#106
Re: Pneumatic Restrictions & Improvments
Either way, I've found more than half of my time inspecting is actually protecting teams from other inspectors with flawed interpretations of the rules. Too many inspectors (rarely LRIs luckily) have a seeming "Us versus them" mentality, rather than focusing on how to work with teams to get them the best experience they can. |
#107
Don't you just love when people on a forum take something you say, twist it around, and start beating you with it every chance they get? No where in anything I said did I say I didn't trust teams to do what they thought was best and legal. No where did I even imply that anything we look for at events is because we suspect teams of cheating, as opposed to acting out of ignorance (which is probably 99.9% of what we see as inspectors).
You'll note that I never said anything about not trusting teams - the word trust wasn't brought up by me. I simply pointed out that we don't know if teams are using a shop compressor to charge their robot, and that's one reason we don't like having them present in the venue. It's not a question of trust any more than any of the other rules we enforce at an event - it's a question of "what is that freshman who doesn't know the rules going to do when the pressure is on and he's sent to get the robot ready for the match?" Many, many teams use a shop compressor during the build season to power pneumatics for testing - I know my team does, and everyone on my team knows how to do so safely... and it's quite possible that one of my students, out of ignorance, would use a shop compressor to charge up the robot when in a time crunch/pressure situation. |
#108
Maybe AndyMark or IFI can start stocking a pneumatic pressure transducer? VEX robots also could use a pressure transducer ! |
#110
The older rules were pretty good at keeping the playing field standardized. I really like the increased volumes of air storage with the new rules but we could write the rules like the motor restrictions of the banebot motors or the bag/mincim. "Your allowed X amount of the following approved tanks" So teams could max out volume with the larger ones, use smaller ones for better packaging or mix and match how they see fit. Just a suggestion for a possible number for amount of tanks, i am thinking of 8. I think that might represent the upper limit for teams but for 987 that might be more like the median of their usual quantities. |
#111
As for general limits on the volume of storage, I would hope we wouldn't see those return. Prior to 2011, those volume limitations made it very difficult to use pneumatics without having an on-board compressor. With the weight and battery issues caused by a compressor, teams often skipped pneumatics entirely, with the exception of their shifters. Once the limits were removed we saw a huge increase in the usage of pneumatics, coupled with many unique designs which were previous infeasible or very difficult (254's jaw in 2011, 2056's shooter in 2013). There's been a definite evolution in design as a result of these more relaxed rules, and I'd hate to see us take a step backwards in terms of the functionality of robots. |
#112
When it comes to limiting the allowable tanks, I see this as limiting a teams ability to research alternative storage tanks. There are a number of suppliers out there as well as custom options that would be more then acceptable under the current rules. As always, size and weight are a trade off in design. FRC558 has been looking into alternative tanks in the offseason, one potential source is the automotive aftermarket, since air suspension is a popular modification in the car world. I wish that there was a direct supply for an old KOP air tank, I believe we only received them in 2011 (Shown on pg. 11). There is always the old KOP tanks from Clippard. |
#113
However, I don't want to see plastic tanks go away and I don't want to see anyone wounded by shrapnel. I guess we just need some clear guidance on safe mounting practices. |
#115
Hopefully, if there is a future rule listing specific tanks that can be used, there will be a listed path towards getting additional tanks approved, similar to the pre-3/18 version of R31 in 2014, which had the blue box:
I saw a large number robotics with plastic tanks mounted on the frame perimeter. Completely unguarded. We have dents in Al plate in similar places on our robot. The trouble with using the general safety rules is what is legal at one regional is not legal at another. It also requires the LRIs to use judgement with something they may not have much experience with. Much like shooter wheel guarding in 2013.
#117
The sole job of the valve is to pressurize the system slowly to prevent the large initial pressure surge that can cause a cylinder rapid to the end of its travel. On the field when teams uses external compressors that have a a few tanks attached, they turn the ball valve and you can see this jump clear as day. This usually happens during the down between a match and its replay. I personally saw this two or three times this year alone. On the the pressure transducer the sunx is nice because you can configure the limits of the dio which makes it a programmable pressure switch combined with a digital gauge and a 0-10V analog for pressure feedback. All this can be done in the same package instead of three. This was really more about convinence than anything else. |
#118
Edit: Then again, since this should only apply to the case of an external compressor with external tanks, even a mechanical flow control would suffice. -Karlis Last edited by kmusa : 18-08-2014 at 11:51. |
