Go to Post You can't simply bring another 100 teams into FIRST and have them all asking Andy Baker questions. - Rich Kressly [more]
Unread 13-08-2014, 19:11
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: [FTC]: Custom Axles
The motor shaft of tetrix motors is 6mm, which is ~.236" (Taken from this drawing)
You can get 6mm shaft from McMaster and a number of other sources.
Of course this drawing of the hub shows the bore to be 5.95mm or .234"
I wonder if you could take the motor hubs and drill them out to 1/4" That would give you a bunch of options. The little nub that centers it inside the gear/wheel/etc. is 7.97mm or .313" so there would be material left to center the hub and use them as normal. D profile shaft 1/4" diameter at McMaster is ~$9 for a foot long piece.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
