Go to Post But their robot puts its wheels on one at a time just like ours, so we can be a HOF winner too! - Foster [more]
Unread 25-08-2014, 14:16
Raymundo N Raymundo N is offline
FRC #0842
Raymundo N is an unknown quantity at this point
Finding the thred size of a 3/4in. bore Bimba piston
Hello,
I am trying to print a mounting for a piston on a Maker Bot(3D printer). For this i need to know how to find the size of the mounting thread of the front of a 3/4 inch Bimba(brand) piston. If anyone knows the answer or how to find it please help.
Unread 25-08-2014, 14:21
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Finding the thred size of a 3/4in. bore Bimba piston
Look it up on www.McMaster.com or www.bimba.com -> http://www.bimba.com/Products-and-Ca...Line-Cylinder/
I believe the correct answer is 1/4-28
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by Raymundo N View Post
Hello,
On my phone but just go to McMaster and type in air cylinder. Filter by 3/4 bore and some stroke size. Click product detail and it'll call out the thread size. Same can be done with other size cylinders.
You can also go to the Bimba site and get the same info.
R.C.
MadTown Robotics Team 1323
Unread 25-08-2014, 14:34
FRC #0842
Ok Thanks, McMaster helped.
And just making sure (1/2'' - 20) means that there are 20 lines of thread in 1/2'' right???
Unread 25-08-2014, 14:37
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
That is incorrect. 1/2 is the diameter and 20 is the number of threads in a full longitudinal inch.
Hi!
Unread 25-08-2014, 14:41
FRC #0842
Oh ok well that makes more sense. Now im measuring the diameter of the piston mounting tread and from the part without thread i get .54 inches and where the thread is i get .61 inches. Does that make a difference?
Unread 25-08-2014, 14:52
FRC #0842
I also feel like i need more information in order to actually draw the thread into the mounting in Solidworks. Does anyone have any ideas on how to do this?
Unread 25-08-2014, 15:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Use the "Hole Wizard" tool, it has all the information needed.
Unread 25-08-2014, 15:03
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Solidworks should have a threaded hole feature built in, where you can select the thread type (if it is actually .61 it may be a 5/8" bolt at .625)
You just need to measure the major diameter (largest diameter you can get (so include threads) and the threads per inch. Then you should be able to use the threaded hole tool. Tell it it is a 5/8 - 24 bolt (or whatever it actually is) and how deep you want the hole to go, and it will draw the threads visually.
To actually get the three-dimensional model of the threads so it can print on a 3d printer you will have to go through a complicated process of drawing the profile and revolving it in a helical manner at 1/24" per revolution.
It may be easier to print the hole to the appropriate tap size In which case you would create a hole of that size in solidworks, so it is printed, then tap the threads into it. I suspect your printer may have difficulty providing enough resolution to make clean, strong threads.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 25-08-2014, 15:17
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
With my team's makerbot, we've always printed to tap into it for bolts. The default wall thickness is 2, but I like to double that to 4 layers for the taps - you want to make sure there is enough material there to hold.
2016: Lake Superior WFFA
Unread 25-08-2014, 14:40
Oblarg Oblarg is offline
AKA: Eli Barnett
Not quite.
Standard bolt sizes are notated as "diameter - threads per inch", so 1/2'' - 20 is a 1/2'' diameter bolt with 20 threads per inch.
Note that for smaller sizes, the first number may be given without units (such as "10-32"). This refers to machine screw size, (in this case, a #10), and if you want to know the diameter in inches you can just look it up (in this case, it'd be ~.19''). It helps to have a wall chart in your build space for this.
"The breakfast of champions!"
Unread 25-08-2014, 14:22
Knufire Knufire is offline
Fill in the information (bore, stroke, double vs single acting, etc) about the cylinder, and hit the dimensions tab.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 25-08-2014, 15:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Just to clarify, virtually every 3/4" bore cylinder I have ever used (primarily Bimba) in the United States has been a 1/4-28 UNF thread on the rod.
Unread 25-08-2014, 16:10
College Mentor
AKA: Trent Borman
Yeah, it seems a bit big, 0.61" might be referring to either the threads on either cylinder endcap for affixing it?
Unread 25-08-2014, 16:13
AdamHeard's Avatar
Lead Mentor
Yup, that's a .625-18 on those cylinders.
