Go to Post It's over, done, let's move on and be positive. Next year maybe everything will be perfect. :cool: - Ed Sparks [more]
Unread 07-08-2014, 13:14
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Tribot swerve
Originally Posted by GrifBot View Post
Well, based on the video, the tribot on swerve allows some very advanced maneuvering that could easily get around defense any day.
In what way is that different from a four-wheel swerve?
However, defense wise I feel that a tribot would be a push over.
Why?
Unread 07-08-2014, 14:29
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Re: Tribot swerve
Why?
Well, depending on how you're angled, it would be ideal to have one wheel closer to the front for steering/direction instead of two, with the back two acting as speed and stability. With one wheel upfront you should be able to turn smoother/faster.
Well, having a 3 sided bot would expose more area for a defensive bot/offensive bot to hit the bot in the corner to knock a shot off target as a triangle is essentially based off of 3 corners, not 4 corners with "flat space" in between that would do very little when hit. In short, the tribot is more exposed when it comes to being hit effectively.
Unread 07-08-2014, 14:43
Joining the 900 Meme Team
FRC #0079
Re: Tribot swerve
Who said number of sides was dependent on number of wheels?
Unread 07-08-2014, 14:44
g_sawchuk's Avatar
Hmm.
FRC #4476
Re: Tribot swerve
True. I was just basing it off of the fact that this one had 3.
Unread 07-08-2014, 15:40
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
Re: Tribot swerve
Neat design.
Just be careful your shape doesn't fit into one of the game elements like when Rosie stuffed Thrust into the goal in 2010.
Unread 07-08-2014, 20:42
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Tribot swerve
Originally Posted by frasnow View Post
Neat design.
I know this is off topic, but look in the thread in the quote, watch the video first, then proceed to read the comments of the thread talk about how aggressive and uncalled-for the defense was, then fast forward to this year. Kinda funny I must say
Unread 07-08-2014, 20:47
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Tribot swerve
Just remember. More 3 wheel swerve robots have won worlds than mechanum.
Unread 07-08-2014, 20:54
g_sawchuk's Avatar
Hmm.
FRC #4476
Re: Tribot swerve
Because that means a lot.
Unread 07-08-2014, 21:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Tribot swerve
IMO, a well-designed swerve drive will beat a well-designed mecanum drive. However, mecanum wheels have only been widely available for a few years in the FIRST community, so you have to give them some time.
Unread 08-08-2014, 15:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Tribot swerve
AndyMark first introduced their mecanum wheels in 2006, iirc. It's been quite a bit longer than a "few years" at this point. Granted, the first robot with steered wheel modules to win a championship was 67 in 2005, iirc.
Unread 08-08-2014, 16:23
FRC #0079
Re: Tribot swerve
Stang 03? (I don't recall)
Unread 08-08-2014, 18:18
Billfred's Avatar
Billfred Billfred is offline
Re: Tribot swerve
I know first-hand that mecanum drives go back to at least 2006 (357--Royal Assault--ran them to the Florida Regional finals). I know AndyMark had them available for the 2008 season (1293 used parts from them). That's seven years (okay, six if you want to discount Lunacy) of development for the masses. Swerve was around no later than 2000 (per this CD-Media picture of Chief Delphi (as in FRC 47) that year), maybe a couple years prior? With the raw number of teams now compared to then, I have to think mecanum has matured as an option by now.
That's the first swerve I can think of that won it all. Can any old-timers go further back with a winner?
Unread 08-08-2014, 19:00
Nate Laverdure's Avatar
FRC #2363
Re: Tribot swerve
Back in 2003 we were calling mecanums "jester drives." Too lazy to search, but you might find earlier evidence of mecanums under this name.
Unread 09-08-2014, 03:22
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Tribot swerve
I stand corrected. For some reason I thought they were only introduced by AM a few years ago.
Swerve for life BTW. I don't care how effective they are now, but new designs are introduced every year. So many ways to do one thing.
Unread 09-08-2014, 19:57
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Tribot swerve
Not winners, but 47 ran swerve for the first time in either 97 or 98 (someone told me that on here recently, but right now I'm on mobile and can't easily search).
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
