Thread Tools |
Rating:
Display Modes |
Re: Gear Face Width
If you're using non-CIM motors, or only 1 CIM, you can realize those gains. See here for an example: http://media.team254.com/2012/08/gearbox.jpg |
Re: Gear Face Width
1 For the most adventurous, if you really want to go crazy to prove the point that we aren't limited by the shaft diameter, and aren't averse to some creative fixturing and metallurgy, you might even be able to machine it, then harden it in place, and finish-grind the diameter (to maintain concentricity) and the teeth (to clean up the profile). That would permit a very small, strong shaft. This isn't remotely easy or cheap, and it's virtually inconceivable that any FRC team has ever tried it. You'd need a lot of very direct heat and a lot of heatsinking ability to avoid cooking the varnish in the motor or demagnetizing the magnets, while still changing the phase of the steel at the tip of the shaft. Then you'd need to quench it fast. And finish grinding of gear teeth essentially requires a custom fixture, which you'd have to build. (Note that if the next set of FRC rules have a definition of modification that allows disassembly of motors, this becomes a fair bit easier.) |
Re: Gear Face Width
Re: Gear Face Width
Modification isn't straightforwardly defined, particularly because it's difficult to account for the cases where something is disassembled, and then reassembled in a functionally-identical way. When the assembly was apart, it was clearly modified, but it is arguable whether reassembly restores it to an unmodified state, leaves it in a functionally-identical modified state that negates the illegal modification, or leaves it in a functionally-identical illegally-modified state. As for removing the CIM shaft, although it's straightforward to open the motor up and detach the rotating parts from the fixed ones, I don't recall it being practical to remove the CIM shaft from the armature. As a result, overheating the varnish is still a concern (but overheating the magnets would not be). But you're correct that this would nevertheless simplify the process significantly. |
