Go to Post The driver must have a relationship with the robot, the driver should talk to the robot, speak soft encouraging words to it. Pet names are also a good idea. If the driver does not love the robot, how can the driver learn to trust the robot. - Gboehm [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 22-08-2014, 08:58
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Re: blog; Motor Controller Options for 2015
Originally Posted by ToddF View Post
My biggest concern regarding the integrated leads is that installing connectors on the ends of the wires constitutes a modification away from COTS state. This means that use of a particular motor controller on a competition bot will (under current rules) only be legal during the year in which the connectors were attached. Currently, we utilize previously purchased Talons as spares. In a pinch, we have even raided previous year's robots for motor controllers (not at an event). With these new ones, unless the rules change, they have a built in expiration date. If you've already attached connectors, you can't use them on a competition bot after the next kickoff day. And cutting off the connectors and putting on new ones isn't legal because just cutting off the connectors doesn't return the wires to their original length. I think now is a good time to revisit the rules regarding reuse of parts. It was bad enough that we couldn't reuse CIMS, but CIMS are fairly cheap, and don't require swapping out very often. Not being able to reuse motor controllers is going to hurt our pocketbook.
Was this ruled on officially by FIRST that teams could not reuse CIMs after crimping on a connector? I don't know that I've ever seen that in the Q&A. I'm not going to throw any teams under the bus but lets face it, teams re-use CIMs.
You are definitely right about this given a pure legal reading of the rules though. I'd just like to know if FIRST has ruled on it.
  #77   Spotlight this post!
Unread 22-08-2014, 09:29
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I can't imagine that FIRST would rule in a way like this. It would be counter to the way teams have operated for years.
  #78   Spotlight this post!
Unread 22-08-2014, 09:36
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Todd,
What rule would not allow CIM reuse?
David
  #79   Spotlight this post!
Unread 22-08-2014, 09:57
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The rule Todd is referring to is (from 2014):
R13
ROBOT elements created before Kickoff are not permitted.
This is clarified in a blue box,
Please note that this means that FABRICATED ITEMS from ROBOTS entered in previous FIRST competitions may not be used on ROBOTS in the 2014 FRC
along with the definition found in the glossary:
FABRICATED ITEM: any COMPONENT or MECHANISM that has been altered, built, cast, constructed, concocted, created, cut, heat treated, machined, manufactured, modified, painted, produced, surface coated, or conjured partially or completely into the final form in which it will be used on the ROBOT.
So, from a strict reading of the rule, crimping or soldering connectors to the ends of leads or even cutting the leads is an alteration, and makes an item (a CIM motor, one of these new controllers, etc) illegal in future years.
Now, I ask all of you two questions. First, do you think it's the intent of the rules to make a CIM motor illegal because you spent 30 seconds adding a pair of 50 cent connectors on it? Second, do you think your inspector, LRI, or any team at your event is going to know or care?
When I read the rule, two possible intents come to mind (note that I'm not the GDC, so I could be wrong about either/both of these):
The first is fair play - we don't want veteran teams having an advantage over rookie teams by being able to pull out a robot from 7 years ago that can already play the game, and instead of spending 6 weeks build one get to spend it improving and driving one. Veterans already have enough of an advantage through their experience with FIRST and through having people (mentors, upper classmen or graduates) with first hand experience in games similar to those we're playing now (for example, the similarities between Arial Assist and Over Drive).
The second is educational - we want the students on the team this year to have the experience of designing and building a robot, not just using what someone else built before them. I've heard before (on here? In LRI training? Not sure) that reusing an assembled gear box (which ships from the supplier unassembled) is illegal... but taking that gear box, breaking it down and then reassembling it during the build season makes it legal because you returned it to the form it arrived in. That strongly implies that the educational experience of assembling a gearbox and seeing how it works is important with this rule.
As an LRI, even if I was 100% certain that a team reused a CIM motor or speed controller and the connectors they had on it from the previous year, I wouldn't say anything or hassle them in any way. On the other hand, if a team comes in with a shooter on it I recognize, and I can verify that it came from a previous robot, they'll be in trouble. When we went with the new sizing rules, there were several teams that had to be lectured, as their re-use was obvious - they used the previous years frame and (assuming) drive train without modification. In that case, the modifications made to make it fit within the sizing parameters was enough of a penalty and lesson for the teams in question, and we could let them play once they got it fixed (which took the entire practice day, and afterwards their mechanisms had issues due to the changes).
2016: Lake Superior WFFA
  #80   Spotlight this post!
Unread 22-08-2014, 09:58
Generator of Entropy
FRC #2973 (The Mad Rockers)
Originally Posted by D.Allred View Post
Todd,
David
R13 ROBOT elements created before Kickoff are not permitted. If you crimp on a connector you've created an element. A specific exception in R13 allowed using battery assemblies from prior years, so if there was a concern with something as simple as charging a battery being a modification it seems that crimping a connector would have the same concern.
  #81   Spotlight this post!
Unread 22-08-2014, 10:03
CIMS with crimps fall under the rule that makes any COTS part plus an added connector a non-COTS fabricated "assembly". Battery assemblies got an explicit exception a few years ago, so there is precedent for removing some restrictions on reuse.
  #82   Spotlight this post!
Unread 22-08-2014, 10:34
D.Allred's Avatar
Interesting. I never thought of it this way. Definitely one for the Q&A.
By that logic, I could reuse a CIM (and the new Talons) if I used wirenuts and avoided a crimped connector.
David
  #83   Spotlight this post!
Unread 22-08-2014, 10:50
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
By the letter of the rule connectors on a motor make it not longer COTS/Reusable, but by the intent of the rule, this entire conversation is beating a dead horse with a level that is unfortunately consistent with all things on ChiefDelphi lately.
I personally commend VEXpro and CTRE on their joint effort to produce this product, and am excited at the form factor and apparent quality, it should have a very positive impact on our wiring layout.
Perhaps they can just have connectors mounted to the motor controllers from the factory or push for a reasonable rule change (about motor leads and connectors on all motors and control hardware).
  #84   Spotlight this post!
Unread 22-08-2014, 11:29
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I agree it's not the intent of the rule but if some teams are following it to that level. There should be official clarification that they shouldn't be. They are at a disadvantage by holding themselves to a standard that I don't believe FIRST expects for them.
  #85   Spotlight this post!
Unread 22-08-2014, 11:49
magnets's Avatar
magnets magnets is offline
Agreed. They really need to publish a list that tells you what rules you don't need to follow.
For newer teams, it gets confusing.
  #86   Spotlight this post!
Unread 22-08-2014, 11:52
It's not a question about "what rules you don't need to follow"... it's about reading the rules for both the letter and intent of the law and using common sense in interpreting them.
  #87   Spotlight this post!
Unread 22-08-2014, 12:00
Joining the 900 Meme Team
FRC #0079
The issue is my view of intent is very different than your view of intent. But you can issue a red card retroactively if you find I viewed intent differently.
Rules should require intent to follow.
  #88   Spotlight this post!
Unread 22-08-2014, 12:04
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Exactly, my interpretation of the intent can differ than yours. Just like the issue with the withholding allowance and robots in the parking lot this past season.
  #89   Spotlight this post!
Unread 22-08-2014, 12:06
Using common sense as a guiding principle, would it be permissible to apply a thin film of non-curing thermal grease to the mounting surface of the new Victor SP (or Talon SRX) before bolting it to the robot?
  #90   Spotlight this post!
Unread 22-08-2014, 12:10
headlight headlight is offline
headlight is an unknown quantity at this point
It was asked in Q&A for 2014. Q454 and Q445.
Highlights:
"Installation of connectors would make the resulting assembly a FABRICATED ITEM."
"Some additional work must have been done to the part (e.g. trimming leads, adding connectors) after the 2014 Kickoff for the part to be legal per R13."
It was asked in the context of the rule that 45 lbs fabricated components (including spares) must be brought into first day of competition and inspected and that additional non-COTS items could not be stored outside the pits and used on the robot, hence the reference to the 45 lbs limit. The implication was that spare motors must be brand new in box motors with no connectors and they would be exempt from the limit.
Hopefully they straighten this out this year. Or we're going to need more motors.
