Go to Post The robot competition is the most obvious, visible, and distilled-media-friendly part of the picture... We shouldn't be surprised that it's all that gets into the news coverage, when that coverage is managed by someone who isn't already well versed in what FIRST is trying to do. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #151   Spotlight this post!
Unread 26-08-2014, 15:46
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: blog; Motor Controller Options for 2015
Originally Posted by Oblarg View Post
My only problem with the daisy-chain configuration is that it greatly exacerbates the failure mode. It's rather annoying to lose half of your motor controllers instead of just one of them.
It would be nice if there were a supported alternative.
There is an alternate: PWM's
  #152   Spotlight this post!
Unread 26-08-2014, 15:49
Oblarg Oblarg is offline
AKA: Eli Barnett
While in the past I would have wholeheartedly agreed, this is a far less-appealing alternative with the new control system.
"The breakfast of champions!"
  #153   Spotlight this post!
Unread 26-08-2014, 15:51
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Do you mean with the robotRIO, or because CAN benefits are now available. If the former, why is everyone so down on using PWMs with the roboRIO?
  #154   Spotlight this post!
Unread 26-08-2014, 15:55
AKA: Eli Barnett
The former.
AFAIK, in order to use solenoids, you must use CAN.
  #155   Spotlight this post!
Unread 26-08-2014, 16:02
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
The former.
Correct me if I'm wrong, but I believe that the system is still plug and play with the modules. There is nothing extra needed to make the solenoid module work, the CAN implementation is in the background.
  #156   Spotlight this post!
Unread 26-08-2014, 16:03
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Originally Posted by FrankJ View Post
Since I don't speak for the Cross the Road people, this is based on what I know about CAN. CAN is a two wire bus. It is intended to be daisy chained.
Sorry Frank, but I'm really not sure where you are getting this from... In fact, you said it yourself, CAN is a two-wire BUS. Daisy chaining is just an easy method to accomplish it. There is nothing stopping you from putting terminating resistors at each one of your end points and then running everything back to a central hub rather than daisy chaining.
To my knowledge (and I haven't looked at all of the ISO standards and heaven only knows I could be wrong) there is nothing prohibiting the use of a star topology with a CAN network rather than a daisy chain topology.
  #157   Spotlight this post!
Unread 26-08-2014, 16:10
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
The former.
This may not be entirely true. While the new system does have a PCM module that automatically controls the compressor/pressure switch and has support for 8 solenoid channels.
Nothing stops you from using the 4 relay ports on the RoboRio to drive solenoids. Without needing to have a PCM.*
You can use One relay for the compressor, and 3 other relays for double acting solenoids. In fact, this is how we were running our pneumatics system using the RoboRio during Alpha testing when the PCM modules weren't supported yet. Only if you exceed 3 double solenoids, would you need to venture to use the CAN PCM module.
And even if you use the CAN module for pneumatics, that doesn't mean you can't or shouldn't use PWM. In fact, I believe most veteran teams will continue to use PWM on their drive train as a minimum despite the new control system, due to PWMs proven reliability and known failure modes. I believe this will be true even if they choose to use CAN motors elsewhere on their robot. Nothing currently prevents a mix use of CAN and PWM on the Robot.
*This is true as long as the 2015 rules do not prohibit this. Doing this is perfectly legal under 2014 rules.
Regards,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
  #158   Spotlight this post!
Unread 26-08-2014, 16:35
Jared Russell's Avatar
Taking a year (mostly) off
(Passive) star topologies are more susceptible to reflections and fan-out problems than traditional bus topologies and are best avoided for CAN networks in my experience.
  #159   Spotlight this post!
Unread 26-08-2014, 16:40
Controls Engineer
AKA: Kevin
This is not accurate. CAN can not be wired like any other network.
The protocol is named CAN Bus because it should only be used in a bus as it was intented, a bus is a type of topology. CAN can not be used in a STAR or Ring topology or Hub type topology natively without having additional CAN modules, or increasing the complexity of the layout, and even so, in the end, the Ring or Star implementation will only be a cosmetic one, and will not be more efficient then the original Bus topology. You will also loose a lot of link speed.
The current CAN products we have available in the FRC control system, including 2015, are internally hardwired, such that if a device fails, only the device fails, it does not bring down the entire physical bus. The device CANs act as pass-through so you can communicate beyond a failed device. How the software reacts to an ID that does not exist because it failed is a different story. WPI is currently working on implementing a NON-blocking CAN implementation for 2015, which should help teams have more graceful software failures.
Saying that if one CAN module goes down the entire bus goes down, or saying anything beyond the failed device is unreachable after that module goes down is not correct and shouldn't be perpetuated. However, it is a true statement that if you were to CUT the wires on the CAN BUS, you would loose all communication beyond the cut. This is where PWM differs marginally. If you wired every motor to an individual PWM channel, then you would have to cut every PWM cable to have the same effect, making PWM more robust. However, the reason I said marginally is because most teams I have encountered in my FIRST decade use PWM Y cable or even tri cables to drive up to 3 motors off one PWM channel. In this scenario if you cut the one cable, you loose all downstream communication making it very similar to the CAN problem, although you do not need to worry about what the software does if you loose the PWM connection. (Maybe this will be true for CAN in 2015 as well, I haven't beta tested the new CAN implementation yet).
I am not trying to say one is better than the other, I am just trying to clarify the rumors around these technologies so that teams can have all the proper information when choosing which one best suits their needs, based on robot design criteria and experience.
Regards,
Kevin
  #160   Spotlight this post!
Unread 26-08-2014, 16:43
marshall's Avatar
Saying that if one ID goes down the entire bus goes down is not correct and shouldn't be perpetrated. However, it is a true statement, that if you were to CUT the wires on the CAN BUS, you would loose all communication beyond the cut. This is where PWM differs marginally. If you wired every motor to an individual PWM channel, then you would have to cut every PWM cable to have the same effect, making PWM more robust. However, the reason I said marginally is because most teams I have encountered in my FIRST decade use PWM Y cable or even tri cables to drive up to 3 motors off one PWM channel. In this scenario if you cut the one cable, you loose all downstream communication making it very similar to the CAN problem, although you do not need to worry about what the software does if you loose the PWM connection. (Maybe this will be true for CAN in 2015 as well, I haven't beta tested the new CAN implementation yet).
Regards,
Kevin
Very useful. Thanks for clarifying.
  #161   Spotlight this post!
Unread 26-08-2014, 19:37
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Originally Posted by cgmv123 View Post
Labeling is a listed exemption in the relevant 2014 robot rules regarding modifying electronics; adding thermal paste isn't.
My common sense doesn't matter. I'm just cautioning against applying thermal paste/grease to motor controllers since the (2014) rule against modifying control system components specifically mentions gluing as an illegal modification.
Again, as Ether pointed out, thermal paste IS NOT GLUE. Glue is an adhesive, thermal paste is not.
Webster defines glue as : a substance used to stick things tightly together
http://www.merriam-webster.com/dictionary/glue
Even if you change glue to adhesive, thermal paste is not there to retain anything. It usually has a very weak bond, and often never sets, remaining a very thick liquid/gel.
Velcro is attached by adhesive or glue, but is legal. Please stop beating the dead horse and move on. I know at least a few teams will have the thermal paste on these speed controllers, if its explicitly allowed or not. It would be almost impossible for a robot inspector to see the thermal paste in place anyway. Im sure as soon as the Q&A opens, there will be more than one person who asks this. No need to keep dragging up the same ridiculous argument.
2014- 5031 Mentor
2013- 1310 Mentor
2012- 4258 Mentor
2011-2012 865 Mentor
2006-2008 1814 Team Captain, Main Driver, Mechanical
  #162   Spotlight this post!
Unread 26-08-2014, 20:37
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Will you be able to use all PWM's for your speed controllers and just do a very simple can run to your PCM? I am not a programmer or heavy into electrical beside powers wires so don't kill me haha. Thanks.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
  #163   Spotlight this post!
Unread 26-08-2014, 20:40
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
You should be able to.
  #164   Spotlight this post!
Unread 26-08-2014, 20:42
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Ty Bryce! We have ran CAN for the last few years and really am ready to throw these $@#$@#$@#$@# jags away. But cost wise, the new victors are a lot more appealing and lending towards PWM use
  #165   Spotlight this post!
Unread 27-08-2014, 03:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The caution about thermal paste is due to a plausible analogy between substances, rather than a mere dictionary definition. Like glue, it doesn't fall off the surface, so some phenomenon must be holding it there; is that adhesion significantly different from the adhesion provided by glue? If so, why, and how will you convince the officials of that?
If it's an argument of magnitude of adhesion, would you have the officials permit weak glue as well? If it's an argument of function, would you have the officials permit glue whose adhesion is redundant due to additional fasteners? If it's because thermal paste doesn't set, would that make uncured glue legal? If it's because thermal paste is pretty much inert and can't chemically harm anything, would mostly-inert glue (like mucilage) be allowed? Or if it's a combination of these factors, how should they be weighted when making a determination?
As for Velcro, isn't it (usually) covered by exception G in R64? Its legality is not a very strong argument for thermal paste.
Best to let the Q&A sort it out, but by all means let FIRST know now that you anticipate it being an issue during the season.
