Go to Post I predict the champion drive teams at each event of the 2011 season will consist of vertebrates. - Taylor [more]
Unread 18-08-2014, 15:12
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: 6 CIM swerve CAD from 2471
Unread 18-08-2014, 15:13
Andrew Lawrence
Posts: n/a
Re: pic: 6 CIM swerve CAD from 2471
The pocketing in the tubing loses a lot of strength that could cause the module (and by extension your frame) to bend. If you want to lighten the module, mill down the tubing walls from 1/8" to 1/16". You'll still lose weight without losing the structural integrity of the solid tubing.
Unread 18-08-2014, 16:38
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Great idea! I'll do some stress analysis on this, and see where it stands. Although I doubt it will be stronger in the directions that I'm specifically worried about for those side walls. considering the way that it would be integrated with a frame.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 18-08-2014, 19:30
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
FRC #2517 (the green wrenches)
Team Role: CAD
kk052 can only hope to improve
hmm how will this cope if one wheel needs to spin faster than another?
FRC TEAM 2517 The Green Wrenches
2012 Autodesk Oregon regional
Chairman's award, Entrepreneurship award, Pit safety award
2013 central Washington regional
Imagery award, Pit safety award
2014 we won something but i forgot
-"the CAD is only accurate if you machine it accurate!!!"
--"its not working because your doing it wrong!!!"
---"is it really ok to put an acronym in an acronym?" (FIRST)RC?
Unread 18-08-2014, 19:39
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Do forgive me if this is a basic question, as I haven't dealt with a swerve drive since 2011 and my memory of that is a bit hazy, especially in terms of controls, but in what situation would this be necessary with a swerve? Doesn't the ability to turn the modules negate the need for moving one wheel (or set of wheels) faster than the other, as is necessary with a traditional skid-steer?
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 18-08-2014, 19:45
kk052's Avatar
CAD extraordinaire
AKA: kyle lundquist
Team Role: CAD
if you want to pivot around a specific pint you need to move the wheels close to that piont at a different speed than the wheels farther, however you may be able to get away with basic movements by just direction, but the wheels would skid a lot.
Unread 18-08-2014, 20:22
If there are two of these, you could do that between the sides fairly easily.
But I can't think of many cases where a swerve would need to pivot around a specific point (that is, center of rotation) that isn't the center of the robot. Depending, of course, on the swerve, and what's on top of it. There have been some very good swerve drives that could not pivot at all. (They had other means of getting aligned with targets and all that--or not, as the case may be.)
Unread 18-08-2014, 21:01
kk052's Avatar
CAD extraordinaire
AKA: kyle lundquist
Team Role: CAD
we have used a off center pivot on our code before, (it would rotate around the two front corners dependent on which button is pushed) witch was insanely useful to pivot the robot around other robots, you could also use an off center pivot to "lock" the distance on to whatever goal the game has. off center pivot's has some uses, but not needed, just helpfull.
Unread 18-08-2014, 21:31
AKA: Nick Aarestad
Thank you. Now I remember 1717's swerve in 2012 and the pivot maneuvers they had. I think the usefulness of pivots would be highly variable on the game though.
tumblr | twitter
VEXU UMN (2015-??)
Unread 18-08-2014, 23:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
What's the weight with what is shown in the picture?
Where are the turning encoders going?
Cool design. I likw the integration with the frame a lot. I would be a little worried about collisions, but you would need to test on that.
Unread 19-08-2014, 02:44
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
The weight for everything in the picture, should be about 15.5 lbs.
The encoders are a little hard to see in the picture, but they are there. they are mounted to the top of the upper gearbox frame, facing downward.
You're right that I will need to test this design to make sure that it holds up, but i'm pretty sure that collisions will be a non-issue.
Unread 19-08-2014, 12:47
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
It is hard to see, but I am concerned that the belt may get caught between the gear and the middle CIM pinion and get chewed up. Is there a flange on the underside of those pulleys? or is there some other way to insure the belt does not ride a little too low?
Unread 19-08-2014, 13:30
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
You're concern is warranted, and in the CAD there are some washers that hang over either side of those pulleys to keep the belt in place. Although, I'll admit that if I were to try and build this design, I would replace all those pulleys with fanged versions. I CADed this in a very short amount of time, when I didn't have good internet access, so I used pulleys that T already had CAD for.
Assuming that the robots center of rotation is somewhere along its mid plane. (I've found a reason of it to be anywhere else) Then a robot with this drive base would be able to translate without any skidding, or rotate without any skidding, but it would have a limited amount of skidding when rotating and translating at the same time. I say "limited", because the module is only 20" long and the other side length of the robot would most likely be about 35".
