Old 3 in. CIM
Does anyone know anything about the old 3 in. CIM? I heard that they were legal years ago, and then were banned. I have two which I would like to use for household projects but I don't know much about them. I'm planning to use one to power a small portable lathe but running into issues with power transmission to the spindle. Anything about gearboxes they worked with or motor torque/power curves would be helpful.
Thanks Last edited by Crazy Ewok : 06-08-2014 at 12:10. |
Re: Old 3 in. CIM
If you search cd-media you should be able to find documents with motor specs from 06 and 07 (when they were legal).
From memory they were ~2700 rpm, and about 2/3 of a CIM in terms of power so ~ 450 oz-in of torque. Andymark used to sell (maybe they have some left?) a 28T gear w/ the D shape for it. I'd recommend using belt for the power transmission though. The efficiency and duty cycle on them (like the CIMs) isn't great, so not sure they'd be a great choice for a continuous duty application like a lathe. |
Re: Old 3 in. CIM
I've attached the motor curves for the "Big CIM" from 2006. Hope this helps.
Re: Old 3 in. CIM
If it's for a lathe, you can just purchase a big 120v motor. You would need a really massive 12v power supply if you go with an FRC motor.
Re: Old 3 in. CIM
Thanks everyone for the info, very helpful. It's a small hobby lathe for wood turning only, I think the CIM will be ok. Thanks asid61, I have a 60 amp power supply ready for it.
Re: Old 3 in. CIM
Why do you think the CIM will be okay?
Why would you choose to use a brushed DC motor instead of a basic AC motor? |
