Go to Post ....you can't go to a single FIRST event without someone saying "Hey, Look! It's SuperNerd!" - [more]
Unread 18-08-2014, 20:01
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
pic: 6-sided tank drive
Unread 18-08-2014, 20:02
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: 6-sided tank drive
Not sure if the 1*1 stuff supporting the bumpers is vexpro versachassis stuff, but if so I'd double layer it or use thicker material. That stuff is really thin for a bumper frame.
Unread 18-08-2014, 20:24
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
evand4567 is an unknown quantity at this point
If it's welded together with 1/8" walls, it shouldn't be a problem
Unread 18-08-2014, 20:28
Olin class of 2019
right; the 1*1 vexpro stock has much thinner walls. I'm not sure which it is.
Unread 18-08-2014, 22:47
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by evanperryg View Post
If I may ask, why are your angles "149.07 degrees" and "105.46"? You will never ever need that kind of precision in a FRC situation, especially on a frame which will be bashed and smashed into every 6 seconds anyways.*
Even with a chopsaw/bandsaw/mill/cnc mill/whatever, it is certainly a better real world design if you round those off to some amount. How critically important is it that you are exactly perfect? In your robot's frame, just about never.
Also, just a recommendation, While it is less pretty, using 1/32" (or preferably 1/16" or 1/8") increments instead of decimals is much less of a hassle for whoever will measure the parts, and just a couple clicks in CAD
Not trying to be a wet blanket on this design, it certainly is cool, but it would be beneficial for every party involved if you simply rounded to the most convenient dimensions, where there will be an immeasurable difference in performance, but a significant improvement in both engineering design quality, and manufacturing
*after all, the entire point of a 6 sided drive like this is for the very purpose of escaping trapping t-bones"
Unread 19-08-2014, 07:13
evanperryg's Avatar
AKA: Evan Grove
The weird angles are the result of the not-weird side lengths. The tolerance should be pretty high.
Oh, and it's welded 1/8" aluminum tubing
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 19-08-2014, 10:06
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Does it meet the 110" rule?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 19-08-2014, 10:14
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Question for you, how exactly is this useful? I love the design, it looks pretty fancy, but in the long run it will amount to more work and not be worth it if doesn't have any specific benefits compared to a 4-sided tank drive.
Unread 19-08-2014, 11:45
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
This design is helpful for avoiding t-bone pins and defense in general. Also hexagons have a greater area to perimeter ratio.
Unread 19-08-2014, 12:36
I am Dave! Yognaut
AKA: Brian Bray
If you are going to forgo the square, a hexagon is really the best option for a traditional tank drive. For things like holonomic and 3 wheeled swerve, other n-gons may be appropriate.
Circles are mathematically the optimal perimeter-to-area figures, but would be difficult to make, and a nightmare to put bumpers on.
Unread 19-08-2014, 12:41
AdamHeard's Avatar
Lead Mentor
You can more efficiently optimize the use of the perimeter sizing by moving the front/rear wheels to inside the frame, and making the center wheel wider.
Unread 19-08-2014, 12:45
g_sawchuk's Avatar
Hmm.
FRC #4476
Ah, good point, although T-Bone pins are rather rare. However, would the bot be able to play an effective defense? For example, if the objective was to T-Bone a bot of the other alliance, it would require rather exact precision as to hit the bot right in the middle of their side.
Unread 19-08-2014, 12:52
I am Dave! Yognaut
AKA: Brian Bray
I saw them happen quite a bit this season. Robots waiting for the ball from a human player after a truss were prime candidates for being bulldozed back to the inbound station
Unread 19-08-2014, 12:53
AdamHeard's Avatar
Lead Mentor
Not necessarily, if they are hit square to an angled face, at least the drivetrain is not perpindular to the t-boning robot.
T-bones happen a LOT at the high level of play in certain games.
Unread 19-08-2014, 13:15
g_sawchuk's Avatar
Hmm.
FRC #4476
Fair enough. It is true that they happened this season a lot, but this was due to the lack of mobility some robots had as they waited for the ball from the human player. On a good driver, t-bones tend not to be effective as a good driver will stay in motion as much as possible.
