Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
Unread 20-08-2014, 16:07
SeanFitz's Avatar
SeanFitz SeanFitz is offline
1st Year Mentor
FRC #2877 (LigerBots)
SeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of light
Which Gearbox Should I Use?
So my team wants to build several different chassis this fall to find which we think is best. Anyways, I am leading the 6-CIM drive-train group. The idea I'm working on is a 6 wheeled design with a dropped center wheel direct driven by a 3-CIM gearbox.
I went on VEX to look at my options for gearboxes, and now I'm stuck. I found these gearboxes online, and I think they would work well. The only problem is that I have no idea what gear reductions I should buy. Basically, I want it to be two speeds, one for driving fast, and one (more importantly) with a lot of torque to push other bots around. What's your opinion on what I should get?
And thanks in advance to anyone who posts an answer
Unread 20-08-2014, 16:22
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Which Gearbox Should I Use?
If you want something VERY reliable, and easy to use for a WCD use this http://www.wcproducts.net/wcp-shifter-3cim/ Also.. gear ratio calculator! http://www.wcproducts.net/how-to-drivetrain/
Unread 20-08-2014, 16:32
Knufire Knufire is offline
You need more quantifiable goals for the drivetrain. When you can put things in numbers, it's much easier to choose. For example, the calculator that thatprogrammer posted has a rough calculation on time it would take to cover a certain distance at every gear ratio. If it was 2013, a logical choice would be to pick your high gear to minimize the time between the feeder station and your shooting location. If it was 2014, what distance would you want to cover in the least amount of time? Or would there be some other factor that you would want to maximize your drivetrain toward? There is no correct answer; it is both dependent on the game and your strategic choices for the game.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 20-08-2014, 16:41
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
It's great to see that your team wants to experiment in the offseason with different drive trains! My team tried building a 6 wheel WCD in the off season a few years ago and probably wont go back for a long time.
It's hard to say what gear ratios you need without knowing anything else about your drive train plans. Are you planning to have a directly driven center wheel? Live axle/dead axle? And most important for determining your gearing is what wheel size are you planning on using? Before we recommend a gear box or a gear ratio we need to know more about your set up.
If you are asking for generalized speeds for how fast your high and low gear speeds should be, it is generally considered for a low gear the gear ratio should be set for somewhere around 4-6 (maybe even a little higher) feet per second. And a high gear around 14 -16 feet per second. (Some teams gear their high gear for 18 - 20 fps even). It really depends on the game to determine the exact ratios. If you feel that there will be a lot of defense like this last year then having a low gear on the bottom end could be of value, but if the field is also open and you need to move fast having a upper end of the high gear values is also very realistic.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 20-08-2014, 16:45
SeanFitz's Avatar
1st Year Mentor
First off, thanks for that calulator, it's very helpful.
And now for a another question.
The only thing that seems to change between the 2-CIM and 3-CIM gearboxes is the Force @ 40 amps box. (If I'm wrong in my next assumption, please feel free to correct me. I'm a mechanical engineer, not electrical) Now if there are less motors on the robot (I.E. 4 CIMs vs. 6), wouldn't there be a higher amperage for those less motors? If so, wouldn't the 2-CIM gearbox be producing more than the 3-CIM?
Unread 20-08-2014, 16:56
SeanFitz's Avatar
1st Year Mentor
My plan so far is a 1/8th dropped center wheel direct driven by the gearbox and the two other wheels either belted or chained to the center wheel. All wheels would be 6".
What I really want is a gear ratio that can give me a lot of torque. I've noticed over my years in FIRST that most teams either get pushed around or stalemate with other robots on the field. Teams that can push others around are always recognizable and are almost always picked for alliances, even if it's just to play defense (Team 2013 was a perfect example of that this year). And even in games where speed is important (2013), I always see cases where being able to downshift would have given a team a boost to victory.
Unread 20-08-2014, 16:58
AKA: Ahad Bawany
no team (None)
True. AN advantage of most 3 CIM gearboxes (If not all) is that you can also test using a mini CIM and two CIM motors. Test and see what amount of torque works for you.
Unread 20-08-2014, 17:27
SeanFitz's Avatar
1st Year Mentor
Originally Posted by BBray_T1296 View Post
That box implies force @ 40 amps per motor. Since the CIM fuses trip at 40 amps, you can draw 120 amps total on a 3 CIM drive vs 80 amps on a 2 CIM.
It is also important to note that the 120 amp main breaker can indeed sustain 240 amps for several seconds
But if the main breaker trips at 120, how does a drive train even run at all. Wouldn't 4 CIMs be running at 160 amps for the whole match?
(Again, not an electrical engineer, just a confused mechanical one )
Unread 20-08-2014, 18:38
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
The main breaker has to be over 120 amps for a while before it trips. If I recall correctly, it will take about 40 seconds for it to trip at 240 amps and about 5 seconds at 500 amps. The motors in your drive train will probably each spend most of their times under 40 amps of current in a match.
Unread 20-08-2014, 18:42
Michael Hill's Avatar
Datasheet for the breaker: http://www.cooperindustries.com/cont...UITBREAKER.pdf
Unread 20-08-2014, 20:14
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The CIMs don't need to run at full power all the time, only when they are in a pushing match or similar situation. When a robot is at rest, the CIMs actually use no power.
Unread 20-08-2014, 21:22
SeanFitz's Avatar
1st Year Mentor
About those 40 seconds: is it cumulative or at one time? If it is cumulative, I'm going to have to seriously rethink the whole 6-CIM chassis.
Unread 20-08-2014, 21:43
The main breaker actually trips based on temperature. Saying xx amps will trip the main breaker in xx seconds means that xx amps for xx seconds will heat up the breaker enough for it to trip. This time will be shorter if the breaker starts hot and longer if the breaker starts colder.
Unread 20-08-2014, 21:48
AKA: Ahad Bawany
no team (None)
To prevent overheating, you can use compressed air to cool the breaker between elimination matches.
Unread 21-08-2014, 09:23
SeanFitz's Avatar
1st Year Mentor
So if it's about temperature, would the various components near the breaker on the bot heating up affect weather or not it trips? Also, once the breaker does trip, is it true that it becomes more likely to trip again at a lower temp?
"A good driver always beats a good robot"
2015: 2 Chairman's Awards, 1 Finalist Medal, 1 St. Louis Alliance Captain Hat (7th Seed Newton)
2014: 1 Blue Banner, 1 Finalist Medal, 1 Amazing time in St. Louis.
