Go to Post "The hardest part about building the robot is figuring out what to build..." - Jeff Waegelin [more]
Unread 17-08-2014, 19:11
Team3993Tom Team3993Tom is offline
FRC #3993
Team3993Tom is an unknown quantity at this point
First time java programming
Ok to start, we are a team that has only used labview and would like to change to java before next season. We have no idea what program we should use, how to program in Java, and how to send code or set up the Crio to use java. Help in those areas would be most appreciated.
(pardon the poor grammar and spelling)
Unread 17-08-2014, 22:33
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: First time java programming
This site tells you mostly everything you need to know
https://wpilib.screenstepslive.com/s/3120/m/7885
But you will need some basic java knowledge.
Unread 18-08-2014, 22:34
FRC #3993
Thank you, its a good start.
Unread 19-08-2014, 11:48
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Do realize that is the 2014 directions. The roborio will use the eclipse IDE rather than Netbeans. While a lot will be the same, obviously some will be different. For this reason, it might be better to wait a year for the switch. You might look to see if there is a Java beta tester close to you who can show you what will be in use in 2015.
Unread 19-08-2014, 18:34
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
You can use eclipse with the 2014 cRIO (to get a head start on using eclipse for 2015).
We have been using eclipse for Java FRC development since 2012, even though it was never officially supported by FIRST.
Here are the instructions to set up eclipse for 2014 FRC.
http://www.chiefdelphi.com/forums/sh...d.php?t=110420
Note: Setting up eclipse will be much easier in 2015, now that FRC is providing official support for it.
I am also one of the many beta tester, so if you have any particular questions, let us know.
Regards,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
