Go to Post Doesn't matter what you use if you can't drive it. - efoote868 [more]
Unread 04-09-2014, 17:22
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
pic: FTC KOP inside SolidWorks
Unread 04-09-2014, 17:23
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: pic: FTC KOP inside SolidWorks
This is awesome! Thanks for putting this together.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-09-2014, 08:21
Let us know if we missed any component. We bought Tetrix Kits directly from Pitsco.
Please use these new models. The older models were off by 1/100's so multiple concentric hole mates were off.
Also, SolidWorks Tetrix defeatured models are vey light weight - better for purchased parts that you can't modify. Do teams need a fully featured model for purchased components? Your advice back to us would be great.
Let us know your pain points in design and we can assist. Interference detection, Stop at Collision are helpful tools in the Assembly. You can assemble the robot and insert a tool from the "tools folder" to see if you can actually assemble the robot with such tight spaces between components using a screw driver or wrench.
If you dont have SolidWorks, Pitsco is a SolidWorks customer and their Tetrix components are available in all file formats on www.3DContentCentral.com.
Good luck in the competition. Marie
Unread 07-12-2014, 06:05
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Hi Marie,
Thanks for your work supporting FTC!
We're trying to model the FTC 2015 field in SW. Has this been done elsewhere?
We've tried to convert the Creo assmebly, but not having much success with the main assembly.
Any help appreciated,
Craig
Unread 07-12-2014, 08:32
Owen Busler's Avatar
Owen Busler Owen Busler is online now
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
This webpage will most likely work for you.
http://www.catalogds.com/db/service?d=first&c=browse
It has the 2015 field and KOP cad files.
Unread 07-12-2014, 09:45
DavisDad's Avatar
MechE
Thanks Owen for the link. I couldn't get the Creo assemblies to work in SolidWorks. The AndyMark STEP files did:
http://www.andymark.com/FTC-Field-p/am-2970.htm
Unread 13-12-2014, 22:34
Sorry for the delay - China.
STEP files work better. Let me know if you need anything else. Marie
