Go to Post The people that have posted in this thread are intelligent and I know that when they talk, I need to listen. - ATannahill [more]
Unread 12-08-2014, 19:26
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
Imaging Tool not finding Crio
As the title states, the FRC Crio imaging tool is not finding the Crio connected to the computer. With all the IP address and Subnet address correct the Imaging tool still does not find it. When I open the Driver Station the Crio shows communication with the DS. Right now it is configured for Labview but I need the Crio to be imaged for JAVA.
Unread 12-08-2014, 19:37
Jared's Avatar
Jared Jared is offline
Re: Imaging Tool not finding Crio
Make sure you're connected with an ethernet cable instead of wireless.
Also, try going to network and sharing center, adapter settings, and disable all network adapters that aren't your ethernet adapter.
Unread 12-08-2014, 19:44
AKA: Naresh Hing
I am connected via an ethernet cable. I have disabled all the adapters except the LAN adapter and still the same results.
Unread 12-08-2014, 19:51
Jared's Avatar
Weird.
What is the IP address and subnet mask of the computer?
If you go to adapter settings, right click on adapter, properties, IPv4, properties, advanced, do you have multiple ip addresses assigned to the computer? For some reason, I've seen teams have random issues caused by this.
Is your firewall configured to allow imaging tool to connect?
Unread 12-08-2014, 19:59
AKA: Naresh Hing
Weird.
The IP address is 10.16.1.5 and the subnet is 255.255.255.0. I do not have multiple IP addresses on the adapter. My firewall is turned off.
Unread 12-08-2014, 20:03
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Can you ping the CRIO?
Jim
Unread 12-08-2014, 20:05
AKA: Naresh Hing
Yes, I am able to ping the Crio.
Unread 13-08-2014, 11:30
AKA: Naresh Hing
I was able to reimage after leaving the program running to search for the crio for 45 minutes.
Unread 13-08-2014, 11:51
Jared's Avatar
Have you tried imaging with the classmate laptop? A while ago, I remember a team having a similar issue (using an HP laptop), which they think was caused by the method of scanning not playing well with a specific network adapter.
A solution can be to reset the IP address of the cRIO before reimaging. I find that the cRIO is found much quicker if it has the default IP address than our team address.
I know we can't image well with my laptop because the network adapter doesn't reconnect properly between cRIO reboots, so the connection times out.
Unread 13-08-2014, 21:13
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I've had success imaging with a crossover cable running straight from a laptop to the cRIO.
Unread 19-08-2014, 07:39
The problem I've seen with HP laptops tends to be that they bring down the ethernet interface eagerly, such as when an attached cRIO is rebooting. Then they are slow to bring it back up. This is often improved if the cRIO and laptop are both plugged into a switch such as the DLink.
Greg McKaskle
