Go to Post its not that I cant spell, I'm just being international. . . . I like it - Stuart [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Unread 06-09-2014, 16:42
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: FTC 2015 Challenge "Cascade Effect"
It's Finally time that we have a field with good construction methods. Our team has a full field on the way and were really excited.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 07-09-2014, 00:38
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
I was fortunate enough to encounter an actual field today at a kickoff event in Elkhart, and I must say I wish I did FTC this year. As for likely team/robot strategies, here are my initial thoughts:
AUTO:
There are two combinations of events that teams could potentially do in order to score a lot of points in auto - (1) Drive down the ramp, knock over kickstand, score in center goal, or (2) Drive down the ramp, score in a moveable goal, move the goal into the parking zone. #1 would score 110 points, #2 would score 70, 90, or even 120 points based on if the robot pushed 1 or 2 goals. I personally would prefer method #1 since it scores more points if you do it right, and sets up the field for an effective teleop.
TELEOP:
Teleop is interesting this year because during the 1:30 before the endgame, scoring balls in moveable goals is the only way to earn points. Therefore, EVERY COMPETITIVE TEAM WILL SCORE IN THE GOALS, most of which will likely be the 90 cm goal. If a team can make a way for the robot to collect and score balls from the floor without continuously using a lift of some sort will be able to score 5 balls every few seconds, making an effective teleop. Note that a team may not collect balls from the center "cascade" dropper and score them, i.e. the balls must contact the floor prior to scoring for the score to count (GS2). The wiffle balls will be crucial to scoring the most points the fastest, but since 80% of the balls are golf balls, all of the competitive teams will probably aim to collect them as well. I also noticed that there are little holes in the moveable goals, perfect for a robot to latch onto and drag around the field as it picks up balls to score.
ENDGAME:
Endgame provides many options. For the moveable goals, you can either have them in the parking zone or lifted off the ground, but not both. Since lifting provides 30 points, while parking is only 10, I think it is safe to say that teams that CAN lift WILL lift instead of parking. Robots themselves will most likely be parked, and many teams will build a robot that can lift other robots. If an alliance has one robot that lifts a goal and the other robot, who is also holding a goal, then the total score I believe is 110 points. Finally, most teams I think will attempt to score at least one ball in the center (if they did not in autonomous) since that first ball will score 180 points. (Can someone tell me I'm wrong? This seems awfully high )
So, the "optimal" robot will be capable of knocking away the kickstand and scoring balls in the middle goal during autonomous, scoring balls in the 30cm goal without continuously using a lift up and down, and lift a goal and/or robot during endgame. A single robot that does this could easily score over 300 points alone, I feel, so I imagine an alliance that is 1 offense/1 defense could actually be very strong this year.
Unread 07-09-2014, 00:54
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Originally Posted by tindleroot View Post
I
ENDGAME:
1. The ramp is "off the Floor", so teams will simply park rolling goals and their robots on the ramp.
2. From the game manual:
Ball Height – The measurement from the bottom of the Ball Tube to the top of the uppermost Ball in the Ball Tube, i.e. the height of the stack of Balls in the Ball Tube. This is used when calculating the Score for a Goal.
6 points for each cm of Ball Height for Balls Scored In the Center Goal.
Therefore, the 1st ball is only worth 6pts time its height. The game animation was poorly worded regarding the scoring. (90 cm is 100% irrelevant except for the difficulties it presents in placing balls, leading to a higher scoring multiplier.)
--Jacob
Illinois FTC FTA
Unread 07-09-2014, 01:34
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
This seems like a nightmare to make sure points are awarded accurately. Not to mention time consuming.
Other than that, this seems like a fun and challenging game. Hope this foreshadows an equally diverse FRC game later this year.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 07-09-2014, 05:32
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I don't think it's that bad, as long as points are scored at the end of the match. Although close ties could be hotly contested. And even touching the tube to measure might cause the level to go down.
Unread 07-09-2014, 01:36
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Though I have never been a part of FTC, here is what I see being a really competitive robot
On the back of the robot is a latch for grabbing onto the 90cm goal, never letting go, so the goal becomes a trailer being rigidly towed for the remainder of the match.
The robot has a continuous intake/lifting system that reaches up to the 90cm goal. Of course it will have to start 18cm and unfold/telescope to that height. This lifting system is similar to a conveyor belt (perhaps with brushes?) that takes balls from the floor, and straight up dumps them into the goal it has possession of.
If said mechanism is fast enough, you will be incapable of acquiring more than 5 balls at a time, because they will be spit out the top too fast.
Unread 07-09-2014, 11:09
AKA: Casey LeeVan
I was thinking about a robot like that too! It would also score in the middle goal during auto.
Unread 10-09-2014, 12:11
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
It's funny they called it Cascade, since that usually refers to water. Haha. Water game joke.
You can't grab on to the ball tube (major penalty), and grabbing onto the bottom would risk toppling the tube over, especially the 90cm one since it's not wheels on the bottom but little metal ball things.
Unread 10-09-2014, 13:00
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
It all depends on how you grab the bottom, look at the Robot in 1 Weekend machine, it will prevent it from tipping over if you are dragging it behind the robot.
Unread 10-09-2014, 14:45
Shrub's Avatar
no team (N/A)
Ah, my bad. I haven't caught up on their robot.
I wonder if teams will try to move their own goal tubes in front of the opponents for max points.
Unread 10-09-2014, 16:36
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
We pulled a full 90cm goal up the ramp without it tipping, but know that the 90cm ones when they roll down the ramp (even empty) will usually topple over when they hit the matt. Sometimes the 60 cm one will tip as well.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 11-09-2014, 22:42
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
This was one of the first ideas the team had. It's going to be the first design we prototype! I'll let everyone know how it goes.
Unread 28-09-2014, 16:16
totalreboot totalreboot is offline
FTC #8441
totalreboot is an unknown quantity at this point
what if you were farther from the goal? wouldn't the mechanism simply gather balls with nowhere to spit them out of?
Unread 28-09-2014, 23:35
I am Dave! Yognaut
AKA: Brian Bray
If you had this vertical conveyor system, I would think you could start/stop it at will. If you didn't have a goal in your possession, you could simply hold onto the ball, like any other mechanism. Again, this was all theoretical. It is up to you to make it work.
Unread 11-09-2014, 12:44
jdaming jdaming is offline
jdaming is on a distinguished road
It also says in the scoring table listed on Page 7 of game Manual 2 "Balls Scored In (from floor) Center Goal".
Therefore the first ball would count for 120cm (top of center goal) - ~27.5cm height of center goal + height of ball (~7 cm big) = 100cm x 6 = 600pts.
I agree that this seems like a game breaking amount of points but I think the challenge of getting a ball scored at 120CM will be difficult. I am wondering why it is referenced both in the video and where I quoted above if counting from the floor is not the intention.
Someone please correct me if I have misinterpreted something.
