Go to Post Ooohh!! Fire!! - dlavery [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 20-08-2014, 11:39
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: 2015 Beta Testing - The Components are Here.
Originally Posted by AustinSchuh View Post
Bummer, thanks for the clarification. This just means that the 5V supply browns out, not the robotRIO's ability to read the digital inputs? I'm trying to figure out whether or not if we were to power the encoders another way, if that would fix it.
The bus switch that adjusts the signals passed to the FPGA is powered by a supply that is sourced by the buck-boost that powers the controller as a whole. That supply operates down to 4.5 V. That means that if you decide to power your encoder with a supply other than the one provided and the provided supply browns out, the signals will still make their way to the FPGA. As noted earlier, if your sensor depends on pull-up resistors (like limit switches or banner sensors or open-collector output encoders) then you will also need to add pull resistors connected to your external supply. You should be able to test this by either using the new power API to disable the 5 V supply manually or by installing a jumper between 5 V and Ground which puts the supply in protection.
  #62   Spotlight this post!
Unread 20-08-2014, 12:46
Originally Posted by Greg McKaskle View Post
There are probably others. I feel that the next step is to characterize the improvement that Joe has already implemented. I'm sure that will be accomplished in the beta. Probably quite soon.
Agreed. That is the next step. Thanks for the thorough description of what is going on. I really appreciate it.
Thanks Joe for describing the signal path to the FPGA, and working on improving the response time.
Hopefully we are all just getting worked up over nothing.
  #63   Spotlight this post!
Unread 20-08-2014, 12:49
AdamHeard's Avatar
Lead Mentor
I am an expert in that!
  #64   Spotlight this post!
Unread 20-08-2014, 23:33
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Originally Posted by jhersh View Post
The jumper only affects the DIO power pins on the built-in DIO connectors. The MXP has both power supply rails included, so the board may use either one as needed. The I/O itself in both MXP and built-in DIO is not affected by the jumper. All DIO is 3.3 V drive and 5 V tolerant.
Does this means that we can use 5v devices (provided they read a 3v3 signal as high) without any risk of damaging the RoboRIO? I'm just thinking about various sensors and custom circuits that were designed for 5v that may perform differently at 3v3. They can probably be re-designed but it would be nice if that wasn't necessary.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
  #65   Spotlight this post!
Unread 21-08-2014, 17:33
jhersh jhersh is offline
AKA: Joe Hershberger
yes
  #66   Spotlight this post!
Unread 21-08-2014, 19:37
Jared's Avatar
Jared Jared is offline
I'm looking at the power board/pneumatic bumper, and it seems to me that the pneumatics bumper has a relay/other driver built in to power the compressor. It also is powered from a fuse, which looks like
https://www.eficonnection.com/eficon.../mini_fuse.jpg , which is smaller than the spike fuse, meaning our normal 20 amp resetting breakers won't work here.
How do we replace the 20 amp fuse shown in (http://www.team358.org/files/program...mages/PDP2.jpg) that picture with an auto resetting one?
  #67   Spotlight this post!
Unread 21-08-2014, 20:00
You don't...
  #68   Spotlight this post!
Unread 21-08-2014, 20:51
Jared's Avatar
Originally Posted by RufflesRidge View Post
You don't...
If you use a 20 amp not resetting fuse, as shown in the picture and the robot's battery is a little low, it trips when the compressor starts, leaving your robot without a compressor in the middle of the match. It's happened to me before.
The people who make this know this (as the manual has an exception for this), so either I'm not understanding how this works, or their will be issues with the fuse getting blown during matches. I'm betting that I don't understand how this works, and was wondering if somebody who actually has the part knows how it would work.
  #69   Spotlight this post!
Unread 21-08-2014, 21:17
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Given both the pneumatic module and the power distribution board are connected to the RoboRIO via CAN, there is a possibility that these devices are monitoring the current to prevent fuse blowouts that the comparatively simplistic implementation "on off with a relay" on the old system couldn't compensate for.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
  #70   Spotlight this post!
Unread 22-08-2014, 00:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
To my knowledge - we didn't see any blow fuses during Alpha testing.
The CTRE guys will need to answer this one. I'll fire them an email.
  #71   Spotlight this post!
Unread 22-08-2014, 08:02
Nate Laverdure's Avatar
FRC #2363
You can get self-resetting circuit breakers in this form factor fairly easily.
Amazon
Grainger
  #72   Spotlight this post!
Unread 22-08-2014, 09:31
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
This was exactly our concern when we sat down to wire it up the first time. Fortunately, the PCM is monitoring the current on the compressor and each of the solenoid channels and will disable the channel temporarily if then current is too high. I have not heard of a blown fuse on the PCM yet.
  #73   Spotlight this post!
Unread 22-08-2014, 12:27
Jared Russell's Avatar
Taking a year (mostly) off
Originally Posted by Nate Laverdure View Post
Self-resetting breakers usually do not trip as precisely as fuses. If the downstream circuits really cannot handle >20A, even for a second, you ought to use a fuse.
  #74   Spotlight this post!
Unread 22-08-2014, 13:21
FRC #2363
Fine, but aren't we're talking about an application (powering the compressor) where self resetting circuit breakers have been used successfully for some time?
  #75   Spotlight this post!
Unread 22-08-2014, 14:53
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
With different hardware, yes. From what I've been told in the past, Vex (the makers of the spike relay) did specific testing with a circuit breaker to validate it as safe before FIRST allowed it to be used for compressors in the rules. That's the only reason teams were allowed to replace the provided fuse with a breaker for use with compressors.
For FRC usage, breakers, in general, are present to protect the wiring, not the components attached to that wiring. For this 20A fuse, it could protect the PCM from over-current if (for example) something gets shorted out... but my guess would be that the fuse is there to prevent the PDP from burning out by drawing too much current from those outputs. It's probably there to protect against a short much more than to protect downstream circuitry.
2016: Lake Superior WFFA
