Go to Post FRC is a game of mentors. The best teams are guided by mentors who know how to balance on the knife edge of pushing the envelope and achieving success. - Mr. Van [more]
Unread 28-08-2014, 00:19
Drew4564 Drew4564 is offline
It's Tape Measure Time!
FRC #4564 (Orange Chaos)
Team Role: Driver
Drew4564 is an unknown quantity at this point
pic: Modified AM Shifter Gearboxes
Unread 28-08-2014, 00:20
Andrew Lawrence
Posts: n/a
Re: pic: Modified AM Shifter Gearboxes
I apologize if I'm missing the obvious, but aside from the gold coloring what modifications have been made to this transmission, and why did you make them?
Unread 28-08-2014, 00:40
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Appears to be a 1st generation shifter, with its internal double sprocket, with the addition of an external extended output shaft, like a super shifter.
Unread 28-08-2014, 00:43
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
This is an AM Shifter. It is normally gold.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 28-08-2014, 00:46
Andrew Lawrence
Posts: n/a
Originally Posted by jspatz1 View Post
Appears to be a 1st generation shifter, with internal double sprocket, with an additional external extended output shaft, like a super shifter.
I didn't see the extended shaft on the first time around - thank you for pointing that out.
Unread 28-08-2014, 00:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
This looks surprisingly lightweight. Perhaps replacing the cylinder with a smaller one would be good though.
Unread 28-08-2014, 01:00
Team Role: Driver
We made them simply for the fact that we had two given to us by a retired team, and it was a much cheaper process than buying new ones. I agree that a smaller piston would be desirable, but I'm not sure what would work as a replacement.
Unread 28-08-2014, 01:06
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
If your looking for something more compact I'd recommend either:
Bimba Flat - 3/4 Bore (due to #10-32 male thread), could do 9/16" bore as well
FO-040.5-MT
or
VEXpro Pancake
You will probably have to modify spacer length as an FYI when switching to a pancake cylinder.
R.C.
MadTown Robotics Team 1323
Unread 28-08-2014, 09:46
jspatz1's Avatar
AKA: Jeff
These older gen-1 shifters are almost entirely steel (sideplates, gears, sprocket, shafts, dog, bearings, bolts) so they are actually quite heavy, but they are durable.
Unread 28-08-2014, 15:40
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
I like it as an engineering exercise. Were you planning on using these for next season?
Unread 28-08-2014, 16:23
Team Role: Driver
Yes, we are planning on using them for next season, and are currently in the process of building an off-season drive with them! It was a great way to learn Solidworks for my team, as we had to not only modify the gearboxes but put them on a WCD.
Unread 28-08-2014, 16:25
Team Role: Driver
FO-040.5-MT
or
VEXpro Pancake
My team will definitely look into these, thanks for your help! The current cylinder is much larger than it needs to be, and would take up a lot of space at the bottom of the drivetrain.
Unread 28-08-2014, 17:51
jspatz1's Avatar
AKA: Jeff
To obey fab schedule rules, you will need to disassemble them to their original COTS state, and replace and redo any modified parts.
Unread 28-08-2014, 20:10
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
I agree, this is the legal way of doing this.
A separate discussion altogether is, how many teams actually follow that vs teams that don't.
Unread 28-08-2014, 20:38
HP42S HP42S is offline
Rookie Year: 2020
HP42S is an unknown quantity at this point
Funny you should mention this. It was about 1 year ago when I was looking a little closer at possible FRC participation and as a total FRC noob couldn't figure out why everyone on CD was showing off their new drives before kickoff. So I asked a question on CD and was politely told how off-season work could be done. Got a much better understanding now
Still trying to figure out if it's really worth stepping up to FRC..... seems to me like the odds are stacked against 1st, 2nd and maybe even 3rd year teams.
