Go to Post Canada has five regional events now. Canada. - Nick Lawrence [more]
Unread 07-08-2014, 14:43
Joining the 900 Meme Team
FRC #0079
Re: Tribot swerve
Originally Posted by GrifBot View Post
Well, depending on how you're angled, it would be ideal to have one wheel closer to the front for steering/direction instead of two, with the back two acting as speed and stability. With one wheel upfront you should be able to turn smoother/faster.
Well, having a 3 sided bot would expose more area for a defensive bot/offensive bot to hit the bot in the corner to knock a shot off target as a triangle is essentially based off of 3 corners, not 4 corners with "flat space" in between that would do very little when hit. In short, the tribot is more exposed when it comes to being hit effectively.
Who said number of sides was dependent on number of wheels?
