Go to Post Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. - RoboChair [more]
Unread 31-08-2014, 21:22
jzeiders jzeiders is offline
AKA: Jack Zeiders
FRC #4096 (Ctrl-Z)
jzeiders is an unknown quantity at this point
Recommended Chain Tensioners?
In the past my team has used a lot of improvised chain tensioners (pvc, bolts) and now for an off-season drivetrain project we are looking to use something a little better, thoughts?
Unread 31-08-2014, 21:38
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Recommended Chain Tensioners?
Check out this recent thread. There are some good ideas in there:
threadid=117430http://www.chiefdelphi.com/forums/sh...hreadid=117430
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 01-09-2014, 03:06
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That thread is good.
You can use special bearing blocks with tapped holes on the sides to use a screw tensioner. Look at team 221's site for more info on screw tensioners.
Vex cams are great tensioners, but will be less rigid than screws if you don't design it right. However, they are lighter than screw tensioners.
Unread 01-09-2014, 09:25
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
I personally love mcmaster's extended life roller chain tensioners.
Unread 01-09-2014, 10:00
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
Fenner Drives makes a low weight plastic #35 chain idler sprocket with integral bearing. The part number is CS3502. We used to buy them from MSC but they no longer carry it. Motion Industries shows it on their website.
