Go to Post I never said there was anything wrong with the kit frame, simply that it was weak. - Viper37 [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 16-08-2014, 12:15
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
2015 Beta Testing - The Components are Here.
Well, the beta test components showed up yesterday and we couldn't resist snapping some pictures.
http://www.fightingpi.org/Resources/...oduction.shtml
There's not a lot that's new, but at least they've all got their official shells, so this is what you should expect to see for next season.
Unread 16-08-2014, 12:41
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: 2015 Beta Testing - The Components are Here.
Looks beautiful! Do you guys plan on making a video of how you connect all the components?
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 16-08-2014, 13:25
Aren Siekmeier's Avatar
on walkabout
Thanks for posting these. A few things (that may have already been addressed by someone, but I couldn't find anything):
-Now that the shells are more or less finalized, any idea when we might get CAD files or interface drawings to plan for fasteners and layout? Schematics, meanwhile, I can understand not being available until almost kickoff.
-Not sure if data on this already exists. Has anyone done testing on when the regulated VRM outputs drop out? Also, do I understand correctly that the rRio does not have a regulated supply, and therefore is sensitive to all battery fluctuations? Probably this isn't an issue since it runs down to 7V, but any testing and data on this would be great, too.
Edit: nevermind, this isn't really that important
-Any option for (regulated) 24V outputs? (for special sensors, etc. not just from 24V solenoids) I suppose the 2015 rules will dictate if it's legal to use the PCM for this purpose (I suspect not). This has not been available in the past either, but it might be nice ...
There's lots of good suggestions for tests over in this thread, in particular concerning I/O timing and how I/O performance depends on voltage outages, brownouts, etc., as well as other concerns about real-time performance. Does anyone know if there is data or testing on any of this posted somewhere?
Unread 16-08-2014, 16:26
This white paper http://www.ni.com/white-paper/14613/en/
is probably pretty close to what you are looking for. The cRIOs used by FIRST are very similar to the 9074, and the roboRIO is very similar to the 9068. There are other white papers that discuss the scheduler and other aspects, but this is the first one I located that had benchmarks.
Just saw your other question. I think it is more appropriate to say that the roboRIO doesn't require an externally regulated supply. The supply of the cRIO and roboRIO were both internally regulated, but the cRIO levels didn't match what was available on a FIRST robot. The roboRIO's internal regulation was designed so that the roboRIO can be connected to any 12V PD circuit. I'm pretty sure the rules will specify that you use the blue circuit on the end of the PD, though.
Greg McKaskle
Unread 16-08-2014, 16:32
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
The shells look very nice! They all look like very quality components!
Can't wait for CAD models. Anyone know when they're coming?
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 16-08-2014, 16:51
on walkabout
Thanks for the link. I'll give that a read. I'm sure the roboRio will be required to be on the 10A fused connection for protection.
I believe the old PDB kept the 24V supply up with a battery even as low as 4V (or maybe I'm making that number up). When it says the roboRio minimum is 7V, is that the same sort of bottom end for the regulator inside? The battery pretty much never drops below 4V, but can certainly get pulled below 7V if several things are going wrong at the same time, and I'd hate to add a controller reboot to the list of consequences. How does roboRio brownout/reboot compare to that of the regulated supply on the old PDB?
Unread 16-08-2014, 17:09
The brownout behavior and voltage levels were a major testing area of the alpha. I'll let the alpha teams describe the details.
The goal is to keep the controller from rebooting for as long as possible. This includes having the motor controllers and possibly other components shut down when necessary to keep power to the roboRIO. It may be tweaked further during the beta, and again, I'll let the teams describe their experience with it.
Greg McKaskle
Unread 16-08-2014, 18:05
Michael Hill's Avatar
Greg McKaskle
Any reason a backup battery wasn't implemented for this? I believe this was the exact reason it was included in the old IFI control system. I understand why it wasn't included with the cRio, but the RoboRio is a custom unit.
Unread 16-08-2014, 18:41
As one of the SW guys, the best reason I can give is .. because FIRST and the HW guys thought this was a better approach.
I'll let one of them or one of the alpha/beta testers describe more about the behavior.
Greg McKaskle
Unread 16-08-2014, 18:44
I hated the IFI backup battery.
It was another thing for teams to keep track of and charged without an easy indicator of when it was depleted or the contact was bad.
They always seemed to be dead for 50% of the teams I helped at events.
Unread 16-08-2014, 18:57
It doesn't have to be that way though. Those are all completely solvable problems.
Unread 16-08-2014, 19:02
coolhandluke811's Avatar
coolhandluke811 coolhandluke811 is offline
FRC #0811
coolhandluke811 will become famous soon enough
I was told in an email by CRE that CAD would be released as soon as beta teams received their parts. So....yeah.
Unread 16-08-2014, 19:04
Everything is a solvable problem. It's the perspectives that differ.
From one perspective the best solution was to be rid of the added operational complexity and make the system more tolerant to low voltage conditions.
When the voltage gets that low, the robot is not going to be going anywhere anyway.
Unread 16-08-2014, 19:16
AKA: Nick Aarestad
So they should be coming soon! Good news!
tumblr | twitter
VEXU UMN (2015-??)
Unread 16-08-2014, 19:29
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
And the roboRIO models are already available.
