Go to Post Not all creativity is visible or mechanical! - dtengineering [more]
Go Back   Chief Delphi > Technical > CAD
Unread 21-08-2014, 19:59
Tanay T's Avatar
Tanay T Tanay T is offline
FRC #0303 (TEST Team)
Team Role: Tactician
Tanay T is an unknown quantity at this point
AutoDesk Installation Problem
Hello,
So I am a "newbie" when it comes to CAD software, and our team is going heavily into it, so I tried to download AutoDesk Inventor.After installing the Student Program, I began to install. However, I found that my C: drive was extremely low on memory and could not handle the download (as seen in the attached picture). I know that I have a lot more space on the D:, but even if I switch it in the installation window and retry, it gives the same message. I have changed the default installation folder in Windows Registry, but that did not seem to work. Perhaps someone has had this problem before? Or maybe I am the only one that sucks?
Crikey! It's a crocodile!
Unread 21-08-2014, 22:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: AutoDesk Installation Problem
I believe Inventor does need some space on the same drive as Windows, at least for Application Data and such. May I ask, why is your C: drive so incredibly small? Can you repartition?
Unread 21-08-2014, 23:37
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Ask Autodesk support they are really helpful with these issues. They got back to me in less than a business day via email.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
