| Thread Tools |
Rating:
Display Modes |
1551 Off-Season Drive Train Project
So this past year we got a CnC sheet metal sponsor, and took some advantage of it this past season. In the off season, we wanted to go a little more hard core, and make a brand new drive base.
As we all know that Chief Delphi is an excellent place to get critique, we thought we'd post some pictures here and get opinions. Features include: 112" perimeter. Robust, etc, etc. Customizable as 8 x 4" wheels (shown) or 6 x 6" wheels. 1/8" drop center wheel(s)--both centers on the 8wd. 2 speed (5.5 fps, 18 fps). Plenty of space for upper mechanical mounts. Multiple battery placement options. Easy to assemble, easy to maintain (rivet nuts used extensively). A hair over 40 lbs, inclusive. Easy, robust bumper mounts (for reversible bumpers). Any/all comments/critiques/questions are welcome. Thanks! |
Re: 1551 Off-Season Drive Train Project
Two more pics!
Interesting concept.
Why did you decide to go with the octagon frame instead of a hexagon? Any reason the belly pan isn't incorporated into the front and back rails as one piece? (971 style, also extending the front and back rail flanges and adding an extra bend to them to make them more box like, again 971 style.) Do you change the gearbox when you switch from 4" to 6" wheels? Also what is the sheet thickness? |
COLIN LIKESyour critique -why five shaft??? yes it keeps the mass centers but robots are rarely 100% symmetrical. i see it as an added fail point, justin claims it make the tranny easier to change and gives you a 100% symmetrical start -atop the bumper mounting surface the hole pattern changes from outer to inner -how do i change a belt? -the belly pan should be notched so the tranny can slid back that length of the output shaft TRUST ME I MESSED UP! - I would add more mounting holes atop each "drive rail" so the hole pattern matches the front and back rails. Last edited by colin340 : 08-06-2014 at 12:03 AM. |
0.090" Quote:
6 wheel would be more traditional WCD, with a direct-driven center wheel. Quote:
Take off the bumpers, pop off the wheels (clip rings), and then with a few loosened bolts the flat panel (with attached 1x3 bumper supports) comes off (leaving the corner brackets in place). Depending on where we mount upper mechanical stuff, we made the top parts all modular and easy to access, just in case we have to add a step to that. At this time, I believe twelve bolts (that we have easy access to) and we can slide the whole side panel off. I mean, we've never had to replace a sprocket or belt in our drive train since switching to belts way back when, but that doesn't mean it can't happen! Quote:
In a perfect world, during build season we'll figure out exactly which mount holes we're going to use and delete the rest of them in favor of larger lightening holes/slots. As to the bumper shape: that's an excellent idea. T'would require some non-trivial re-design of what we've got here, but that's the whole idea! I'll bring it up to the team. Thanks for the feedback so far! ![]() Last edited by pfreivald : 08-06-2014 at 12:16 AM. |
What Colin Said.
Also http://www.chiefdelphi.com/forums/at...8&d=1407293863 It looks like you have e-clip grooves on the outside of the bearing and also at the end of the shaft to retain the wheel. You will be better served to remove the interior groove because it creates a failure point in the shaft that's seeing a lot of torque. Use spacers to maintain the gap you like between the rail and the wheel and keep the e-clip on the very ends of the shaft. Nice work. |
#7
I like the design!
Same question, why 5 shafts? If you lose chain you could be unable to drive any of the wheels, whereas if you direct drive a wheel you are guaranteed at least one wheel under power. Second, Are you using the w pattern traction wheels? http://www.wcproducts.net/versawheel/ Third, Why go with exactly 112" perimeter? This may sound dumb, but why go as close as you can, because a tape measure may be short or you could bend your frame making it bigger... (my team usually goes at 111" to be on the safe side) Fourth, I have not worked with sheet metal before, but is it strong enough to support the wheel bearings without versa blocks or something to that extent? i have seen it done with thicker metal, but not sheet metal. |
#8
That is what I was talking about by going to hexagon, instead of octagon.
#9
Looks really cool! I love the octagon design.
A few questions/comments: How do you remove the transmission? What type of bearing blocks are you using (if any)? If you're not direct driving a wheel, have you considered the 3 CIM ball shifter? You may be able to get the extra reduction stage between the output shaft and the wheel. I'd be careful with that snap ring groove between the frame and the wheel. You generally want to avoid these where the shaft is transmitting torque. |
#10
I'm not sure how worried I'd be about breaking two belts simultaneously (which is what would have to happen to lose drive completely on one side)--we've never broken one! Quote:
![]() Quote:
Cool, thanks! |
#11
Do you have a specific way of tensioning the belts? Or are you planning on getting it right first and then not changing it? Also, its a little hard to tell from your picture, but you may want to add in some more ribbing, especially at the corners. From the way the brackets are bent and they way you did the hole pattern, it seems like these corner pieces would mount to the bumper? correct me if I'm wrong. The way it is design it seems like you could see bending of those flanges through the rigors of competition. You can take a look at 971's CAD screenshots to get a better idea. We put a lot of support on the inside of the drivetrain, independent of using the bellypan as an integral part of the drivetrain. It's a step up on complexity, but your drivetrain will be much more likely to survive high speed impacts that were more common this season. Otherwise, it's great your team is spending the offseason trying to improve/design a drivetrain. I'm looking forward to seeing more from your team. |
#12
Thanks! |
#13
Thanks for the post pat. We are in developmental stages on some drive train work too. I'll take some of these notes into consideration for ours as well.
Can't wait to see it. |
