#166
Re: blog; Motor Controller Options for 2015
Regarding the CAN bus, to some extent, there's always an aspect of star topology on the bus—but traditionally the stub length is short, possibly on the order of a couple of millimetres (in the case of a direct connection to an integrated CAN transceiver). Barring any strange internal arrangement on these controllers, if you leave one pair unconnected, you should still be able to make the connection downstream to the remaining pair, but your stub length will increase.
Here are some general suggestions for optimizing stub length, given other parameters. |
#167
Here is what the CIA-- the organization that maintains the CAN standard, not the American government entity with the same name has to say. Quote:
#168
Quoting the 2014 rules, NO exception for Velcro, any team who used it violated the modifying motor controllers rule. I wonder if we should check every robot, and overturn matches from this past season? 4.9.11 R64 The Driver Station software, cRIO, Power Distribution Board, Digital Sidecars, Analog Breakouts, Solenoid Breakouts, RSL, 120A breaker, motor controllers, relay modules, Wireless Bridge, 12VDC-5VDC converter, and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions: Please note that the Driver Station application is a separate application from the Dashboard. The Driver Station software may not be modified, while teams are expected to customize their Dashboard code. A. User programmable code in the cRIO may be customized. B. DIP switches on the cRIO may be set (applies to cRIO-FRC only). C. Motor controllers may be calibrated as described in owner's manuals. D. Fans may be attached to motor controllers and may be powered from the power input terminals. E. If powering the compressor, the fuse on a Spike H-Bridge Relay may be replaced with a 20A Snap-Action circuit breaker. F. Wires, cables, and signal lines may be connected via the standard connection points provided on the devices. G. Fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT. H. Labeling may be applied to indicate device purpose, connectivity, functional performance, etc. I. Brake/Coast jumpers on motor controllers may be changed from their default location. J. Limit switch jumpers may be removed from a Jaguar motor controller and a custom limit switch circuit may be page 63 / 93 substituted. K. If CAN-bus functionality is used, the Jaguar firmware must be updated as required by FIRST (see Rule R67-D). L. Devices may be repaired, provided the performance and specifications of the device after the repair are identical to those before the repair. Again, im saying that it should be left to the Q&A, and that lawyering rules to this point isnt what FIRST is about, and as I said in my first post in this thread Quote:
Come on guys, use some common sense, If adding fans is legal for the purposes of cooling, do you really think first wouldn't allow thermal paste for the same reason? Last edited by donkehote : 27-08-2014 at 14:57. |
#169
Velcro is a brand of hook-and-loop fastener.
#170
Remember it was response to a Q&A question that got bumper tape banned in the First place. After considered discussion, they wisely amended their position. Silliness abounds on all sides. ![]() |
#171
Not to be stupid, but isnt it an adhesive or glue that attaches each side of the hook and loop to the speed controller? Essentially the same as gluing a nut onto the bottom of a speed controller. It IS a fastener, but its not attached with a fastener, its attached with an adhesive.
I do understand your point though. |
#172
I would love to hear what procedures IRI and CTRE have in place for assessing demand and reacting quickly to the supply of the new motor controllers. Using the initial Talon release and the shortages that ensued along with IFI's struggles to match inventory with demand, motor controllers could be scarce this season. Vex shows no stock of the old Jaguar and Victor controllers to supplement. AndyMark appears to have some Talons.
I expect demand to be high for both of the newly designed controllers! What will the restocking time frame look like? Is anyone else concerned? I am looking forward to the new controllers!!!!!!! |
#173
I imagine all parties involved have learned well from the previous events. Another reason is essentially they are the only speed controller on the market for FRC. Predicted demand should be easier. It's not them predicting how many teams will reuse speed controllers, how many will buy the competitors, and how many will buy theirs. It's just them predicting how many teams will buy versus reuse. When you compare this to the mechanical items it's not even fair. The purchase of mechanical components aren't an A or B or C thing, they're A1.... Z1242123. Even though Hex bearings are popular in FRC, I doubt anyone on chief would be able to accurately predict the amount purchased even IF they had access to all of the sales numbers from all of the venders (other than a lucky guess). I don't think they owe a public explanation to us on HOW they plan to do it (such information is propriety and the kind of knowledge that is worth good money). I'm pretty confidant it will be handled well. Edit. Since the parties involved represent the combined only source for speed controllers for the last few years, they now have exact numbers for how many teams purchase versus reuse. Plus margin for teams upgrading. Last edited by AdamHeard : 29-08-2014 at 14:41. |
#174
I agree with Adam - I think they'll probably do alright with speed controllers. All the same, I personally would encourage veteran teams to hold off on purchasing new ones a little bit so that rookies can get what they need - Veterans simply have more options than rookies do, as we are fortunate enough to have controllers we can pull off old robots.
It's really something when you think about what sort of inventory they might have for this upcoming season. If we just estimate about 5 new speed controllers for every team (some teams won't get any, some teams will buy 20), then that's ~15,000 new speed controllers. With an average price of $70 (assuming even distribution between Talon and Victor), that's over $1,000,000 worth of speed controller stock for just one season! Obviously, some major assumptions there. How many veteran teams will decide to use the "tried and true" speed controllers and avoid the new ones for at least 1 season? How many teams will decide to use all new ones? What will the mix be between PWM and CAN use with speed controllers and the new control system? |
#175
I find it a bit curious that they chose to utilize a single button to calibrate the speed controller, as well as switch between brake and coast modes.
#176
For reference. We plan to order 40 or so.
That's a good deal of our budget but we're at the point where we need more anyway and it's a good time to switch. |
#177
I hope some creative FIRSTer can get involved and bring another competitive product to market. A single-source supplier for such a critical component usually isn't a good thing from a consumer's point of view. Alternatives are important. |
#178
The competition comes in, I think, when FIRST put out the RFP for the new control system - companies had a chance to come in, show off what they had for everything (including speed controllers, if I remember correctly) and get themselves chosen to supply things for the next few years. |
#180
A PWM driven speed controller is stand-alone enough that competition can still be created though. The rest of the control system, not so much, except possibly the VRM. |
