Go to Post Last I checked, this was a competition... just checked again, yup still has Competition in the name. - Andrew Schreiber [more]
Unread 14-08-2014, 13:33
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Another Drivetrain Idea - "True Octanum"
Originally Posted by Certified Nerd View Post
Why not just use 8 sets of 2 omni wheels? Wouldn't this work fine and be much cheaper?
Do you mean 2 sets of 4 = 8?
8 wheels*2=16
16*$18 a wheel (4" VEX Pro omni) = $288
2 sets of 4" VEX Pro Mecanum = 8*$30 = $240
8 total 4" VEX Pro omni wheels = $144
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 14-08-2014, 14:46
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
I don't think this really helps you.
So, here's the thing (Ether or one of the mecanum experts can correct me here): in an ideal environment, there is no difference in power applied forward/backward vs strafe left/right. The reason you see bias in the real world is because of the internal friction in the roller bearings - this effectively means the wheels aren't providing power at 45 degrees, but rather some other number that is typically biased towards front/back.
All you're doing here is combining two imperfect drives orthogonally, so instead of max speed in one direction and 60% in another, you're probably going to have 80% in both, as the fast drive will be "dragging" the slow drive.
