Go to Post Indeed, the more ways you fail, the more ways you know something doesn't work.:) - Steven Sigley [more]
Unread 01-09-2014, 02:08
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Range Finder?
Ultrasonic range sensors may give unpredictable results if aimed at the player station. The diamond plate gives unusual reflections.
Are the unpredictable results consistent with:
Originally Posted by Nzoner View Post
The Ultrasonic sensor could not get a constant reading, and would often jump from 15ft to only a few inches which would triggers safeties and our launch system.
Our software team had similar spikes, and think that it is due to noise on the analogue signal.
Could those of you who used the Maxbotics sensors successfully provide some more info on how you did so? Which signal did you use (analogue/PWM/UART)? If you did anything non-trivial in reading the input (such as filtering), could you also provide some sample code?
We are also at a loss on how to read in the PWM signal (to get over the analogue noise above) directly into the cRIO (and probably roboRIO), if anyone has experience with reading in PWM signals it would be great to hear.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
