Go to Post Chief Delphi down for a few hours ON A WEEKEND??? This is MADNESS! - [more]
Unread 18-08-2014, 15:11
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: New swerve CAD from 2471
Unread 18-08-2014, 15:47
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: pic: New swerve CAD from 2471
Seems like a pretty daring design, having the modules on the outside. Have you made sure that the modules won't be affected by a hard hit?
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 18-08-2014, 15:55
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
I'd be worried about the strength of using pocketed 1/8" wall tubing to support the weight of the robot and the forces from the wheels. Most swerves I've seen with a similar coaxial setup use 1/4" plate.
I like the originality of you module packaging, why did you choose to do it this way?
Why have the modules on the outside? It would seem like your frame would be stronger and you'd have more electronic placement space with the framerails on the outside.
-Adrian
Unread 18-08-2014, 16:15
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
It is a somewhat daring design. Although there will be structural bumpers outside of the modules, that will distribute impact forces evenly across two modules and the surrounding welded frame.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 18-08-2014, 16:32
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
-Adrian
Last year, in the off-season, we ran a coaxial swerve drive made from 0.1875" wall aluminum extrusion. It didn't have any problems with structural integrity, and it had a much harder job to do. The reason I believe this design will also not have any issue is that the modules are cut from a single piece of extruded aluminum, and they are closely supported by the 0.125" welded frame on both top and bottom.
The packaging was chosen to minimize the distance that the modules will have to carry the weight of the robot, before distributing that force to the frame. As well as to minimize weight and maximize space in the center of the robot.
If the frame were on the outside, there would have to be an extra inch of space left empty in the belly pan around the modules in each direction. This space would be necessary to remove the swerves, because the frame is C channel that raps around the top and bottom of the module.
Thanks for your questions and feedback!
Unread 18-08-2014, 17:41
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Very cool! Will this make it on a BunnyBot this year?
Also, what is your reduction off of the CIMs? It looks like it will be on the fast side but maybe that's what you intended.
Unread 18-08-2014, 18:17
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Also, what is your reduction off of the CIMs? It looks like it will be on the fast side but may be that's what you intended.
Thanks! Yes, the plan is to test this out on a BunnyBot this fall.
The reduction is quite fast, although it's a bit slower than what we ran last year. The final reduction is 3.6:1, or approximately 2.4 inches per revolution of the CIM shaft.
Unread 18-08-2014, 19:22
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
FRC #2517 (the green wrenches)
Team Role: CAD
kk052 can only hope to improve
Hmmm... looks somewhat similar to one I've seen before...
just make sure the C brace the swerve's attach to are not shaved completly flat, or you might lose strength in the frame. also are you not worried that the belt might slip off the larger gear because its not flanged?
also most years bumpers must be supported every 8 inches do they mount on the swerves, or is there an additional bracket that is hidden?
FRC TEAM 2517 The Green Wrenches
2012 Autodesk Oregon regional
Chairman's award, Entrepreneurship award, Pit safety award
2013 central Washington regional
Imagery award, Pit safety award
2014 we won something but i forgot
-"the CAD is only accurate if you machine it accurate!!!"
--"its not working because your doing it wrong!!!"
---"is it really ok to put an acronym in an acronym?" (FIRST)RC?
Unread 18-08-2014, 20:32
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Well you certainly won't be winning any pushing battles going that fast but on the up side, if it works as well as last year, maybe you won't need to!
Unread 18-08-2014, 22:26
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
We proved this year that you don't need to push back to win a pushing battle just not get pushed.
I still think its geared a bit high.
Unread 18-08-2014, 23:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
It's geared for around 14fps adjusted it looks like. That's not too fast.
Even so, I would be worried about collisions at that speed on the modules. A hard hit on a corner could render you immobile, as well as costing a few hundred dollars. Even if nothing breaks mechanically, encoders are pretty fragile.
With frame perimeter rules, are you really gaining extra room this way?
Unread 18-08-2014, 23:28
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
It's also going to impact acceleration. I suspect being geared that high the robot will seldom actually get to top speed during a match before having to change direction. Usually robots geared that fast will have six CIM drive trains just for that reason.
Unread 19-08-2014, 13:37
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I think you'll find that a robot geared for 14 fps on 4 cims will have plenty of power to accelerate quickly. Our comp bot did fine this year, and it was geared for about 18 fps. Our bunny bot was geared even faster that that, and it won. so obviously, it will depend on the game, but in my opinion, 14 fps isn't "too fast".
Unread 19-08-2014, 13:42
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Originally Posted by asid61 View Post
...Even so, I would be worried about collisions at that speed on the modules. A hard hit on a corner could render you immobile, as well as costing a few hundred dollars. Even if nothing breaks mechanically, encoders are pretty fragile.
Last years modules only costed about $220 each. I expect this years to be a little higher, but still not too bad. the encoders we are using are non contacting magnetic absolute encoders, so I doubt the would break. Although, if they did, they only cost about $10.
I'm not really sure what you mean by "With frame perimeter rules, are you really gaining extra room this way?"
Unread 19-08-2014, 13:48
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Your robots were certainly zippy! I'd love to know how long it took the robot to get to its terminal velocity (and what that velocity is.) Maybe that would be a good fall project for your software folks graphing speed vs time as measured by an encoder on your 2014 robot.
Going that fast will also impact power consumption during acceleration. I wonder what the peak current is.
