Go to Post FIRST, grant me the serenity to accept the things I cannot drill, Courage to drill the things I can, And wisdom to know the difference. - Bill_B [more]
Unread 08-20-2014, 10:33 AM
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
pic: 303 Prototype Sheet Metal Drivebase
Unread 08-20-2014, 10:36 AM
Tanay T's Avatar
Tanay T Tanay T is offline
FRC #0303 (TEST Team)
Team Role: Tactician
Tanay T is an unknown quantity at this point
Re: pic: 303 Prototype Sheet Metal Drivebase
I just wanted to start a discussion to see what others had to say about this design, particularly on the geartrain. We had bad experiences with belts this year, and in MAR several other teams have done all gear drives particularly well (341 and 25 just to name a few). Any responses would be helpful.
Crikey! It's a crocodile!
Unread 08-20-2014, 10:59 AM
Step 1 when starting sheet metal - talk to your sheetmetal shop about best practices with bending, material selection, and structural integrity.
Unread 08-20-2014, 11:12 AM
Tanay T's Avatar
We got that down, and the sponsor has approved all the stuff on that render. Any criticism on the geartrain or anything else is much appreciated.
Unread 08-20-2014, 11:24 AM
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Can you show an image of your geartrain and provide details on what gears/ratio you are using ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 08-20-2014, 11:26 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
This looks really robust and cool. I especially like the aesthetics of the gears.
A few questions I have:
How do you intend to incorporate bumpers into this design?
Is the bellypan aluminum as well? If so, how will you mitigate electronic component isolation issues?
Why did you make the right-left sides congruent rather than mirror images?
What issues did you have with belts that led to your dislike?
Hi!
Unread 08-20-2014, 11:32 AM
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Looks good,
Exposing a portion of wheels on the front/back will allow the drive train to climb a obstacle better. Consider a angled bottom front and aft.
A staggered perf pattern allows for more weight reduction and will help prevent oil canning.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 08-20-2014, 12:48 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Without seeing an image of the gears more exposed it's difficult to give a good review of the system overall. Just looking at what is visible though it looks like the system would certainly run.
I am curious about a few things:
  1. What size gears are used on the wheels and idlers?
  2. What is the distance, center to center, between the wheels?
  3. Are the wheels on a flat plane or angled?
  4. What type of gears do you plan on using (Vexpro? AndyMark? Steel? Aluminum?)
  5. What are the overall frame dimensions
  6. How wide are the drive modules?
Unread 08-20-2014, 03:42 PM
TylerS's Avatar
AKA: Tyler Stark
The shifters are just WCP 3 cim dog shifters, we haven't decided on the ratio with that yet. The gears in the drive modules are all the same so it's just 1:1.
Thanks! Honestly thought I'd get a lot more criticism for the design then I have so far.
We are thinking of using one piece bumpers that are attached with thumb screws to the front and back. That idea hasn't been fully flushed out or CADed yet so it's subject to change.
Yes it's aluminum, all of the control system parts are electrically isolated themselves if we don't have issues with shorts in our testing in the pre-season we probably won't do anything special to isolate them.
Not sure what you mean by congruent vs. mirror image.
We have had issues with tensioning in the past and rarely belt snaps. We figured if we could sacrifice the weight then we might as well do away with them.
Originally Posted by roystur44 View Post
Looks good,
Definitely going to do this with this design at some point. Optimally I'd like it to be able to support wheels up to 6in in diameter.
Something else that will be done
40t
Not sure off the top of my head, will have to check the CAD tonight
Center two wheels are dropped 1/8in since we have had success with that drop using 6 wheels
Vexpro 40t aluminum with the hex bore.
Dimension wise all I can remember off the top of my head is that the perimeter comes out to 111.2in
Unread 08-20-2014, 06:43 PM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
For the hole pattern, could you stagger the hexagons so that there are only thin lines of metal between the hexagons? Like this:
_____
__ / \
/ \ \_/
\_/
Unread 08-21-2014, 07:19 AM
Taylor's Avatar
AKA: @taylorstem
Perhaps I'm looking at the render incorrectly, but it looks like the gearboxes are offset from each other (the one on the robot's left is more forward, the one on the robot's right is more aft) rather than being directly across from each other. I assume this was designed so that the right and left sides would be congruent to each other and easier to manufacture, but I would think if they were lined up, the bellypan would be more uniformly accessible. I was hoping you would speak about why you decided to design it as you did.
Hi!
Unread 08-21-2014, 09:18 AM
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I would be seriously worried about frame rigidity, I would over-design and avoid any type of bend.
Where is the CG?
Unread 08-21-2014, 12:15 PM
This frame looks similar to 971's 2013 drive base. We just released CAD of that frame. Take a look and see if it gives you any ideas. It has treated us very well, so you are off to a good start.
Off the top of my head, your front and back frame rails aren't beefy enough. Make the top flange like 1.5 - 2" long, and add a bend off the back of it for strength.
Any reason why you didn't leave the wheel cutouts as a hole with metal all around it rather than cutting it out to the edge like you did? It will be stronger, especially in the corners.
I like to leave some holes in the top of the frame rail so I can see things like tread wear, and belt (or gear in this case) health.
Unread 08-21-2014, 01:32 PM
TylerS's Avatar
AKA: Tyler Stark
Oh yes you're correct, I decided to do that to keep the CG dead center.
I actually have been looking at that CAD among others for inspiration since this is only my second attempt at an FRC drive-base.
That's a good point and I'm going to change that before we send it off to be manufactured.
Another good idea that I'll probably add. Thanks for all the suggestions, this is the reason I posted here so we don't have to waste our sponsors time and moeny.
Unread 08-22-2014, 12:14 AM
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
I am not certain, but I think daisy only had 2/4 wheels per side directly driven this year. Dustin may have to correct me on that.
Anyway, one thing to be super careful about is efficiency. 341 puts a ton of effort into really precise machining, speccing parts/materials, and maintenance, and I would assume 25 does the same. Lots of idler gears means not only a lot of weight and a lot of money, but it means a lot of inefficiency.
If you are willing as a team to put this much effort into improving drivetrain performance, IMHO the effort would be better placed learning how to correctly implement timing belts (hint; dead space center to center, no tensioners). They are efficient, light, and far more durable than they are often given credit for.
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
