Go to Post So we are able to run a very competitive and active robotics program. Sustainability, alas, is a month-to-month issue for us and is dictated by the space situation. This is okay today. Tomorrow could be different. We live like this. - Clem1640 [more]
Unread 28-08-2014, 12:20
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Recommendations for chain drive lubrication?
Originally Posted by hrench View Post
Finally, I've not had good experience with #25 chain. Go to #35 if you can. Also, WD40 is okay for a while, but it evaporates. In a month, it won't be there.
If you go with this option often could be close to daily with heavy use. While the exact composition of WD40 is a company secret, it is roughly a mix of mineral spirits & light machine oil. The oil part is persistent as any oil. The solvent helps to penetrate the side plates.
Anything with molybdenum disulfide is going to be messy. One reason why I ride a shaft drive BMW rather than one of the excellent Japanese bikes.
