Go to Post what fun is it if you haven't ripped out all your hair and beaten your now bald head against the wall for extended periods of time.... - pickle [more]
Unread 30-07-2014, 01:22
drumtechjp drumtechjp is offline
FRC #3015
drumtechjp is an unknown quantity at this point
How to CALCULATE assist points
So, I realize this is well after the fact, but during the season, as we were developing a scouting database in excel, we were considering tracking each robot's individual assist locations per cycle, using a 3x3 grid as shown in the rules. A student had proposed that coding such a system would be VERY complex, given the myriad of possible outcomes. Due to circumstances of various symmetries, etc. I understand that this amount is pared significantly. Anyway, we decided on going a different route and didn't need it, but promised him that I would figure out a way to do so in the off season. I sat down last night and came up with a rather...... ugly bit of code in excel that will in fact calculate it correctly (included below), however, I was wondering if anyone else had done this, or had suggestions for a far more STREAMLINED approach.
The 3x3 grid occurs in the range C4:E6, and at the bottom of each column, as well as to the right of each row,there is a cell with a "counta" function pertaining to its respective adjacent column or row.
The code:
=IF(OR(AND(COUNTA(C4:E6)>5,(COUNTIF(C7:E7,">0")+CO UNTIF(F4:F6,">0")=6)),AND(COUNTIF(C7:E7,">0")+COUN TIF(F4:F6,">0")=6,(COUNTIF(C7:E7,"=3")+COUNTIF(F4: F6,"=3"))<>2,COUNTA(C4:E6)<>4)),30,IF(AND(COUNTIF( C7:E7,">0")+COUNTIF(F4:F6,">0")=6,COUNTA(C4:E6)=4, IFERROR(CELL("contents",INDIRECT(ADDRESS(MATCH(2,F 1:F6,0),MATCH(2,A7:E7,0)))),0)<>0),30,IF(AND(COUNT IF(C7:E7,">0")>1,COUNTIF(F4:F6,">0")>1),10,0)))
Basically, I began with scenarios to give 3 assists, then added elements to eliminate those which would incorrectly score 30 given the set parameters. I then proceeded to do the same with the 2 assist situations.
Any input would be greatly appreciated!
Unread 30-07-2014, 01:23
FRC #3015
Re: How to CALCULATE assist points
and though I'm not sure what language the FMS is written in, if anyone has access to that methodology, that too would be interesting/ helpful!
Unread 30-07-2014, 01:25
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Are you interested in general approaches or just better code in Excel?
Unread 30-07-2014, 01:29
AKA: Eric
I don't know how FMS did it, but here's one approach:
1) Make the power set of pairs of (robot,location with ball)
2) Filter for sets where all robots in the pairs are unique and all locations are unique
3) Find the max cardinality of the remaining sets.
Unread 30-07-2014, 03:10
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
You can abuse the fact that assists can be calculated on the diagonal of the grid, if you count the robot-zone combinations along a diagonal, you can find the number of assits for a given column arrangement. If you also swap the columns around, and take the max, you can find the total assists.
Here's a quick example in python:
#~/usr/bin/env python
import sys
def main ():
    if (len(sys.argv) < 1 + (3*3)):
        return
    grid = [[0,0,0], [0,0,0], [0,0,0]]
    for i in range(0, 3):
        for j in range(0, 3):
            grid[i][j] = int(sys.argv[1+(i*3)+j])
    print "The combination:"
    printgrid(grid)
    print "Has", calcAssists(grid), "assists"
def calcAssists (grid):
    asstCombs = [0]*(3*2*1) # 3! Combinations
    asstCombs[0] = calcDiagonal([grid[0], grid[1], grid[2]])
    asstCombs[1] = calcDiagonal([grid[0], grid[2], grid[1]])
    asstCombs[2] = calcDiagonal([grid[1], grid[0], grid[2]])
    asstCombs[3] = calcDiagonal([grid[1], grid[2], grid[0]])
    asstCombs[4] = calcDiagonal([grid[2], grid[0], grid[1]])
    asstCombs[5] = calcDiagonal([grid[2], grid[1], grid[0]])
    return max(asstCombs)
def calcDiagonal (grid):
    return (grid[0][0] + grid[1][1] + grid[2][2])
def printgrid (grid):
        print str(grid[i][0]), str(grid[i][1]), str(grid[i][2])
if __name__ == "__main__": main()
Hopefully you can adapt that to excel
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 05-08-2014, 23:15
FRC #3015
Just curious, is there any way off actually obtaining/ accessing actual FMS source code? Also, is anyone reading this familiar with what language/ protocol it employs?
Unread 06-08-2014, 00:15
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
I think that this is something that everyone wishes was available to FRC team. Unfortunately, the source code has not been publicly released.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 06-08-2014, 02:07
timytamy's Avatar
AKA: Tim
There is a good write-up from 2009 here: http://www.chiefdelphi.com/media/papers/2266 however the main FMS-DS-Robot communication loop hasn't really changed so it's still relevant for at least the 2014 FMS.
However this only specifies robot control, AFAIK the scoring system in the main FMS is not accessible by teams over the network.
Tim W
Sydney, Australia
Unread 06-08-2014, 09:45
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
The FMS source is not available to anyone outside of FRC Engineering.
The FMS proper (i.e. the big server box) is written primarily in .NET (with an MVC front end). There are other pieces to the field electronics (such as the driver station boxes), but I'm not sure what those run.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 06-08-2014, 11:05
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Perhaps a better way of doing the calculation:
=VLOOKUP(MIN(IF(COUNTA(C4:C6)>0,1,0)+IF(COUNTA(D4: D6)>0,1,0)+IF(COUNTA(E4:E6)>0,1,0), IF(COUNTA(C4:E4)>0,1,0)+IF(COUNTA(C5:E5)>0,1,0)+IF (COUNTA(C6:E6)>0,1,0)),G3:H6,2)
In this, I included the counta functions, although you could certainly utilize the ones to the side and bottom of the table you mentioned, which makes this equation even easier:
=VLOOKUP(MIN(COUNTIF(C7:E7, ">0"), COUNTIF(F4:F6, ">0")),G3:H6,2)
Basically, we want to know how many rows and how many columns have something in them. From there, we could look at each possible combination exhaustively... but it's easier to look at the minimum of the two, as that will be the number of credited assists. Then I just created another table G3:H6 that has 0-4 in the first column and the corresponding scores in the second (0,0,10,30). Doing a vlookup on that second table lets me find the score that matches the number of assists performed and return it.
Note: Why doesn't excel have a function like Oracle's DECODE function in SQL? I so wanted to use that for this solution!
Edit: I just realized there's an edge case this doesn't handle correctly - two robots both poses in zone 1, then a third possesses in zones 2 and 3. Back to the drawing board!
2016: Lake Superior WFFA
Unread 06-08-2014, 11:52
Mentor, LRI, MN RPC
Ok, second try now that I had a few more free minutes...
=VLOOKUP(MAX(COUNTA(C4,D5,E6), COUNTA(C4,E5,D6), COUNTA(D4,E5,C6), COUNTA(D4,C5,E6), COUNTA(E4,C5,D6), COUNTA(E4,D5,C6)),G3:H6,2)
Again, using the vlookup function to transition from number of assists to points. Here though, I'm simply doing a counta on each possible combination for 3 assists. By default, that also includes all possible combinations of 2 and 1 assists. By doing a max, we find the maximum possible assists that were counted.
Unread 06-08-2014, 11:57
AdamHeard's Avatar
Lead Mentor
Tangentially related. Index(match()) is much more efficient than vlookup, and a more robust way to link in case people insert collumns, etc... I find it more intuitive to setup as well.
The performance is far better. Not a huge issue for most excels, but a huge performance difference in google spreadsheets.
