Go to Post Fancy that, better robots winning matches... - DampRobot [more]
Unread 04-08-2014, 22:57
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Arduino + CRIO
How can I get an arduino and a crio to communicate with each other. My goal is for the arduino to send information to the crio in some way and the crio will use the data values sent and perform tasks with the robot that correspond with the data sent. Is this able to be done through network tables or how could it be done? Thanks!
Unread 05-08-2014, 07:32
Gdeaver Gdeaver is online now
FRC #1640
Re: Arduino + CRIO
The Arduino can be an I2C slave. Use serial or the lan UDP. Lan solution needs a lan board.
Unread 05-08-2014, 10:12
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Arduino + CRIO
I've personally never tried it. However, I know that it is possible. People use Arduino devices to control LED circuits controlled by the cRIO all the time.
Depending on what kind of information you want to send back to the cRIO I could potentially help you further. I do use Arduino a lot in my University lab classes so I'm familiar with almost all aspects of it. I2C is the first thing that would come to mind in terms of communication, and I think the LAN board solution...might work. I'll be testing both once I get the RoboRIO for future knowledge on that front as well.
John Fogarty
Unread 05-08-2014, 10:39
Joining the 900 Meme Team
FRC #0079
Re: Arduino + CRIO
The RoboRIO can also act as a USB host if I recall. I'd like to hear if that works.
Pretty please with LEDs on top?
Unread 05-08-2014, 10:58
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Arduino + CRIO
When we did LEDs in 2013 we just used a few DIO pins to send different combinations to IO pins on the arduino to run different light routines.
Unread 05-08-2014, 14:02
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Re: Arduino + CRIO
https://github.com/FRC-Team-4143/swerveneopixel
This sketch controls Adafruit neopixel leds over i2c. I2c is echoed over serial for debugging.
Crio code (in c++) is something like:
m_i2c = DigitalModule::GetInstance(1)->GetI2C(0x04 << 1);
RobotMap::m_i2c->Write(0x0, 50);
The first 0x0 is the command. The 50 is a parameter to the command in the sketch.
The i2c address is 0x4, but you have to shift it left on the Crio to write. That is the tricky part.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Last edited by RyanShoff : 05-08-2014 at 14:11. Reason: changed parameter to not get confused with address
Unread 05-08-2014, 14:27
Re: Arduino + CRIO
Originally Posted by RyanShoff View Post
The 7-bit i2c address is 0x4, but you have to shift it left on the Crio to write because the cRIO code uses 8-bit I2C addressing and you're performing a write which is LSB = 0. That is the tricky part.
Added some detail about addressing for anyone curious why what Ryan posted is true.
Unread 06-08-2014, 13:24
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Arduino + CRIO
Would love to hear from anyone who has set up an Arduino as an I2C slave and sent info back and forth with the cRIO.
We simply used a few DIO to toggle between preset LED patterns.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 07-08-2014, 16:15
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
Re: Arduino + CRIO
2013 our team used it. There's 2 things to look out for.
1. As people have already mentioned Arduino's i2c addressing hides the bottom bit, so you'll have slightly different addresses on the Arduino and CRIO
2. The round cable connecting the cRIO to the digital BO does not include the i2c connection, you'll need to use a ribbon cable.
Unread 08-08-2014, 09:43
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: Arduino + CRIO
Look at the LED.Java and Shooter_Lights.ino in are code from this year. We used it to control the lights on are arm.
Unread 13-08-2014, 09:11
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Arduino + CRIO
Mr. Lim,
This thread may help.
Mike
Unread 13-08-2014, 21:32
Jared's Avatar
Jared Jared is offline
Re: Arduino + CRIO
We've used a serial connection between the arduino and the cRIO for the past two years. It's much simpler to set up and debug than I2C.
You will need a level converter between the cRIO, which is RS-232(can be a wide range of voltages, IIRC the 8 slot cRIO was +10, -5), and the arduino which is TTL (normal 5V logic).
I used this (http://www.ebay.com/itm/MAX232-RS232...-/221022603873) level converter board to plug directly into the cRIO. The level converter was powered with the 5V supply on the arduino, and works very well.
If you're interested, I can probably dig up the code for this.
Unread 24-08-2014, 18:05
Richard100 Richard100 is offline
FRC #0836 (RoboBees)
Richard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to behold
Re: Arduino + CRIO
Jared - Interested in code and general wiring diagram, thanks.
