Go to Post yes, duct tape solves everything - Ted Boucher [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 29-07-2014, 13:47
Math Quiz 4
For the mathematically inclined, looking for a summer challenge.
Name:	Math Quiz 4.png
Unread 06-08-2014, 14:17
Re: Math Quiz 4
No takers?
Advanced math not required.
But it does help to think outside the box...
Unread 07-08-2014, 03:49
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Re: Math Quiz 4
Edit: Incorrect, please disregard
I would have responded earlier, but I was at an off-season.
Also, I will not have any pretty MS-Paint pictures due to limited computer access. Please bear with me.
The 3 things we know are:
1. OL is perpendicular to DH.
2. DE is perpendicular to OC
3. DE = CH.
Based on 1 and 3, I can safely state that triangles OLC and OLD are similar right triangles reflected along line OL. This is known because both triangles share a leg, a right angle, a hypotenuse, and a terminating point O.
I am given DR, DL, OL, and DE/DF.
From triangles OLC and OLD's similarity, I know LC and DL are the same length. I can also compute OD (which is equal to OC) from the Pythagorean theorem using OL and CL
I know the angle PCL = OCL and that angle can be found by taking arctan(OL/LC)
I can now find PD based on the law of sines. For all of you who have forgotten geometry, the length of a side in a triangle devided by the sine of the angle opposing it js a constant for the triangle. All three side/and pairs share this property. CD/sin(CPD) = PD/sin(PCD). We know both angles and length CD (angle PCD is known from arctan(OL/CL).
Now that I have established PD, I will try and find ED. I know the total angle of COR is arctan(CL/OL) + arctan(RL/OL). OP can be found by using the Pythagorean theorem on the triangle OPD as both PD and OD are known and angle OPD is right by 2.
Angle COR is also and POF. Using triangle POF is right by 2, PF = OP×tan(POF). As we know know PF and PD, DF = PD-PF. DE = DE/DF (given) × DF.
EP = DE-PD. We know the angle HOL is equal to arctan(EP/OP)+arctan(PD/OP)-arctan(DL/OL). We also know triangle HOL is right by 1.
DH =tan(HOL)×OL.
If I have made a mistake, please let me know. I think my solution is correct, but I may be wrong.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 07-08-2014, 08:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Math Quiz 4
3 reads DC=CH in the image... I believe that correction to your post messes up the solution pretty badly...
2016: Lake Superior WFFA
Unread 07-08-2014, 10:26
Re: Math Quiz 4
It does, my apologies.
2015:
2014:
2013:
2012:
Unread 07-08-2014, 13:32
Re: Math Quiz 4
I've thought about this a little, but haven't had time to sit down and work out the math yet. With what's provided, you can easily figure out lengths and angles for everything about triangles OLR and OLD, but that alone doesn't help you.
I suspect the answer lies in using the DC=CH relationship, along with the DE/DF ratio to infer some other relationships. As point C (note Point H moves in relation to point C!) approaches point L, the line DE approaches line DH. As such, the length of DE is important - that length has to change in a very specific way as you move point C along the DH line. This seems to imply that the length of DF is critically important, as it tells you the length of DE... Can we find DF using what we know of triangles OLR and OLD and the relationship the angle FDR has with the length of DC and DH?
Anyways, those are my lunchtime musings... They may lead you towards a solution, or down a blind alley from which there is no return! Either way, it's the journey that matters, not the destination
Unread 07-08-2014, 13:58
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Math Quiz 4
Yup. Sometimes the simplest way to solve a problem is to draw your own lines...
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 10-08-2014, 12:50
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: Math Quiz 4
I am at an off-season event right now (showme-showdown), but I am working on this throughout the day. I suggest those who are trying it to look into Stewart's theorem.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 11-08-2014, 10:29
Re: Math Quiz 4
I'm really surprised no student has posted a solution yet... I know I stumped one of our students with it at our meeting Saturday - She's a Dean's List Winner and couldn't give me an answer after 3 hours of staring at the whiteboard!
Unread 19-08-2014, 15:31
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Math Quiz 4
Here's a golfed version of the solution i came up with, ill neaten it up in a second
(2*sqrt(z^2+a^2)*sin(90-arcsin(a/sqrt(z^2+a^2))))/sin(180-(90-arcsin(a/sqrt(a^2+(z-y)^2))+180-(180-(180-arcsin(a/sqrt(a^2+(z-y)^2))+arcsin(a/sqrt(z^2+a^2)))+arcsin((bsin(180-(180-arcsin(a/sqrt(a^2+(z-y)^2))+arcsin(a/sqrt(z^2+a^2)))))/(y)))))
E/ i just noticed that I accidentally wrote o instead of sin(o) when i golfed this code.... woooooooooooooooops
2e/ pay no attention to the golfed version above
3e/ fixed the golfed version. ignore the 180-180-180-...
where
y=DR
z=DL
a=OL
b=DE/DF
e/ explanation (i know i accidentally used "b" twice, in the expalantion "b" will be marked as "#")
b (OD) = sqrt(z^2+a^2)
c (<ODL)= arcsin(a/b)
d (<DOL)= 90-c
e (OR) = sqrt(a^2+(z-y)^2)
f (<ORL)= arcsin(a/e)
g (<ROL) = 90-f
h (<DRO)= 180-f
i (<DOR) = 180-(h+c)
//temporary stepping out of alphabetical order
l (DF) = b^2 + e^2 - 2*b*e*cos(i)
//back again
j (<DFO)= arcsin((bsini)/(l))
k (<ODF)= 180-(i+j)
m (DE) = #L
n (<DOC)= 90-C
o (<DCO) = 180-(g+k)
sin(n)/x = sin(o)/b :: 1/x = sin(o)/bsin(n) :: x = bsin(n)/sin(o) ::
solution = 2 * DO * sin(<DOC)/sin(<DCO)
Dean's List winner doesn't necessarily mean a math whiz... most of our deans list entries aren't mathletes (except for our 2012 entry, who won at MSC)
Name:	Math Quiz 4 Solution.png
Unread 19-08-2014, 22:09
Re: Math Quiz 4
j = arcsin((bsini)/(y)) <- error here
Unread 20-08-2014, 06:56
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Re: Math Quiz 4
Woops, my bad, that should be lowercase L.
e/ L is after J in the alphabet. Right. I would need to solve for triangle DRF somehow. I'll post a different solution in a bit
When I get home I'll see if i can get a neater final solution. (though I only just went through trig (starting BC) so I don't know many tricks)
2E/ fixed that error. working on a latex solution
3E/ i feel like i should be doing something with all of those cos(arcsin() - arcsin())
\frac{2 * \sqrt{z^2 + a^2}*cos(arcsin(a/b))}{cos(arcsin(a/\sqrt{a^2+(z-y)^2})-arcsin(\frac{bsinc}{\sqrt{a^2+(z-y)^2}})-arcsin(\frac{a}{b})-arcsin(\frac{bsin(arcsin(\frac{bsinc}{\sqrt{a^2+(z-y)^2}})-arcsin(\frac{a}{b}))}{\sqrt{2*b*\sqrt{a^2+(z-y)^2}*cos(arcsin(\frac{bsinc}{\sqrt{a^2+(z-y)^2}})-arcsin(\frac{a}{b}))}))}}
Unread 20-08-2014, 15:01
Re: Math Quiz 4
I see at least 3 errors in your derivation. Check your work carefully.
Or better yet...
Think outside the box. Consider other approaches.
Unread 20-08-2014, 16:46
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Re: Math Quiz 4
Or better yet...
Hmmph, I suppose I'm a bit rusty, haven't had to do anything with my brain since last build season. Although, I don't see how using cartesian coordinates will help, since most of the numbers given are variables.
by "errors in [my] derivation", are you referring to issues I have with the fundamental concepts of trigonometry or just slips like the first error I posted? the only thing I know i purposely avoided was the ambiguous law of sines case.
Unread 20-08-2014, 17:12
Re: Math Quiz 4
You seem to understand trigonometry but there are obvious (careless I assume) mistakes in your derivation. Check each step carefully.
Or better yet, think a bit more about other (simpler) approaches.
