Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 13-08-2014, 18:47
SpeedFreed's Avatar
SpeedFreed SpeedFreed is offline
Coach Annoyance Lead
FRC #0418
SpeedFreed is an unknown quantity at this point
Another Drivetrain Idea - "True Octanum"
While reading the recent thread about "Box drive", I was struck with the idea of that configuration made out of mecanum wheels. Now this is pretty much just a thought experiment, but I got to thinking that it does solve one of the biggest problems mecanum has, which is the loss of power in strafing. Here is a concept drawing:
Notice the 8 mecanum wheels, making this, in my option, more worthy of the "octanum" name.
In an environment with no unwanted friction, a typical mecanum configuration can reach full speeds forwards as well strafing. For the longest time I thought that mathematically mecanum were limited to about 70% speed in strafing action, but in actuality the 30% lost entirely to entropy (booooooo).
However, as shown above, this configuration has the second set of mecanum wheels that will be able to strafe at the same speed the other set can go forward. Since mecanum wheels are not mathematically limited, the set not being "used" should just go along with the ride, and while not providing much use in moving that direction, they shouldn't drag much on the ground.
Each pair of mecanum wheels (two per corner) should be able to be linked via a clever use of bevel gears, and the driving/coding should be no different than typical mecanum.
I have only been able to think it through forwards, backwards, strafing, turning, and diagonals, and as far as I can tell I should work. Though I can't tell when it comes to complex movements.
This should allow you to make a completely symmetrical, omni-directional drivetrain; the only other ones being swerve and holonomic. It also should reduce mecanum bounce, as well as increase mecanum's traction some (though that is a complete guess). Furthermore, you get the advantage of full motor usage in the primary direction, which you lose in something like H drive (which has to split up the motors for different directions).
What do you guys think?
Note: Again, we aren't planning to actually do this. In fact we have already designed built and are now testing the other "octanum" for next year.
Unread 13-08-2014, 19:00
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: Another Drivetrain Idea - "True Octanum"
How do you ensure coplanar ground contact between all the wheels?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 13-08-2014, 19:10
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
Looks like you might need to go into the realm of spring suspension if you're worried about coplanar contact. If you made the corner unit as a whole independent from the main frame, I think that would be a functionally sound way of pushing the mecs down into the floor surface. Obviously that would cause issues with lateral impacts, so depending on the amount of uneven wear expected between wheels, it would probably be better to just assure that all of the wheels are in the same condition and the axle is attached to the frame soundly.
Unread 13-08-2014, 19:11
SpeedFreed's Avatar
FRC #0418
The steps I always take to make sure all wheels touch the ground are:
1) I don't make perfectly rigid drivetrains (on purpose!). You shouldn't be able to notice any flex, but it should be there in ever so slight amounts.
2) Mecanum wheels that flex, such as Vex Pro Mecanum wheels, actually have a small amount of give, so they could be ever so slightly off.
3) Diligence. I always use a CNC machine or mill with DRO to drill holes in my mecanum drives to make sure they are exactly in the right spot I do this for many other parts of the robot too).
But I can't imagine it would be all that different from a typical 4 wheel mecanum, just doubled.
Unread 13-08-2014, 19:45
pimathbrainiac's Avatar
pimathbrainiac pimathbrainiac is offline
Today, Regionals. Tomorrow, Worlds.
AKA: Philip N
FRC #1127 (Lotus Robotics)
pimathbrainiac can only hope to improve
Interesting idea, taking off my/cjl2625's concept. How would the suspension work on this, since each corner of mecanum wheels are joined by bevel gears?
Unread 13-08-2014, 20:46
SpeedFreed's Avatar
FRC #0418
Well on first thought, you could have to pivot one mecanum wheel about axis of the other. While you wouldn't want to do this for anything extensive (I can't imagine mecanum wheels work well on significant angles) you should get a safe 1/8" of travel out of it, which would be plenty to account for any build tolerances. Then you just have to make sure the 4 solid mounted mecanum wheels are mounted such that they are coplanar (like any mecanum drive).
But, in my opinion, suspension is unnecessary complexity that should be avoided whenever possible. One of the goals in this idea was it's lack of articulation for simplicity and weight (and time and money...).
Unread 13-08-2014, 23:21
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Interesting, now I want someone to build it to test how it performs compared to a standard mecanum drive.
Unfortunately though, I don't think that the added weight/design complexity would be very worthwhile. If I am understanding this design correctly, any gains you get in the strafing direction will come at the expense of the forward backward direction.
For example, under a normal 4-wheel mecanum setup, top speeds might be something like 10fps in the forward direction and 5fps in the strafing direction. With the same reduction in your setup, my guess would be that you would see more along the lines of 7fps in both the forward and strafing directions (whichever directions you so choose those to be).
I suppose that if you wanted the robot to handle more like a swerve drive than standard mecanum, this setup could help. I know our driver did not like field-centric code with mecanum wheels since his max velocity was dependent on which way the robot was facing.
Unread 14-08-2014, 11:22
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Correct me if I'm wrong, but wouldn't you be better off going to a 4 omni setup? You wouldn't have the losses from miter/bevel gears, it would be lighter, more robust (it seems omnis stand up better than mecanums), have the same strafe power as forwards-backwards, wouldn't require a suspension, and would be mechanically simpler? It's effectively what you're doing here already.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 14-08-2014, 12:46
SpeedFreed's Avatar
FRC #0418
It is true that basically this only improves the strafing abilities and adds symmetry. While I can imagine it must have some effect on top forward speed, exactly how much is a question that can only be answered in testing. Also, speed can always we compensated for, like my teams new octanum--powered by 6.66 CIMs and does 22fps on mecanum (after mecanum loss). Likewise if you power each corner of this with 1 CIM and 1 Mini CIM, forward loss will probably be quickly forgotten.
As for 4 omni wheels, I'm not quite sure what you are getting at. If you mean replace one set of mecanum wheels with omni wheels, then you would need at least 6 independent gearboxes to drive all the wheels (4 for mecanum, 2 for omni wheels) (or differentials, but THAT truly gets in the realm of unnecessary complexity), and then that is some strange mix of H drive that really holds no advantage. If you mean just 4 omni wheels, then that would have to be holnomic drive, which only reaches top speeds on the diagonals (unless you do 4 omnis Killer Bees style, and then you have to be magic to drive it).
The biggest pro's I was getting at with this, is that it provides full motor power in the cardinal directions (unlike H drive), and is symmetrical like swerve. But it is also heavier, more expensive, and harder to make than mecanum, for probably not enough gain.
However if your team does mecanum every year without exception, and is tired of it's asymmetric performance, then this is the drivetrain for you!
Unread 14-08-2014, 13:18
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Did you mean 2 sets of 4 or 8 total? Like this:
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 14-08-2014, 13:22
Certified Nerd's Avatar
Certified Nerd Certified Nerd is offline
The Only Certified Nerd! GOT IT?!
AKA: Danny
FRC #3840 (TNT)
Certified Nerd is an unknown quantity at this point
Why not just use 8 sets of 2 omni wheels? Wouldn't this work fine and be much cheaper?
Unread 14-08-2014, 13:33
jman4747's Avatar
AKA: Josh
Team Role: CAD
Do you mean 2 sets of 4 = 8?
8 wheels*2=16
16*$18 a wheel (4" VEX Pro omni) = $288
2 sets of 4" VEX Pro Mecanum = 8*$30 = $240
8 total 4" VEX Pro omni wheels = $144
#banthebag
#RIBMEATS
#1620
Unread 14-08-2014, 14:46
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
I don't think this really helps you.
So, here's the thing (Ether or one of the mecanum experts can correct me here): in an ideal environment, there is no difference in power applied forward/backward vs strafe left/right. The reason you see bias in the real world is because of the internal friction in the roller bearings - this effectively means the wheels aren't providing power at 45 degrees, but rather some other number that is typically biased towards front/back.
All you're doing here is combining two imperfect drives orthogonally, so instead of max speed in one direction and 60% in another, you're probably going to have 80% in both, as the fast drive will be "dragging" the slow drive.
Unread 14-08-2014, 15:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Draw out a free body diagram of both a typical mecanum set-up and then this one.
Unread 14-08-2014, 16:17
lovelylily06 lovelylily06 is offline
AKA: Caroline
FRC #1699
lovelylily06 is an unknown quantity at this point
What size mechanum wheels were you considering for this design? I think the efficiency of the design would be changed by the robot itself and not just the theory of the drive system alone. I generally consider the drive system more of the support but I really like this design!
