Go to Post It isnt about winning and losing (although getting the trophies and medals are nice) - Winged Wonder [more]
Unread 28-08-2014, 16:38
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Re: Alternate robot controllers?
What 3946 did was use an Arduino and two XBees to make a remote control T-shirt launcher.
All the code for the Arduino (and I believe the Firmware for the XBees) is avalible on our github: https://github.com/frc3946/MobileAirCannon
What we did was have the XBee standalone in the controller, using its dedicated IO lines as inputs. Then we had the XBee on the Arduino sending that data from the Controller to the Arduino via Serial. Then I made some breakout boards for PWM (S + -) and Relay (A B -) ports.
Here is the hardware we used:
Arduino Leonardo (an Uno or Mega would work just as well): https://www.sparkfun.com/products/11286
2x XBee Pro S1 https://www.sparkfun.com/products/8742
Arduino XBee Shield: https://www.sparkfun.com/products/12847
XBee Explorer USB (For Programming XBees): https://www.sparkfun.com/products/11812
XBee Explorer Regulated (For use in Controller up to 12volts): https://www.sparkfun.com/products/11373
The rest are just buttons, joysticks, battery holders, and switches to make the controller, and some perfboard and headers for the additional breakout headers.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 28-08-2014, 17:12
parkedraccoon's Avatar
parkedraccoon parkedraccoon is offline
FRC #0766
Team Role: Electrical
parkedraccoon is on a distinguished road
I'm not sure how your system will work, but if you're using Spike relays, the RobotOpen cannot drive the Relay ports on the sidecar, and driving them directly off the Arduino is iffy in terms of currrent draw (and a pain to wire). It worked great for us on a motors-only robot, but it didn't work on a robot with solenoids and relays.
"Why is it stupid?"
2006-2008 Little brother of Team 766 member
2008 FLL
2009-2014 FRC 766
2014-> ??? (hopefully some sort of mentor!)
