Go to Post If all else fails - bring cookies in the shape of FIRST shapes. Cookies are always good. - Eugenia Gabrielov [more]
Unread 31-08-2014, 21:05
pimathbrainiac's Avatar
pimathbrainiac pimathbrainiac is offline
Today, Regionals. Tomorrow, Worlds.
AKA: Philip N
FRC #1127 (Lotus Robotics)
pimathbrainiac can only hope to improve
CDBot - The Chief Delphi "New Thread" Bot on ##FRC
For those of you who frequent ##FRC, I made a bot for you that scans the RSS feed and alerts the channel when there is a new thread. It also has a few other functions (some useful, some not). Here's a list of them:
.google [search] - Googles [search] and outputs the link and the title
.test - outputs "test received"
.ping [url] - pings [url] and outputs the response code and whether or not the ping was successful.
There are a few others, though. You can look at the source for the rest of the commands: https://github.com/pimathbrainiac/CDPostBot
EDIT: It didn't detect this post. It is a work in progress, after all :/
Unread 31-08-2014, 21:20
icecube45's Avatar
icecube45 icecube45 is offline
Drive|Programming|Captain
FRC #0114 (Eaglestrike)
Team Role: Driver
icecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the rough
Re: CDBot - The Chief Delphi "New Thread" Bot on ##FRC
It just detected it
Unread 01-09-2014, 12:47
AKA: Philip N
Okay, so it's not instantaneous. It must be due to the RSS feed not updating instantaneously. Good to know. Thanks for the notice. Next function will be match scores, synced with TBA, if that' possible.
Unread 01-09-2014, 15:13
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
It's very much possible. TBA has an API that you can poll for changes. Additionally, if I get the time in the coming weeks, I'm going to work on adding webhook functionality, which will make it even easier.
Unread 01-09-2014, 18:29
AKA: Philip N
Thanks. I saw the API and am working on handing the json right now. I will also add lookup commands for past matches and events. I'll post an update here when it is done.
EDIT: It appears that there is something wrong with the API, or the way it works. When I use this url in chrome, I get the response data. When I use the same URL In Java, I get error code 400. Any ideas?
Unread 01-09-2014, 20:14
plnyyanks's Avatar
AKA: Phil Lopreiato
Are you supplying the proper "X-Tba-App-Id" header to identify your request? I can run the following command and get the proper response back.
curl --header "X-Tba-App-Id:foo:baz:baz" http://www.thebluealliance.com/api/v2/events/2014
If you need some help with using the API through java, take a look at this file in the TBA Android app - it should be a good starting point.
Unread 01-09-2014, 21:32
AKA: Philip N
I forgot. Thanks for that! I added it as a URL param.
Also thanks for the file link. That should come in handy!
Unread 12-09-2014, 06:28
AKA: Philip N
Some major improvements have been made recently. I'm working on tba lookups right now (with the last score of an event, some event data, etc. already done). I also added a .cdsearch function so you can search CD from IRC. I'll document everything once this is finished. For now, if you want to check things, you should go look at my source code on GitHub (and star it, while you're at it).
Unread 16-12-2014, 17:13
AKA: Philip N
It's been a while since I've posted here.
I have added a .help command, as well as some code for a very nice surprise once the competitions start
