Go to Post It's amazing what you'll find in the FIRST Manual :) - dcarr [more]
Unread 15-08-2014, 00:13
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
pic: FRC 1086 Off-season teaser #1
Unread 15-08-2014, 00:14
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: pic: FRC 1086 Off-season teaser #1
Very nice, looks like everything could be done without a mill or maybe even a lathe, correct?
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 15-08-2014, 05:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looks good. Is that the only support plate, or will there be a second one beneath?
Unread 15-08-2014, 07:43
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I'm guessing not photography?
http://www.mcbride4.org/?attachment_id=207
The sooner we get behind schedule, the more time we have to catch up.
Unread 15-08-2014, 07:46
We actually did use a lathe, but we were able to avoid using a mill.
That is the only support plate. The module mounts nicely with the old style kop c channel.
Unread 15-08-2014, 08:10
Gdeaver Gdeaver is offline
FRC #1640
Can't see inside but, That hole looks like it is for accessing a set screw. The transfer axial should be designed so that the axle is constrained eliminating the need for a set screw. Racking. What is going to keep the lower module from becoming a parallelogram under high stress and load? Did you use thrust bearing for the miter gear loads or are you putting this on the ball bearings? What wheel is that? Allot of cantilevered load for that single mounting plate and those welds. How is this going to be driven? Is it a module or are you going to use a separate power pack? Only way to know what you got is to put it on a fully loaded robot frame and drive the hell out of it. See what wears. Igus bushing instead of bronze?
Unread 15-08-2014, 10:56
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
There are internal support braces that will keep the lower part rigid. It is a module. 1 Cim 1 mini cam per module. Also it's worth noting that on the final version we will be using our own custom 2" performance wheel instead of the wheel you see there.
Unread 15-08-2014, 10:59
AKA: John Gallagher
It's also worth noting that the internal support is not visible in this picture because this version of our design hadn't incorporated them.
Unread 15-08-2014, 11:02
jwfoss jwfoss is online now
Chasing Elegant Simplicity
AKA: Justin Foss
2" Diameter? How concerned are you with the wear rate?
With Live axles I'd suggest taking a look at other solid rubber wheels, perhaps a Colson.
Unread 15-08-2014, 11:35
AKA: John Gallagher
We've considered colsons and used them before but our CAD team tells us that performance wheels are significantly cooler looking.
Unread 15-08-2014, 17:38
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
Is this something we'll see at the Rumble in October?
winner vcu 2006,winner vcu 2013,2014,2015
Unread 15-08-2014, 20:19
nathannfm's Avatar
AKA: Nathan
FRC #3940
It is a module. 1 Cim 1 mini cam per module.\
You mean 1 CIM to drive it and 1 Mini CIM to turn it?
Unread 15-08-2014, 20:38
No, we were looking at how some teams were running 8 motors to drive their octocanums, so we thought it would be cool to give the same treatment to swerve. We use andymark motors to turn them.
Unread 15-08-2014, 21:07
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
So a 12 motor drive.... Sounds like a lot of power draw....
Unread 16-08-2014, 18:22
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Looks like exactly what the off season is for. Make sure to post lots of puctures, and maybe a writeup when you're done? I really like the idea of a lower barrier of entry for swerve.
Good job, keep us updated!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
