Edit: (not that pushing is necessarily important)
ewcp 2013-current
