Go to Post Anyone else think we're (including me) a little obsessed? The seasons over and were already onto the next one. - Bjenks548 [more]
Unread 25-08-2014, 00:47
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Question 8 sided Drive Train footprint
I have a question. Have I made an error in my math or is the 8 sided Drive Train much larger than a normal rectangle Drive train?
If I'm not wrong that is such an advantage.
Name:	8WD Footprint.png
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 25-08-2014, 00:50
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: 8 sided Drive Train footprint
No error. Angled sides also increase maximum robot footprint.
However, a lot of octagonal drive designs do not fully take advantage of this footprint. Generally, the wheels should be arraigned in a hexagonal pattern to maximize the robot footprint.
Unread 25-08-2014, 00:52
AdamHeard's Avatar
Lead Mentor
Small issues. The min bumper length is 8 inches.
The 5 inches of taper you have is hard to effectively utilize with wider track width. We found 3.5 much easier to utilize with our drive layout. Other drives will have different results.
These changes will only slightly reduce the size of your comparison.
We just tried this on our comp bot and the point you raise is one of the pros high on our list. The perimeter size rules make logically laid out octagon bases attractive.
Unread 25-08-2014, 01:01
Joe G.'s Avatar
AKA: Josepher
Not necissarily. Per 2014 rules, segments less than 8 inches are legal as long as the entire side is covered by bumper, and adjacent sides are also legally protected.
Oblarg Oblarg is offline
AKA: Eli Barnett
The optimal area you can get with a given perimeter constraint is a given by a circle. A regular n-gon becomes a better approximation of a circle as n increases.
Admittedly, yours isn't a regular n-gon, but in light of this, yeah, you shouldn't be surprised that an 8-gon gives you more usable area than a 4-gon.
"The breakfast of champions!"
Unread 25-08-2014, 01:03
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Geometry is such a lovely thing, isn't it?
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 25-08-2014, 01:07
AKA: Roger Moore
Thanks for all the replies so quickly.
I am glad I can do simple math. Now to make use of my discovery.
Stronghold
Student 2013-2016
Unread 25-08-2014, 01:34
AdamHeard's Avatar
Lead Mentor
Thanks! I overlooked that.
We can further optimize our octagon shape in the next rev...
That adds a little bit!
Unread 25-08-2014, 01:52
AKA: Eli Barnett
It can be, though it's easy to overlook its subtleties and a often pain to iron out the details.
(If you want to be convinced of this, try actually proving the seemingly-obvious thing I posted above).
Unread 25-08-2014, 03:11
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Challenge accepted!
In a regular n-gon, the central angle for each side is 180/n degrees, and if the ngon has an inradius r, the side length of each side is S=2r*tan(180/n). I proceeded to construct a isosceles triangle where the center of the n gon is connected with equal length legs to one side of the n gon. The inradius of the n gon is the altitude of that triangle. Thus, r=S/(2tan(180/n)). This means the area of that triangle is A=rS/2=S^2/(4tan(180/n)). Therefore, the area of an N gon with side length S and side number n is A=nS^2/(4tan(180/n)).
The perimeter of a n gon is p=nS. Therefore, p/n=S. Thus, A=p^2/(4n*tan(180/n)).
With p held constant, the limit of A as n approaches infinity converges upwards to the Area of a circle with radius r.
Therefore, a circle is the optimum shape for an n gon of a given perimeter, and the more sides a regular n gon has, the more closely the it approaches the greatest possible area it can have for a given perimeter.
-Plutarch
Unread 25-08-2014, 09:40
AKA: Eli Barnett
Originally Posted by DampRobot View Post
Challenge accepted!
This is one portion of the correct proof, but a crucial (and rather more difficult) piece is missing:
This proves that a circle has a greater area than any regular n-gon, and that the area of a regular n-gon approaches that of a circle as n increases. It does not show that a circle has greater area than any n-gon, regular or irregular. So, to complete the proof, you must show that a regular n-gon has the greatest area of any n-gon with a fixed perimeter.
Actually, if we're going to be really precise, there's an additional step in showing that if a circle has greater area than any polygon with fixed perimeter, then there can be no shape with fixed perimeter with greater area than a circle, but this follows rather trivially from the fact that we can easily approximate any (convex, piecewise-smooth) shape to arbitrary precision with an inscribed polygon.
Unread 25-08-2014, 13:57
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is online now
I am Dave! Yognaut
AKA: Brian Bray
I would much rather stick to an octagon than bending 3/4" plywood around a 17.825353626292277606114981497722" inside radius
(since we are getting so precise that we say a circle is more useful than any reasonable N-gon, I figure you want to be spot on 112" perimeter)
Unread 25-08-2014, 14:09
AKA: Eli Barnett
If you find a supplier who'll sell you plywood with 32-sigfig tolerance on the sizing, let me know.
Unread 25-08-2014, 17:04
I am Dave! Yognaut
AKA: Brian Bray
I know. I still wouldn't want to bend plywood to a 18" radius
